Unicyclist Community
Reply
Old 2003-04-25, 06:45 PM   #1
daino149
On Vacation - till i find a job
daino149's Avatar
Send a message via AIM to daino149
Seatpost diameters
It seems that unicycle.com doesn't include too much information in their product descriptions. In particular I want to know what the seat post diameter is for each frame and the width of the frames (from bearing holder to bearing holder).
the frames I'm most interested in are:
1. Yuni/N2
seatpost ???
2. KH24
seat post 27.2mm
3. Black Torker
seat post 25.4mm
4. Chrome Torker
seat post ???
5. United
seatpost ???
Other questions I have are:
What diameter is the GB4 universal seatpost?
How well do shims work?
Does it matter if the distance between the bearings and the bearing holders are different?
Thanks for your help.
Daniel
__________________
OPPORTUNITYISNOWHERE
daino149 is offline   Reply With Quote
Old 2003-04-25, 07:04 PM   #2
motoxunimech
sensitive, kind.....whatever
Post Query
why not call or email them and ask them?
__________________
"Old enough to know better, young enough not to care" Smartmouth....
motoxunimech is offline   Reply With Quote
Old 2003-04-25, 07:14 PM   #3
teachndad
ONE for the...Off Road
teachndad's Avatar
Location: West San Fernando Valley, Southern California
Daniel,
I am pretty sure all of those use the 22.2 mm seat post size. I just got a Yuni and it took my miyata seat post just fine and it is 22.2mm.
I have a 3" custom machined shim on my Muni that has always worked well. But the shims from Uni.com aren't that long. As I recall they are only about 1.5 inches long. That was for a 22.2mm shimed to fit a 25.4 ID seat post tube.
__________________
Rod Wylie
teachndad is offline   Reply With Quote
Old 2003-04-25, 08:04 PM   #4
Krashin'Kenny
Crash Tested
Krashin'Kenny's Avatar
The Yuni, United and GB4 universal are all the standard 22.2
__________________
If you ain't crashing, you ain't going fast enough!!!!!!!!!!!
Krashin'Kenny is offline   Reply With Quote
Old 2003-04-25, 08:07 PM   #5
gbarnes
www.gb4mfg.com
gbarnes's Avatar
Send a message via AIM to gbarnes
Daino,
All of my (GB4) posts are 7/8" or 22.2 mm in diameter. These will fit the Yuni, Chrome Torker, and United unicycles.
A 1" or 25.4 mm post will be available this summer and will be compatible with the new Velo saddles. The current GB4 posts are not compatible without removing some fabric from the inside of the saddle, or grinding some material off the seat plate.
I personally am not a fan of shims, but I know they do work.
__________________
George C. Barnes IV
http://www.gb4mfg.com/
gbarnes is offline   Reply With Quote
Old 2003-06-05, 03:08 AM   #6
daino149
daino149's Avatar
FYI:
I just got my Summit 20. The seatpost on it is 27.2, but there is a shim in it. The frame is 29.4. I'm not sure if the KH uni's are the same... Are they?
Daniel
__________________
Old 2003-06-05, 05:05 AM   #7
john_childs
Guinness Mojo
john_childs's Avatar
Re: Seatpost diameters
Quote:
Shims can work just fine. But it does depend on the quality of the unicycle frame and the seatpost clamp. If the frame is prone to twisting seatposts without a shim it's not likely to improve when adding a shim.
I just put a GB4 seatpost on my DM Ringmaster Advanced (thanks George). The DM takes a 25.0mm seatpost so I needed to use a shim to fit the 22.2mm GB4 seatpost. I got the needed shim from unicycle.com. It's rock solid. The DM does have a double pinch bolt seatpost clamp which definitely helps.
My KH24 Pro and KH20 Pro both use a shim and the seatposts are rock solid. I'm using a Salsa Flip-Lock seatpost clamp which works very very well.
As long as the frame tightens up on the seatpost well and you're using a good seatpost clamp and you've got a good quality shim then using a shim shouldn't cause a problem. Beefy BMX seatpost clamps or Salsa seatpost clamps are a good thing.
__________________
john_childs (att) hotmail (dott) com
Team Never Wash Your Muni
My Gallery :: Unicycling Bookmark List :: World Clock
john_childs is offline   Reply With Quote
Old 2003-06-05, 05:38 AM   #8
Nathan Hoover
Newsgroup User
Posts: n/a
The KH Pros definitely use a shim to get down to 27.2. I thought the
diameter was over 30mm but I'd believe 29.4 I guess. I've never measured.
Shims work ok, but best would be not to use them. The KH36 seat tube is
exactly 25.4 and Hunter makes his seat tubes exactly 26.8 (although he can
make you any shim you need).
---Nathan
"daino149" <daino149.oj5zm@timelimit.unicyclist.com> wrote in message
news:daino149.oj5zm@timelimit.unicyclist.com...
> FYI:
> same... Are they?
> Daniel
Old 2003-06-05, 12:32 PM   #9
Dirtsurfer
One wheeled
Dirtsurfer's Avatar
Re: Re: Seatpost diameters
I picked up a KH24 pro and it has the 25.4 seatpost. Uni.com has a seatpost FAQ that lists all the sizes of each frame.
---Nathan
> FYI:
> same... Are they?
> Daniel
__________________
"All we have to decide is what to do with the time that is given to us." Gandalf the gray
Dirtsurfer is offline   Reply With Quote
Reply
Tags
diameters, seatpost
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.10290 seconds with 9 queries
