Unicyclist Community
Reply
Old 2002-09-16, 04:45 AM   #1
teachndad
ONE for the...Off Road
teachndad's Avatar
Location: West San Fernando Valley, Southern California
MOnty cranks vs. Black Widow ?'s
Does anyone know which of the below cranks goes out farther from the wheel plain?
Monty 158mm or Black Widow 160mm cranks?
I wear active ankles and am worried about clacking the brace on the crank arm or scraping the part of the shoe that wraps around the brace on the inside between the brace and the crank arm.
Thanks.
__________________
Rod Wylie
teachndad is offline   Reply With Quote
Old 2002-09-16, 08:11 PM   #2
dustin
Type something clever here.
dustin's Avatar
Re: MOnty cranks vs. Black Widow ?'s
Thanks.
I've only dealt with 140mm Monty's and 150mm Black Widow's, but based on that I would have to say that the Monty's will rake out just a little more than the BW's. Also, the edges on Monty's are rounded which will let Active Ankles or body parts slide off more easily without catching and causing a blood letting.
I also think the Monty's are stronger, but you have to make sure they are pressed on the axel real good.
Ride On!
__________________
dustin kelm isa40:30.31
"You are only limited by your imagination."
dustin is offline   Reply With Quote
Old 2002-09-16, 09:46 PM   #3
john_childs
Guinness Mojo
john_childs's Avatar
Re: Re: MOnty cranks vs. Black Widow ?'s
Quote:
Ride On!
The Montys are going to be stronger. The Black Widows are good for XC muni and Cokering, but I wouldn't do drops with them.
I used the Black Widows on my Pashely back in the old days when I was using a 2.1" XC tire and doing XC style riding with no freeride stuff mixed in. Never had any problems with the Black Widow cranks, but I wasn't doing any jumps and drops at that time.
The Black Widows are very straight. You can get unicycle.com to confirm, but I would be very surprised if the Montys didn't have more rake.
__________________
john_childs (att) hotmail (dott) com
Team Never Wash Your Muni
My Gallery :: Unicycling Bookmark List :: World Clock
john_childs is offline   Reply With Quote
Old 2002-10-10, 01:01 PM   #4
willfcc
I always wear my helmet.
willfcc's Avatar
Does anyone know anything about these Technique Crank Arms? They look massive, and come in sizes from 145 to 176mm, for square spindle axles.
Go to www.danscomp.com
Click on Bike Parts, then Cranks, and scroll down the list to Technique Aluminum Arms
__________________
Will
willfcc is offline   Reply With Quote
Old 2002-10-10, 03:39 PM   #5
picpost
Registered User
Your Back Dustin!
picpost is offline   Reply With Quote
Old 2002-10-10, 06:22 PM   #6
john_childs
Guinness Mojo
Ask Dan Heaton. I believe he tried them and found that they didn't hold up.
__________________
Reply
Tags
black, cranks, monty, widow
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.07456 seconds with 9 queries
