Unicyclist Community
Reply
Old 2004-01-05, 08:25 PM   #1
jagur
My Uzi is a Tongue
jagur's Avatar
Arrow "Mountain Unicycle Brakes" Darren Vs. Unicycle.com Vs ordering straight from Magura
i need to get a brake for my KH24 and i have a couple of options now i guess.
i was just going to get one from Darren but today i noticed that
unicycle.com now has a similar option for $159 US.Darrens brakes are
here for $170 US
also,by the quote "The tech team at Magura USA is now custom-making these for unicyclists." on unicycle.coms discription,it sounds like these may be availible though local shops.is there a chance that these are just standard length front brakes and not really made just for us? can someone who works at a shop call Magura and get more details...?
i would also like thoughts on which is better,Darrens or Uni.com's... why on uni.coms Magura picture is one brake black and the other silver?
Thanx...
__________________
theres enough BS in life, without mobius contributing.
Forget_Your_Life
-------MUNI MILITIA -------
One Wheeled Death Squad
twitter> @shot of jagur
jagur is offline   Reply With Quote
Old 2004-01-05, 10:03 PM   #2
manic_mark
level 4!
im pretty sure its just a standard front magura brake, available from most bike stores, as i've heard of people buying a pair (f + r) and just shortening the rear hose, as it works out cheaper as a pair bought between 2. In the uk a pair can be got for £85(150 USD) if you shop around, whereas a front brake alone is £50-60 (90 - 108 USD).
__________________
lever (dot) mark (at) ntlworld (dot) com
manic_mark is offline   Reply With Quote
Old 2004-01-05, 11:41 PM   #3
karl
Endless Productions
I have One of Darren's Brakes...it is really good.
From what I've heard and noticed the length of the tubing is just right. I have seen an older uni.com brake but not the new one. The uni.com (new one) has a quick release mount were Darren's does not which I kind of like becuase it won't come loose and jiggle or fall off.
Karl
karl is offline   Reply With Quote
Old 2004-01-06, 12:02 AM   #4
johnhimsworth
Registered User
johnhimsworth's Avatar
on the uni.com photo both brakes are black, but only one is in the silver bracket thing which attaches to the brake boss. The problem with the uni.com one's is that the little black elbowy things go inside the frame to stop the brakes from rotating away from the tyre, which reduces the clearance. I have these on a nimbus 2 (yuni?) frame with a halo ception 2.6, and it fits, but it's a bit tight. Don't think a 3.0 would fit. And the bosster is only made for 2.3 tyres, will fit 2.6 tyres after being attacked with a saw/file, but I doubt very much it'd go on a 3.0
The brackets on darren's use 2 bolts to attach, so don't need the elbow or the booster. I think they might be the only one's that fit on frames with brake mounts too - the uni.com (standard) brackets go on normal bike brake bosses. I think the 2 bolt version is made just or unicycles.
Other than the brackets I think the brakes are normal hs33's in both cases. Mine's a front braqke and the cable length is about right.
e-bay's quite good for magura's too. I got a set of 2 for £50, and sold 1 to phil. Bargain.
John
__________________
Never argue with an idiot; they drag you down to their level and then beat you with experience.
johnhimsworth is offline   Reply With Quote
Old 2004-01-06, 01:27 AM   #5
Checkernuts
currently riding bikes
Checkernuts's Avatar
Send a message via Yahoo to Checkernuts
I've seen 3" boosters arround, but if you have the option to not run a booster and have the maggie style mounts that dont require it thats deffentatlly the way to go.
__________________
No one said it was gonna be easy and I'm not afraid to try, with the odds stacked up against me I will have to fight, One Life One Wheel got to do it right. H2O
Checkernuts is offline   Reply With Quote
Old 2004-01-06, 02:21 PM   #6
johnhimsworth
Registered User
3" boosters are here.
You still have the little elbow thingy's though. You probably don't need to use them to keep the brakes in place, but I think they're part of the bolt that holds the top of the clamps together, and holds the booster on, so I don't know if it'd be possible to remove them, although you might be able to replace them with a normal bolt. you might just be able to twist them around to be out of the way, either downwards so they`re away from the wide bit of the tyre, or on the outside of the frame.
Go with the 2 bolt version. They look so much nicer.
John
__________________
Old 2004-01-06, 04:58 PM   #7
jagur
My Uzi is a Tongue
jagur's Avatar
i mentioned that the brake is for my KH24 which has the 2 bolt version,so i dont know why the booster chat is going on here but thanx anyway.
__________________
Forget_Your_Life
Old 2004-01-06, 07:10 PM   #8
zod
Southern Fried mUni
zod's Avatar
Send a message via AIM to zod
jagur, any bike shop will be able to get you one and for cheaper than what uni.com offers it for.....
A better bet is to look for one on ebay.....I picked up a used one for $20
zod is offline   Reply With Quote
Old 2004-01-06, 07:13 PM   #9
Sofa
you - pee - dee
Sofa's Avatar
Quote:
Boosters are needed with the 2 bolt version
But not in the 4 bolt version like on your Uni
__________________
Happy Life Day
Sofa is offline   Reply With Quote
Old 2004-01-06, 07:49 PM   #10
jagur
My Uzi is a Tongue
jagur's Avatar
oh,i was talking about a leg by leg basis.
__________________
Forget_Your_Life
Old 2004-01-06, 08:01 PM   #11
bugman
NAUCC 2006 Memphis
bugman's Avatar
Jagur,
If you find some killer deal on a pair of brakes the same quality as those on Uni.com. I will gladly split it with you. I would be glad to let you have the longer one. Besides, you are most likely more mechanical than myself, and would relish the challange of modifying the cable.
__________________
Support my Tour de Cure Ride!
Go here to Donate!
Thanks!!!
bugman is offline   Reply With Quote
Old 2004-01-06, 08:18 PM   #12
Sofa
you - pee - dee
Sofa's Avatar
Yeah! One more from Jagur to add to my collection!
Today is a good day to post
__________________
Happy Life Day
Old 2004-01-07, 10:17 AM   #13
jagur
My Uzi is a Tongue
jagur's Avatar
yeah,yesturday was pretty good...
__________________
Forget_Your_Life
Old 2004-01-07, 10:19 AM   #14
pete66
UNI branded
pete66's Avatar
Send a message via MSN to pete66
I'm gonna try and hold out for the uni-specific lever to come out, wonder when that will be?
pete66 is offline   Reply With Quote
Old 2004-01-07, 12:17 PM   #15
zod
Southern Fried mUni
zod's Avatar
Quote:
Don't hold your breath, Magura could care less about the unicycle market. Just get one of these and cut it down.....they work great
http://www.unicycle.com/shopping/shopexd.asp?id=516
Reply
Tags
darren, magura, mountain unicycle brakes, ordering, straight, unicyclecom
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.08708 seconds with 9 queries
