Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 |
Uni-fied in Christ
Hi, I was wondering have any of you ever thought about drilling holes in your trials uni frame, possibly the forks for the purpose of making it lighter... I guess this is a three part question...
First: Has anyone ever done it? if so, then 2ndly, how did it work and where did you do it on the uni frame? and lastly... whether you have or havent what do you think about the idea? The reason that I am asking is because My trails uni is pretty heavy (summit) and it has pretty thick forks on it... so, I think that it would make it lighter, and I dont think it will compromise it strength too much to where it would break... all opinions are welcome!! Thanks! |
#2 |
Too gnaaaar for a KH20
The best way to make a frame lighter is to use thinner walled material. Ideally the frame designer should use a thin a wall as posible to start with. Drilling holes in tubes isn't a particually good idea as they will lose a lot of the strength that comes from the shape. If you are keen to save weight then save up for a new frame or have one custom made. Sorry
![]() The weight saving from drilling holes wont be that great, anyway. Can you remove weight anywhere else? (Saddle base, pedals ?? ) I used to design gears for racing cars and we'd have to add holes to our gears for the American market because that is what the customer percieved to be better. For European stuff we'd always go with thinner walls because that gives better strength to weight. HTH Nick |
#3 | |
Quote:
.duaner. |
#4 |
Back into muni!
I reckon instead of drilling holes in the frame chose lighter clothes to ride with. It'd probably make about the same difference wouldn't it?
Good luck, Andrew
__________________
#5 | |
Quote:
If he's caring any tools or spare parts, losing those might drop some weight fast. Also, excess water is excess weight - each (extra) liter of water is an (extra) 2.2lbs (1kg)! - But, please do carry enough water to stay properly hydrated. .duaner. |
#6 |
Uni-fied in Christ
thanks guys...
what I mean is not to necessarily drill it to make it lighter, but more so it just seems like the holes would make it more airy... My husbands summit is fine for him, but for trials it is a little heavy for me... so this is just an idea we had... please, continue on with feedback!! All is appreciated! Thanks! |
#7 |
My Uzi is a Tongue
how about cutting a long half inch wide slot on the inside of the fork blades? (inside only)
you could also buzz off the medal arrow things on top of the crown
__________________
theres enough BS in life, without mobius contributing. Forget_Your_Life -------------------------------------- -------MUNI MILITIA ------- One Wheeled Death Squad twitter> @shot of jagur |
#8 |
North Shore ridin'
If it were a Schwinn frame I'd say drill away. I have done this with a couple of Schwinn frames, but if you want lightness you would not be using a Schwinn in the first place. A frame made of tubing is designed to be solid tubing. Get a lighter rim and you can save more weight than you probably ever could by weakening the frame.
Seats and seatposts are huge harbingers of weight also. Remove all excess parts, and cut off excess post. Someday, Trials unicycle seats might consist of little more than handles, to keep the weight down. Similar to a Trials bike, with those tiny plastic seats. Plus, for total weight (including rider) don't worry about clothes... Period.
__________________
John Foss "jfoss" at "unicycling.com" www.unicycling.com "Unicycling is a way of looking at the world, making a choice to slow down, finish what you start, doing things not because they're easy, but because they're a challenge." -- Nurse Ben |
#9 |
Newsgroup User
Posts: n/a
Re: drilling holes into trials uni frame???....
On Mon, 29 Sep 2003 05:41:51 -0500, andrew_carter
<andrew_carter.uik4f@timelimit.unicyclist.com> wrote: >I reckon instead of drilling holes in the frame chose lighter clothes to >ride with. It'd probably make about the same difference wouldn't it? And pee and poo beforehand. :-) Klaas Bil - Newsgroup Addict -- If the crank is moving then it really sounds as if it's loose. - onewheeldave trying to pinpoint the cause of a clicking crank |
| Tags |
| drilling, frame, holes, trials, uni |
