Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 |
Last of the Dogmato-Revisionists
Article on Kris Holm in The Independent (UK)
By Mark MacKenzie.
1,474 words 8 December 2002 Independent On Sunday 22 English (c) 2002 Independent Newspapers (UK) Limited. All rights reserved. This material may not be published, distributed or exploited in any way. You've heard of extreme ironing. Well, it's about time you got to grips with mountain unicycling. Mark MacKenzie catches up with Kris Holm, the For a journalist, directing readers to an internet website to demonstrate an unfamiliar sport because you are unable to do it justice in words is an admission of failure. However, if you do happen to be near a computer, I strongly recommend you download the video clip at the following address: www.unicycle.uk.com/shop/thunderdragon.htm. The minute-long footage highlights the extraordinary talents of Kris Holm, 29, a Canadian whose claim to sporting greatness is that he is the world's leading practitioner of the sport of mountain unicycling. I admit, until I'd seen Holm in action the concept of mountain unicycling or "muni" (pronounced mewni) seemed ridiculous. Clowns, after all, ride unicycles, which puts it on a par with the custard pie, the collapsing jalopy and size-26 shoes. But through a keen sense of adventure, Holm has turned what was once a circus gimmick into a hair-raising form of downhill biking, thrilling to watch, requiring extreme levels of fitness and technique. It's a sport that he has taken to such dramatic locations as the mountain passes of Bhutan and the volcanic peaks of Mexico. "Despite what people think," says the Vancouver student, "I've no experience of conventional mountain biking." Holm has lived by the "one wheel good, two wheels bad" mantra since he got his first unicycle on his 12th birthday. "It took me about a day to master the basics and staying upright was pretty much a leap of faith. Once I'd cycled to the end of my driveway, I moved on to riding across the ditch in my back yard, then to riding along logs. As I had no outside influences, I had no idea of the limitations of riding a unicycle." Locating muni's precise origins is difficult, which is surprising considering that the navigation of treacherous mountain trails on a single wheel is practised by only a handful of enthusiasts worldwide. Holm credits the invention of the sport to a fellow Canadian, George Peck, the designer of the world's first custom mountain unicycle - one with a titanium axle - in the early 1990s. "Because the type of riding I do is very demanding on the bike, the equipment needs to be strong," explains Holm. "Unlike a conventional bike, a unicycle's fixed gear means the wheel takes much more punishment than the frame and all the pressure is on the axle." Holm insists that riding on one wheel is safer than riding a conventional bike. "The speed is no faster than you can run and if you fall off, you just fall on to your feet, rather than handlebars." This argument looks less convincing if those feet happen to land inches from the edge of a cliff. Filming a unicycling video two years ago, Holm found himself pedalling along the edge of Canada's Stawamus Chief, at 600 metres, the second highest granite monolith in the world. "Cycling the Chief looked outrageous," Holm says "but wasn't that hard technically; it's more a test of nerve than ability. The challenge wasn't the cycling but concentrating with that huge drop in my peripheral vision. I've been in a number of situations where if I screw up, it'll be the last time I do. I know I have the technique, the trick is to apply that technique in a bubble." Holm refers to this as his "focus issue". "In life you have to concentrate on a million different things at once but when I'm riding, everything else disappears. I love a sport where I absolutely have to concentrate on one thing and if I don't, I'm not going to make it." Such Zen-like calm was precisely what was required one sunny day last year when Holm tested his "focus" by cycling along the handrail of the Burrard Street bridge in downtown Vancouver. Riding 120 feet above the water on a rail six-inches wide, Holm's three-inch wide tyre meant he had little room for error. "Before I got up there I looked at what could go wrong but when I rode, the only thing I thought about was getting to the other side." Cycling a handrail may seem more David Blaine than Jason Queally; but when Holm sets his pedals at the top of the various mountains which give muni its name what follows is revolutionary. Holm undertook a descent last year of the Mexican volcano El Pico de Orizaba, at 5,666m the third highest peak in North America. Setting off from the summit at 4.30am to beat the mid-morning clouds which encircle the mountain top, Holm and fellow muni daredevil Nathan Hoover began a four-hour epic ride to a base camp at 4,545 metres. "As the terrain was slippery, I was descending through a combination of rolling and sliding which meant I didn't have much control. It's easy to do something wrong that can throw you off, and normally you don't last more than 30 metres," Holm explains. "On rough ground, I hardly sit on the seat at all, although it looks like I do. Because the bike has a fixed gear, braking is about resistance in the legs but this is difficult when the pedals aren't level. My bike has a handle on the front of the seat which stops the seat shooting out from under me - it also houses the lever for a rim brake attached to the wheel. If you brake too much you'll fall, so you have to constantly judge the `friction limit'. In this case, everything went right and I had the ride of my life; 300 metres down the side of the mountain with my legs pumping furiously." Holm explains that, although leg strength is important in muni, the difference between the ultimate muni ride and a mouthful of dirt is good core strength in the abdominals and lower back. "Eventually, you get to the point where the bike becomes your lower half, just this thing underneath your feet and reactions become automatic." Holm completed a unicycle descent last month of the the Guatemalan volcano Tajumulco, the highest mountain in Central America and a 4,220m monster he describes as "lots of fun". All of which brings us back to that video clip, a series of high-speed out-takes from Holm's latest adventure, a 12-day unicycling trek across the ancient Rodang Pass in Bhutan he made with Hoover earlier this year. "Nobody has ever written a guide book on unicycling and so you never know what you're going to get," Holm says. "Bhutan is a country that didn't get the wheel until the mid-20th century, it just wasn't part of the culture. If something needed to be transported it went on the back of a yak. "The ride along the main pass, the Rodang La, was physically demanding as it's about 3,000 vertical metres from the the valley floor to the pass summit and the trails are steep. Some sections were too steep to ride up so we had to hike. We had packs designed for snowboards and just clipped our unicycles to them. To cover this sort of terrain on a conventional mountain bike you'd need a 35-40lb machine compared to a 15lb unicycle. It was quite satisfying because, in terms of design, the unicycle came into its own." "On the descent side of the pass, there were over 1,000m of stairs cut into the mountains," Holm says. This terrain was made more complicated by daily thunder storms. Making life more difficult still were the demands of filming for Into the Thunder Dragon. Bhutan is known as Land of the Thunder Dragon, a reference to the prominence of dragons in Bhutanese mythology and a fact not lost on Holm. "Riding a route travelled by traders and religious figures for over 1,000 years - The Rodang pass lies on the Silk Road - was amazing," he says, "and learning about Bhutanese culture through unicycling is fairly unique. "The local children were incredible; we'd ride through a village and the whole school would turn out to see this incredible new toy. Outside the major cities, you don't even see conventional bikes because the terrain is so difficult. I got asked numerous times if this was something everybody did back home..." To purchase Kris Holm's `Into the Thunder Dragon' visit www.unicycle.uk.com. Video £19.95, DVD £24.95. Next week: Britain's greatest living mountaineer, Sir Chris Bonington.
__________________
Raphael Lasar To plotz is human, to schvitz divine. |
#2 | |
Guinness Mojo
Re: Article on Kris Holm in The Independent (UK)
Quote:
![]() Thanks for finding and posting the article. Do you spend all of your free time at the library doing searches for "unicycle"?
__________________
john_childs (att) hotmail (dott) com Team Never Wash Your Muni My Gallery :: Unicycling Bookmark List :: World Clock |
#3 |
768 - It's in your DNA
Cool article, even with the bike mix-ups and clown references. Thanks, Raphael.
__________________
-Greg Harper Destroying the climate by shutting down nuclear power plants, one by one, since 1979. JC is the only main man. There can be no other. "A fool on a unicycle is redundant" - J.D. Miller |
#4 | |
Re: Re: Article on Kris Holm in The Independent (UK)
Quote:
![]() Well, actually since I work for a corporate library I have free access to news databases. Every now and then I do take it into my head to throw "unicycle" or "unicyclist" or "unicycling" in to see what comes up. Today I just hit the jackpot. I have, of late, been spending a bit of my real free time at the library doing research on the subject. I've been trying to locate information on yoopers recent photo acquisition. I've also been reading up on the relation between unicycling and clowning; one of these days I'll post my vaguely substantiated opinion/findings. Cheers, Raphael Lasar Matawan, NJ
__________________
#5 | |
My Uzi is a Tongue
Quote:
__________________
theres enough BS in life, without mobius contributing. Forget_Your_Life -------------------------------------- -------MUNI MILITIA ------- One Wheeled Death Squad twitter> @shot of jagur |
#6 |
Newsgroup User
Posts: n/a
In article <john_childs.fkdmb@timelimit.unicyclist.com>,
john_childs <john_childs.fkdmb@timelimit.unicyclist.com> writes: > > Since when did Canada claim Alaska! ![]() > 1872-1903 timeframe. http://www.ac.wwu.edu/~jay/pages/dan.html ============================================================ Gardner Buchanan <gbuchana@rogers.com> Ottawa, ON FreeBSD: Where you want to go. Today. |
#7 | |
Guinness Mojo
Quote:
![]() But in this case it looks like Canada claimed all of Alaska and it's citizens. George Peck is from Alaska.
__________________
#8 | |
Level 3
Quote:
Hmmm... you might get in trouble if you aren't careful.
__________________
One wheel drive! |
#9 | |
Quote:
Hmmm, a trip to England? I haven't been there in over 10 years. Perhaps I'll turn myself in. Raphael Lasar Matawan, NJ
__________________
#10 |
Kris in the UK - Couple of Articles
Just riding high with one-wheel wonder Kris.
By Ross Smith. 254 words 24 April 2003 Evening Gazette 3 English (c) 2003 Gazette Media Company Ltd. All Rights Reserved. Where there's a wheel, there's a way. No place is out of bounds to daredevil unicyclist Kris Holm in his quest to ride in the most unusual spots. So Kris seized the chance to pedal his way across the Transporter Bridge's walkway during his first trip to Britain. And a brave band of Teesside one-wheelers followed the Canadian across, including 12-year-old John Tasker. It was John's dad, Paul, a Middlesbrough Council worker, who helped to set up the stunt, after fellow Teesside unicyclist Roger Davies persuaded world champion Kris to visit the area. John, from Norton, said: "My dad managed to pull a few strings, so I came along with my 'uni' and got the chance to ride, which is cool. The height, and the fact you can see everything underneath you, makes it different to normal. "I felt on top of the world, to be riding up there and to ride with Kris Holm." Kris, 29, said: "It's always amazing to ride in unusual and interesting areas. I've never even heard of a Transporter Bridge before, so when the opportunity came up to ride on this one, you have to jump at it. "The technical difficulty of it was not high, but it's a beautiful place to ride, and in some ways for me that's just as important." His next challenge is a 24-hour cross-country endurance race in California. ============================================== No bridge too far for the unicyclist who's looking for challenges 252 words 24 April 2003 Newsquest Media Group Newspapers: This is the North East English c Copyright 2003 Newsquest Digital Media. FOR some people, being at the top of Teesside's Transporter Bridge would be enough to turn the stomach - even if you were standing still. But adrenaline junkie Kris Holm yesterday rode along the bridge on a unicycle. He described the 225ft-high landmark as an "urban obstacle". "It was really good fun because it is such a spectacular bridge with great views," said Mr Holm, 29, of Vancouver, Canada. "I have done things like this before, and you get used to it. Actually, I enjoy riding while having so much air beneath me." Mr Holm is known to adventure sports fans everywhere and is renowned as being the best mountain unicyclist in the world. "It is a lot more technical than regular biking, and you have to go a lot slower," he added. "But people see it as a pretty cool thing to do because extreme sports are so hot at the moment." He spends most of his time touring the world looking for more death-defying challenges to undertake. Fans of Mr Holm's exploits can buy the footage on videos and DVDs. Despite the dangerous positions he has been in, the worst injury he has sustained is a sprained ankle and a few bruises. Mr Holm did the Transport Bridge stunt while visiting his friend, Roger Davies, who is the country's biggest supplier of the one-wheeled bikes and works from offices in Billingham, Teesside. ============================================== Below, I believe, is the bridge in the articles. Here's a webcam of the bridge: http://www.bbc.co.uk/tees/webcams/transporter.shtml Raphael Lasar Matawan, NJ
__________________
#11 |
Kris in the UK - Couple of articles
__________________
#12 |
Newsgroup User
Posts: n/a
We actually got 3 newspaper articles.
2 radio spots 6 regional TV spots All from Paul Tasker sorting out for Kris to ride over the bridge. It took only half an hour of phone calls to sort the press. It was fun on the top, 5 of us rode along in the end Roger ----- Original Message ----- From: "JJuggle" <JJuggle.mnx5n@timelimit.unicyclist.com> Newsgroups: rec.sport.unicycling To: <rsu@unicycling.org> Sent: Tuesday, April 29, 2003 8:39 PM Subject: Re: Article on Kris Holm in The Independent (UK) > > JUST RIDING HIGH WITH ONE-WHEEL WONDER KRIS. > > By Ross Smith. > 254 words > 24 April 2003 > Evening Gazette > 3 > English > (c) 2003 Gazette Media Company Ltd. All Rights Reserved. > > Where there's a wheel, there's a way. > > No place is out of bounds to daredevil unicyclist Kris Holm in his quest > to ride in the most unusual spots. > > So Kris seized the chance to pedal his way across the Transporter > Bridge's walkway during his first trip to Britain. And a brave band of > Teesside one-wheelers followed the Canadian across, including > 12-year-old John Tasker. > > It was John's dad, Paul, a Middlesbrough Council worker, who helped to > set up the stunt, after fellow Teesside unicyclist Roger Davies > persuaded world champion Kris to visit the area. > > John, from Norton, said: "My dad managed to pull a few strings, so I > came along with my 'uni' and got the chance to ride, which is cool. The > height, and the fact you can see everything underneath you, makes it > different to normal. > > "I felt on top of the world, to be riding up there and to ride with Kris > Holm." > > Kris, 29, said: "It's always amazing to ride in unusual and interesting > areas. I've never even heard of a Transporter Bridge before, so when the > opportunity came up to ride on this one, you have to jump at it. > > "The technical difficulty of it was not high, but it's a beautiful place > to ride, and in some ways for me that's just as important." > > His next challenge is a 24-hour cross-country endurance race in > California. > > ============================================== > > > NO BRIDGE TOO FAR FOR THE UNICYCLIST WHO'S LOOKING FOR CHALLENGES > > 252 words > 24 April 2003 > Newsquest Media Group Newspapers: This is the North East > English > c Copyright 2003 Newsquest Digital Media. > > FOR some people, being at the top of Teesside's Transporter Bridge would > be enough to turn the stomach - even if you were standing still. > > But adrenaline junkie Kris Holm yesterday rode along the bridge on a > unicycle. > > He described the 225ft-high landmark as an "urban obstacle". > > "It was really good fun because it is such a spectacular bridge with > great views," said Mr Holm, 29, of Vancouver, Canada. > > "I have done things like this before, and you get used to it. Actually, > I enjoy riding while having so much air beneath me." > > Mr Holm is known to adventure sports fans everywhere and is renowned as > being the best mountain unicyclist in the world. > > "It is a lot more technical than regular biking, and you have to go a > lot slower," he added. > > "But people see it as a pretty cool thing to do because extreme sports > are so hot at the moment." > > He spends most of his time touring the world looking for more > death-defying challenges to undertake. > > Fans of Mr Holm's exploits can buy the footage on videos and DVDs. > > Despite the dangerous positions he has been in, the worst injury he has > sustained is a sprained ankle and a few bruises. > > Mr Holm did the Transport Bridge stunt while visiting his friend, Roger > Davies, who is the country's biggest supplier of the one-wheeled bikes > and works from offices in Billingham, Teesside. > > ============================================== > > Below, I believe, is the bridge in the articles. Here's a webcam of the > bridge: > > http://www.bbc.co.uk/tees/webcams/transporter.shtml > > Raphael Lasar > Matawan, NJ > > > +----------------------------------------------------------------+ > | Attachment filename: tees.jpg | > |Download attachment: http://www.unicyclist.com/attachment/137983| > +----------------------------------------------------------------+ > > -- > JJuggle - Last of the Dogmato-Revisionists > > My mind is like swiss cheese. - Sukhreet Gabel describing her own mental > state and memory while testifying on behalf of her mother, Hortense > Gabel, a judge accused of favoring Bess Myerson, former Miss America, in > her divorce proceedings. > > 5TH ANNUAL LBI UNITHON > Long Beach Island, New Jersey > Saturday, May 31, 2003 > http://jjuggle.unicyclist.com/lbiunithon > ------------------------------------------------------------------------ > JJuggle's Profile: http://www.unicyclist.com/profile/24 > View this thread: http://www.unicyclist.com/thread/22144 > > ________________________________________________________________________ ___ > rec.sport.unicycling mailing list - www.unicycling.org/mailman/listinfo/rsu > |
#13 |
The Social Unicyclist
Hey guys.
I have on of the articals.... Its an awsome pic! You may want to click on the image again (to get it full sized) to read the text. CLICK HERE Hope you guys (and girls) like it Joe,
__________________
VoodooUnicycles.Com - Extreme Unicycle Display Team Last edited by joe; 2003-04-30 at 04:44 PM. |
#14 |
dreaming of idling...
Surprised to see Kris's frequent use of the "B word" - or was this a case of misquotation?
__________________
Trevor. Still going forwards... |
#15 | |
Kris Holm
Quote:
-Kris. |
| Tags |
| article, holm, independent, kris |
