Unicyclist Community
Reply
Old 2003-06-24, 11:12 PM   #1
ITEMNO530
MOST REPLYS FTW
ITEMNO530's Avatar
Send a message via AIM to ITEMNO530 Send a message via Skype™ to ITEMNO530
Angry Crank arm help
Okay, I just got my first uni about 4 days ago, and the wheel was put on backwards. So I turned the wheel around and blah blah. Ok, now I noticed that the errr... hmmm... the little black thing on the pedals that you scrw into the crank arms, I guess, are different.... problem. Now the threading inside my right crank arm is stripped..... damn. The bastards at the bike shp screwed me over and they won't do anything about it. So, the questions I want to ask are how do you take the crank arm off and is it possible to buy just one crank arm offline anywhere and where? >,< this really pisses me off... ARGH!! But oh well, LABTYD. Well, I'll check up later on posts, thanks for any help you can offer.
Unicycle to live, live to Unicycle
__________________
Here I am! Now what were your other two wishes?
ITEMNO530 is offline   Reply With Quote
Old 2003-06-25, 01:38 AM   #2
Dirtsurfer
One wheeled
Dirtsurfer's Avatar
Why not try another bike shop and have them tap out the crank arm and try to save it. If that fails, measure their length and give Uni.com a call, you can get both for $25. Next time you may want to post what brand and size uni.
__________________
"All we have to decide is what to do with the time that is given to us." Gandalf the gray
Dirtsurfer is offline   Reply With Quote
Old 2003-06-25, 03:15 AM   #3
ITEMNO530
MOST REPLYS FTW
ITEMNO530's Avatar
My uni
It's a silver Torker, 20" wheel.
__________________
Old 2003-06-25, 11:47 AM   #4
onewheeldave
Semi Skilled Unicyclist
onewheeldave's Avatar
That reminds me of the first uicycle I bought over ten years ago.
I was a bit upset when the crank fell off and then realised they'd put the wheel on backwards- this was from a juggling shop as well.
I guess it's an easy mistake to make, nevertheless your bike shop has messed up and you should go back and demand some compensation. If you swot up on the consumer rights of your area and sound as though you know what you're talking about you should be able to get it sorted.
At the end of the day they've sold you something which is defective, and there are clear laws about that kind of stuff.
Normally to take the crank arm off you need a crank remover tool, in the case of stripped threads I'm not sure what you should do. spare cranks can be got online from www.unicycle.com and www.unicycle.uk.com
To experienced unicyclists- I also think that another useful bit of advice to add to the usual tips for new uni purchasers is to check their wheel is on the right way, check the seat is pointing the right way, check the left crank is actually on the left etc. etc.
__________________
"You can't outrun Death forever.
But you can make the Bastard work for it."
--MAJOR KORGO KORGAR,
"Last of The Lancers"
AFC 32
onewheeldave is offline   Reply With Quote
Old 2003-06-25, 04:43 PM   #5
Mandell
Still riding
Mandell's Avatar
OK, I give up.
How can you tell that the wheel is on backward (as opposed to the seat)? Is it a matter of the tire tread?
Mandell is offline   Reply With Quote
Old 2003-06-25, 07:49 PM   #6
dazedNcontused
Proud Uni-Dad
You can look at the pedals to see if it's assembled right. If everything is on right (and the pedals aren't cross-threaded), the Right pedal should be on the right side. Pedals are usually marked Right and Left.
The Left pedal should be on the right side too, but that's the Left.
Tim
__________________
She was so impressed she didn't even roll her eyes. - Harper
dazedNcontused is offline   Reply With Quote
Old 2003-06-25, 08:15 PM   #7
Mandell
Still riding
Mandell's Avatar
But, again I ask:
If the pedals are on the correct cranks, how can you tell if the wheel is on backwards as opposed to the seat being on backwards?
Old 2003-06-25, 08:21 PM   #8
bugman
NAUCC 2006 Memphis
bugman's Avatar
Quote:
Originally posted by Mandell
But, again I ask:
Mine has stickers that would be on the wrong side if you had it on backwards, on the KH the crown would slop the wrong way.
__________________
Support my Tour de Cure Ride!
Go here to Donate!
Thanks!!!
bugman is offline   Reply With Quote
Old 2003-06-25, 10:25 PM   #9
ITEMNO530
MOST REPLYS FTW
ITEMNO530's Avatar
Question huh?
What's a suicide mount?
__________________
Old 2003-06-25, 11:08 PM   #10
Klaas Bil
Newsgroup User
Posts: n/a
Re: Crank arm help
On Wed, 25 Jun 2003 14:49:57 -0500, dazedNcontused
Yes and the Right pedal should be left right where it is :-)
Klaas Bil - Newsgroup Addict
"No two crotches are alike. If they are, I don't want to know about it. - John Foss, on seat comfort."
Old 2003-06-25, 11:08 PM   #11
Klaas Bil
Newsgroup User
Posts: n/a
Re: Crank arm help
On Wed, 25 Jun 2003 15:15:01 -0500, Mandell
Some things are directional on a uni, some are not. The wheel, that is
to say the rim, has no directional preference as far as I am aware.
The tyre may have; if it has an arrow-shaped profile then usually the
arrows (V-shapes) point in the direction of travel at the top of the
wheel. I don't know if there is a technical reason for that - maybe it
transports water to the side? The hub technically has no preference,
but some purists mount it such that any lettering on it is readable
through the valve hole, when the left crank is on the left-hand side.
The seat, pedals and cranks are obvious. The frame may have a sloping
crown in which case the low side is the front. Also, the seat post
clamp should be on the rear.
I hope that helps.
Old 2003-06-26, 01:05 AM   #12
phil
Average wheels: 1.5
phil's Avatar
Frames usually have a slot in the back where the seatpost clamp goes in. I find this the easiest way of telling back from front if I've taken the seat off.
Phil
__________________
"Cattle Prods solve most of life's little problems."
phil is offline   Reply With Quote
Old 2003-06-26, 05:37 AM   #13
ITEMNO530
MOST REPLYS FTW
ITEMNO530's Avatar
what the.....
So, what's a suicide mount.... anyone?
__________________
Old 2003-06-26, 05:50 AM   #14
UniBrier
Time To Ride
UniBrier's Avatar
Re: what the.....
Quote:
Mind Over Manhood
__________________
Steve
Hop Drop & Roll
“If something is too hard to do, then it's not worth doing. You just stick that guitar in the closet next to your
shortwave radio, your karate outfit and your unicycle and we'll go inside and watch TV.” – Homer
UniBrier is offline   Reply With Quote
Old 2003-06-26, 10:09 PM   #15
ITEMNO530
MOST REPLYS FTW
ITEMNO530's Avatar
Hmmm??
So, how do you do a suicide mount? O,o
I'm lost, I know... at least I think I do.......
__________________
Reply
Tags
arm, crank
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.08545 seconds with 9 queries
