Unicyclist Community
Go Back   Unicyclist Community > Unicycling Discussion > Unicycle Product Reviews
Reply
Old 2003-12-30, 08:18 AM   #1
daino149
On Vacation - till i find a job
daino149's Avatar
Send a message via AIM to daino149
Trials Tires
This thread is not a review but I thought this is the best place for it anyway. I wanted to know more about trials tires. So far, the only two I know of are the Monty and Luna. From what I hear, they are very similar. I have a Luna on my Summit trials, but it's getting worn down. I was wondering what other trials tires are available. I would prefer having a slick tire.
Thanks,
Daniel
__________________
OPPORTUNITYISNOWHERE
daino149 is offline   Reply With Quote
Old 2003-12-30, 06:40 PM   #2
super_evill
Addicted To Jesus
super_evill's Avatar
I'm not quite sure what you mean by a slick tire but their is the onza sticky finger tire on unicycle.uk. It has sticky stuff about 1 inch wide going around the tire. It looks awesome.
__________________
"Whadda ya want me to do, whack a guy, off a guy, whackoff a guy, cuz I'm married"- Peter Griffin
super_evill is offline   Reply With Quote
Old 2003-12-31, 03:51 AM   #3
john_childs
Guinness Mojo
john_childs's Avatar
Quote:
The soft sticky center section of tread just means that area of the tread is going to wear down faster. Unless you're doing trials on things where you need the extra sticky tread, the tyre is a waste. A regular trials tire like the Monty will last longer and the tread on the Monty is plenty sticky enough for almost everyone. If you're pushing the envelope and loosing traction on your trials obstacles then maybe the Onza Sticky Fingers tyre will help. Just don't expect the Sticky Fingers tyre to last as long as a Monty.
__________________
john_childs (att) hotmail (dott) com
Team Never Wash Your Muni
My Gallery :: Unicycling Bookmark List :: World Clock
john_childs is offline   Reply With Quote
Old 2003-12-31, 04:17 AM   #4
jagur
My Uzi is a Tongue
jagur's Avatar
Quote:
and like-wise,dont expect the Monty to last as long as a Luna.
__________________
twitter> @shotofjagur
jagur is offline   Reply With Quote
Old 2003-12-31, 05:58 AM   #5
john_childs
Guinness Mojo
Yes, it is good to remember that the Luna has a harder rubber compound than the Monty tire. That is something that I had forgotten.
It would be nice if there was some place that had the durometer numbers (a measure of rubber hardness) for the various trials tires.
__________________
Old 2004-01-01, 12:51 PM   #6
gingerfreek
unicyclist of mass destruction.
gingerfreek's Avatar
there is another trials tyre out there, which i don't believe any unicyclist has tried yet. it's the echo supa mod rear bike trials tyre. i have found one place that supplies them in the uk so the next tyre i get for my trials uni will be that. apparently it is lighter and as strong as the monty(side walls are of same strength) so that sounds good.
it should be easier to get hold of them in america as Echo bikes is American i think.
iain
__________________
www.hogsquad.co.uk - ain't no mingin', this s***'s blingin'!
gingerfreek is offline   Reply With Quote
Old 2004-01-04, 07:23 PM   #7
johnglazer
We own you
johnglazer's Avatar
Send a message via AIM to johnglazer
you can get echo trials tires at
http://www.webcyclery.com/.docs/prod...t_details.html
there are a couple more at this site too.
http://www.webcyclery.com/.docs/m/10...ct_search.html
just make sure it says mod tire, unless you do trials on a 26" uni...
john
__________________
www.rowletts.com
www.sixsixone.com
johnglazer is offline   Reply With Quote
Old 2004-01-05, 01:48 AM   #8
fluffinator007
Expert UPD'ist
Send a message via AIM to fluffinator007 Send a message via Yahoo to fluffinator007
Also with trials tires, how often do you think you should rotate them, or should you rotate them...I notice after many a hops/jumps/drops. The area that flexes the most (the part that touches the ground and gives in and bounces out) has a sort of white kind of dust sort of thing from the rubber flexing so much? This is on my 20'' summit trials. Does this happen to every tyre and will it wear it down, if so how often should i rotate it...and hsould i rotate the inner-tube as well.
fluffinator007 is offline   Reply With Quote
Old 2004-01-05, 02:57 AM   #9
johnglazer
We own you
johnglazer's Avatar
I rotate my tire when the tread gets worn down a lot. Also, you can't really rotate the innertube because of the valve stem, but you can rotate the cranks. You could just rotate the cranks and it would be like you rotated the tire.
john
__________________
www.rowletts.com
www.sixsixone.com
Old 2004-01-05, 03:05 AM   #10
fluffinator007
Expert UPD'ist
ah yes, i could, but rotating the cranks sounds like a difficult task that a guy with my knowledge could not safely attempt
Reply
Tags
tires, trials
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright © 2001-2016 Gilby
Page generated in 0.08475 seconds with 8 queries
