Unicyclist Community
Reply
Old 2003-02-06, 02:24 AM   #1
Scott Stephens
Equipment Destroyer
Scott Stephens's Avatar
Send a message via AIM to Scott Stephens
Kick Up Mount
Ive been working on the kickup mount lately, and im having some trouble. Every time I kick it up, I get the seat in the right place, and my foot is on the pedal, but the other foot always ends up on the ground. has anyone had this problem? Any tips?
Scott
__________________
If it weren't for electricity we'd all be watching television by candlelight."
George Gobol
I have worked too hard to be a clown. I am an athlete and wish to be respected as one.- Checkernuts
Scott Stephens is offline   Reply With Quote
Old 2003-02-06, 01:04 PM   #2
Sofa
you - pee - dee
Sofa's Avatar
Hate to be the one that says this, but...
Keep trying
__________________
Happy Life Day
Sofa is offline   Reply With Quote
Old 2003-02-06, 01:19 PM   #3
nb
one wheel short
nb's Avatar
Place the uni on the floor in the proper position and stand on it ready to mount. Now take two step backwards so you are behind it and below it. Walk towards the uni but carry on walking as if you are going to walk over it. The uni should kick-up into the right position. Try it and it should be a bit clearer.
The second tip is to go for it. If you go at it a bit half hearted you wont do it.
A thirdly........ practice.
nb is offline   Reply With Quote
Old 2003-02-06, 02:46 PM   #4
Max_Dingemans
Pedal Pedal Crash
Max_Dingemans's Avatar
Send a message via AIM to Max_Dingemans
tonight i'll take a couple of movies of one. that might help you.
__________________
There is nothing worse than a gross exaggeration.
Max_Dingemans is offline   Reply With Quote
Old 2003-02-06, 03:39 PM   #5
GILD
Waffle-Tosser, Time-bider and JCTK
GILD's Avatar
Location: the bustling metropolis of Nelspruitia, south africa
is your grounding foot touching the ground behind or in front of the uni?
u can see how the answer to this question will help u finetune your own mount
what helped me out of this self same slump was to aim my body diagonally forward heading in the direction of the wheel
that simply put me in a position to sit on the seat once aquired and find the pedal with my foot, having a momentary still stand
max's pics will be worth lots of words
the practise advice is also valid
GILD is offline   Reply With Quote
Old 2003-02-06, 05:57 PM   #6
johnfoss
North Shore ridin'
johnfoss's Avatar
Lay the unicycle on its side with the top pedal facing 90 degrees to the rear. Now draw an imaginary line from the top of your seat post, through the pedal, to a spot behind the bottom of the tire. This is approximately where you need your center of mass to be when you kick the unicycle up. Make sure you use enough "oomph" to get there, and aim for that spot.
Once you get there, since your pedals will be in the dead spot, push the top pedal 1/4 turn to the rear, and riding away should be a piece of cake. With practice.
__________________
John Foss
"jfoss" at "unicycling.com"
www.unicycling.com
"Unicycling is a way of looking at the world, making a choice to slow down, finish what you start, doing things not because they're easy, but because they're a challenge." -- Nurse Ben
johnfoss is offline   Reply With Quote
Old 2003-02-06, 07:00 PM   #7
daino149
On Vacation - till i find a job
daino149's Avatar
Send a message via AIM to daino149
After reading about several people learning to kickup I knew I had to learn. For the longest time I tried, but didn't seem to get anywhere with it. After watching Jeff Lutkus do it on one of his videos I realized I had been doing it all wrong. When I went back out to try, I nailed it on the second try. Moral of the story is... Videos help a lot more then words. Here’s the video I used to learn.
Quote:
http://lutkus.com/video/jeff/kickup_mount.avi
Good luck, and never give up.
Daniel
__________________
OPPORTUNITYISNOWHERE
daino149 is offline   Reply With Quote
Old 2003-02-07, 06:05 AM   #8
Unimoron
The only Genius is Norman Einstien
Unimoron's Avatar
Hei
This probably means that I have been cheating the kickup mount, I have doing them and when I do it the unicycle cranks are completly horizontal facing me, and the other one away from me. So this leaves the frame at an upward angle and the seat is up to my knee. Making the whole mount more manouverable. This way doesnt count does it?
Unimoron is offline   Reply With Quote
Old 2003-02-07, 02:40 PM   #9
Max_Dingemans
Pedal Pedal Crash
well I forgot to bring the camera last night... but Ill remeber this weekend.
__________________
Old 2003-02-07, 02:51 PM   #10
john_childs
Guinness Mojo
john_childs's Avatar
Re: Hei
Quote:
Yup. It's not a traditional kickup mount.
I don't know if your style of kickup mount would count as a unique mount for skill level testing or not? I think it would still be an interesting mount. I don't even know if your mount has a name.
__________________
john_childs (att) hotmail (dott) com
Team Never Wash Your Muni
My Gallery :: Unicycling Bookmark List :: World Clock
john_childs is offline   Reply With Quote
Old 2003-02-07, 03:10 PM   #11
GILD
GILD's Avatar
is it possible to get some video of this mount?
Old 2003-02-07, 03:12 PM   #12
Max_Dingemans
Pedal Pedal Crash
that's what I was planning on.
__________________
Old 2003-02-08, 03:21 AM   #13
unisteve
Yes?
unisteve's Avatar
Send a message via MSN to unisteve
kickup-ish mount
I have been learning a kickup-ish mount and it's really spectacular but I need to practice more to land it more often. I just learned it last night. I'm so excited. I can show off even more to the neighbourhood that knows little if anything about unicycling and then look really, really good. Hee hee.
I'm not sure if mine is correct either. I will try to explain what I do.
I keep the right pedal as high as it will go and the left one, as a result, goes to its lowest position. I then lay the unicycle on the ground on its right side. Keeping my left foot on the left pedal which is kind of sideways, and the seat just below my knee, I kick the seat up and sit on it and then ride away if I'm lucky.
That may sound weird, but it's another mount so I can be a level 3 rider unofficially....
I also wish to know if my technique is flawed. Thank you for any advice, tips, etc.
__________________
"...if a bunch of fellow unicyclists can't rally around, commiserate and say 'chin up, lad', then what is this world coming to?" -GILD
unisteve is offline   Reply With Quote
Old 2003-02-08, 04:10 AM   #14
Unimoron
Unimoron's Avatar
Hei
Quote:
Im actually pretty sure thats what i do for that mount. You just explained it better.
Old 2003-02-08, 06:11 AM   #15
Max_Dingemans
Pedal Pedal Crash
http://www.unicyclist.com/gallery/albuo09
Two vids up. if there not good enough, stuff it. I mean.... I can take more, really I can. *shifts eyes*
__________________
Reply
Tags
kick, mount
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.11633 seconds with 9 queries
