Unicyclist Community
Reply
Old 2003-06-18, 10:20 PM   #1
Kenny
Registered User
Send a message via ICQ to Kenny
Oh dear, oh dear oh dear oh dear.
Hello,
A couple of days ago i tried some different crank lengths, and of course managed to **** ** the threads on the hub. My almost new UDC Max Traction.. *sob* ..
Well, if i was an optimist i could always think that this is a great oppertunity to learn to ride long-distance one-footed, or wheel-walk and some gliding. But i'm not...
According to my bank account my options are:
A. Weld crank to hub and rebuild wheel when my wallet is big enough for new hub and cranks.
B. Fix the threads. (No idea how).
C. Become an optimist..
Any tips or suggestions? I can't be the only one who have messed up this?
/Kenny
Kenny is offline   Reply With Quote
Old 2003-06-18, 10:37 PM   #2
onewheeldave
Semi Skilled Unicyclist
onewheeldave's Avatar
I'm afraid I've got no experience with fixing threads, but I was wondering what you did to damage them as it may help others to avoid doing the same thing.
__________________
"You can't outrun Death forever.
But you can make the Bastard work for it."
--MAJOR KORGO KORGAR,
"Last of The Lancers"
AFC 32
onewheeldave is offline   Reply With Quote
Old 2003-06-18, 10:47 PM   #3
phil
Average wheels: 1.5
phil's Avatar
Re: Oh dear, oh dear oh dear oh dear.
Quote:
Definitely not; I think I've actually heard of more people destroying / damaging hubs this way than bending them. I did it to my Max Traction, by forgetting to remove the nuts before trying to remove the crank with the crank remover. Overtightening of the nut will probably do the same thing.
If you get the crank(s) welded on, sooner or later you will have to replace the lot for one reason or another, including the price of a new set of cranks. I'd definitely try to find some way of getting hold of a new hub, even if it's a cheaper one rather than a suzue; if you're not doing big drops I don't think there's any difference.
Phil
__________________
"Cattle Prods solve most of life's little problems."
phil is offline   Reply With Quote
Old 2003-06-18, 10:50 PM   #4
Kenny
Registered User
Either i tried to tighten it to hard, and/or the bolt wasn't properly in place when i tightened it.
Never underestimate the damage a hungry and tired Kenny can do..
Old 2003-06-18, 11:22 PM   #5
andrew_carter
Back into muni!
andrew_carter's Avatar
Take it in to your local bike shop and see if they can help you out. In my early days working at the bike here I stripped the thread on a crank arm and Gary fixed it for me.
Good luck,
Andrew
andrew_carter is offline   Reply With Quote
Old 2003-06-19, 07:09 PM   #6
JoeRowing
MUni Animal
JoeRowing's Avatar
Send a message via AIM to JoeRowing
you've had it
welding will knacker the heat-treatment.
Either buy a new hub or possibly get an engineering company to braise-up the threads with some high-strength nickel-bronze rods and re-cut the thread.
__________________
Joe
gravitykarma.co.uk
JoeRowing is offline   Reply With Quote
Old 2003-06-19, 09:20 PM   #7
cjd
Pashley apologist
cjd's Avatar
Re: Re: Oh dear, oh dear oh dear oh dear.
Quote:
Yep, that's how I did mine. I was getting a click on one side. I thought it was the crank, so I torqued it. Must have been the pedal or a spoke.
I stripped some of the threads on the hub and most of the threads on the nut. The hub will still hold a (replacement) nut, but now I'm nervous about changing cranks, since that would put the remaining threads to the test.
I never managed to strip b*cycle cranks/bottom brackets, but I guess the materials are different.
cjd is offline   Reply With Quote
Old 2003-06-20, 05:21 AM   #8
john_childs
Guinness Mojo
john_childs's Avatar
Re: Re: Re: Oh dear, oh dear oh dear oh dear.
Quote:
Most bike crank spindles have internal threads and a retaining bolt. While most unicycle hubs have external threads and a retaining nut. A unicycle hub with internal threads (like the QU-AX hub) would be less likely to have the threads strip.
I'll attach a picture (that I stole from Jagur) of the QU-AX hub with internal threads to show what I'm talking about.
__________________
john_childs (att) hotmail (dott) com
Team Never Wash Your Muni
My Gallery :: Unicycling Bookmark List :: World Clock
john_childs is offline   Reply With Quote
Old 2003-06-20, 05:33 AM   #9
jagur
My Uzi is a Tongue
jagur's Avatar
Kenny
if there is still a couple of threads left at the bottom that are still there,you may be able to beat or press the crank arm on with a wooden mallet/clamp just far enough to catch the last of the threads with the nut.
before i learned to beat them on every time then tighen the nut,i did just what you did.the threads on uni hubs seem weak and the chroming process makes them brittle.
__________________
theres enough BS in life, without mobius contributing.
Forget_Your_Life
-------MUNI MILITIA -------
One Wheeled Death Squad
twitter> @shot of jagur
jagur is offline   Reply With Quote
Old 2003-06-20, 05:37 AM   #10
Adrian
Experienced Faller Offer
Is there a good reason for this? The bike system of having internal threads seems more logical to me, maybe it's just because it's what I'm used to.
Edit: Of course, one of the advantages of internal threads is that you can't leave the nut attached whilst using a crank extracter
Adrian is offline   Reply With Quote
Old 2003-06-20, 06:15 AM   #11
john_childs
Guinness Mojo
Bike crank spindles used to be made with the external threads. It's an older design. Then the bikes switched over to the internal threads. My guess is that the unicycle hubs just haven't bothered to make the redesign yet. It may also be cheaper and easier to make unicycle hubs with the external threads. Since companies like Suzue already have the machining and tooling set up to make the external threads, why change?
I do hope that companies like Suzue change over to the internal threads for their unicycle hubs. It's a better design. Maybe one day...
__________________
Old 2003-06-20, 09:45 AM   #12
foolish
Cokerhead
foolish's Avatar
That one day is today! Cokers have internal threads. Yet another reason for its superiority over a 29er
__________________
"People are so very different...." - Too-Ticky
foolish is offline   Reply With Quote
Old 2003-06-20, 10:16 AM   #13
nb
one wheel short
nb's Avatar
But you can leave the washer in place once you have removed the bolt... I would have thought
nick
nb is offline   Reply With Quote
Old 2003-06-20, 04:46 PM   #14
jagur
My Uzi is a Tongue
jagur's Avatar
Quote:
only some of them,another reason for better resale value when selling it for a 29errrrrrrrrrr.
__________________
Forget_Your_Life
Old 2003-06-20, 06:07 PM   #15
harper
768 - It's in your DNA
harper's Avatar
I made the uni.5 axles with internal threads because I could tap them MUCH deeper than the external threads on an axle extend. This gives alot of pulling strength to that connection and, since the threads are internal, if the bolt is kept clean for installation it's likely to stay clean. I have three times the thread length contact with the internal threads as opposed to the unicycle standard external threads. Removing material from the end of the axle and replacing it with a bolt weakens that area somewhat.
I (probably erroneously) thought that it was a cheaper way to go also. Steve Howard told me that for production purposes it would be easier and cheaper to make the axles with external threads. I think bicycles went to internal threads to keep them from being constantly exposed even though the production process may be more costly.
__________________
-Greg Harper
Destroying the climate by shutting down nuclear power plants, one by one, since 1979.
JC is the only main man. There can be no other.
"A fool on a unicycle is redundant" - J.D. Miller
harper is offline   Reply With Quote
Reply
Tags
dear
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.12058 seconds with 10 queries
