Unicyclist Community
Reply
Thread Tools Search this Thread Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 2002-09-16, 04:40 AM   #1
teachndad
ONE for the...Off Road
teachndad's Avatar
Location: West San Fernando Valley, Southern California
Calculating crank to diameter ratio ?'s
Hi,
When calculating the ratio of cranks to diameter, should I be trying to reach a ratio of 4.0?
For example: a crank ratio of 3.9037 would give me more torque than a ratio of 3.859?
Or do I have this concept reversed?
Can anyone detect this close a difference in torque in real world riding based on using the above numbers?
I calculated the diameter from the circumference of the tire using pi.
I then converted the diameter to mm and divided by crank length.
For example Using 160mm cranks and a diameter of 616.08mm
I divided 616.08 by 160 to get my ratio of 3.855.
Did I do this correctly?
If I did this correctly, a 24 x 2.6 Gazz with 160mm cranks is nearly the same as a 24 x 3.0 gazz with 170mm cranks. The difference is 4 thousandths. Gazz 24 x 3.0 is calculated as 656.08mm/170mm which equals 3.859.
Thanks
__________________
Rod
scottw818.wixsite.com/vintage-rod-and-reel
teachndad is offline   Reply With Quote
Old 2002-09-16, 10:08 PM   #2
Klaas Bil
Newsgroup User
Posts: n/a
Re: Calculating crank to diameter ratio ?'s
On Sun, 15 Sep 2002 23:40:35 -0500, teachndad
To begin with: why 4.0?
Secondly, you are talking about "the ratio of cranks to diameter" as
if it is a fixed notion, but is it? If not, I would rather use a
"crank to diameter" ratio.
>ratio of 3.859?
The way you express it, it would be the other way around. While you
call your number a "ratio of cranks to diameter", what you actually
calculated is the ratio of diameter to cranks.
It is barely 1%. I doubt if it would make a noticeable difference.
Yes, with the above proviso.
For your example, I would proceed as follows:
The radius of the wheel is 313.04 mm (half of the diameter). The
radius of the crank (a.k.a. crank length) is 160 mm. The crank to
diameter ratio then is 160/313.04, which equals 0.5111. That is sort
of a leverage factor, meaning that if you push with force x on the
pedal (perpendicular to the crank), then the force at the ground
contact point will be 0.5111 times x. So you would have more torque
(e.g. for climbing) if your crank to diameter ratio is higher
(assuming that you could still muster force x on the pedal).
Obviously, you can't go higher than a ratio of 1, or your pedals would
protrude beyond the tyre. Bonk bonk bonk bonk. Indeed, they would bonk
already below 1.
Hope this helps,
Klaas Bil
If you had this signature, I have forged it.
Old 2002-09-17, 01:28 AM   #3
Jason Neumann
Newsgroup User
Posts: n/a
> Hope this helps,
Isn't this mostly academic?
Example:
I want to buy a 24" MUni and I want enough torque to make it up hills
with a minimal amount of effort. However, I don't want the cranks so
long that my overall ride becomes jerky. I have asked myself, do I want
170 mm or 175 mm cranks? It seems to me that an important factor not
included in the equation is the size of the rider. If I were 6'-6" tall
with rather long legs then the ride would feel very different on 175 mm
cranks than with my shorter stature of 5'-10" tall. Until I actually
ride on the different cranks I won't know anything other than the amount
of force represented by x, which doesn't really help or does it?
Jason
Old 2002-09-17, 07:01 PM   #4
Mikefule
Roland Hope School of Unicycling
Mikefule's Avatar
It's dead simple if you think of the cranks in inches - you think of the wheel in inches after all.
Roughly:
100 mm = 4 inches.
125mm = 5 inches
150 mm = 6 inches
170 mm is a shade under 7 inches.
Then it's the radius of the wheel which matters, not the diameter, so simplify the calculation here too - the lever acts through the hub.
So, on a 20 inch wheel (10 inch radius) with 125 cranks (5 inches) you can express the leverage as 50% (If you prefer: 1:2)
On a 24 inch wheel (12 inch radius) with 6 inch cranks, the leverage is also 50%
This suggests the two set ups offer similar leverage - although there are many other factors which come into play.
On a Coker with a 36 inch wheel (18 inch radius) and standard 6 inch cranks, the ratio is 33% or 1:3.
Keep it simple.... count the cranks in inches.
I found my Coker with 6 inch cranks would go up some hills my 20 wouldn't go up with 5s on it. I found my 26 with 7 inch cranks (53%) would not go up stuff that my 24 with 6s (50%) would.
So, the ratio is a guide only, and the actual wheel size and actual crank size have an effect due to rolling resistance, momentum, angle of attack on obstacles, and ergonomics.
Mikefule is offline   Reply With Quote
Old 2002-09-17, 10:48 PM   #5
Klaas Bil
Newsgroup User
Posts: n/a
I agree that other factors than just leverage play a role as per
Mikefule's last sentence. He also simplifies the calculations by using
round inch numbers but the principle remains the same. And no, it's
not academic. When I went from 24" with 125 mm cranks to 20" with 125
mm cranks, I noticed a definite improvement for uphilling. I mounted
150 mm cranks on my 24" wheel and hey presto, an improvement just as
big (compared to 125 mm). And guess what, the leverage factor is
(nominally) exactly the same.
Klaas Bil
On Mon, 16 Sep 2002 16:32:11 -0800, Jason Neumann
>Example:
>Jason
Old 2002-09-17, 10:48 PM   #6
Klaas Bil
Newsgroup User
Posts: n/a
On Tue, 17 Sep 2002 14:01:14 -0500, Mikefule
For the second example, OK that's a small difference in leverage
factor. Maybe also the 26" was a wider and hence larger tyre than the
nominal value? But the Coker example is remarkable, unless either
these were real short hills and you could use the greater speed
achievable with the Coker to carry you over the top, or the surface
was so bumpy that the small wheel got stuck.
Klaas Bil
Old 2002-09-18, 05:03 AM   #7
Jason
Newsgroup User
Posts: n/a
Yes. After reading Mikefuls post I find this information much more
useful, expressing it in relative percentages such as, "50% (If you
prefer: 1:2)".
Thanks guys!
Jason
Old 2003-09-27, 09:18 PM   #8
joona
)-O <--Neat
joona's Avatar
Send a message via AIM to joona
There is still one more thing to here. Remember to measure the diameter of the tyre. For example, my 20" trainer has wheel diameter of 20" but my Gazza 24" has diameter of 26". This 24-26 diameter only affects 5%, but I think you may feel it.
__________________
You are my friend...
165 lbs. I'm not going to stop eating yet... I'll be a big boy soon
joona is offline   Reply With Quote
Old 2003-09-27, 11:59 PM   #9
Chuck Webb
Unicyclist
I can't seem to find it on his site right now, but quite a while back i downloaded a cranklength spreadsheet from Roger Davis...still use it a lot, it lets you plug in wheel diameter or circumference and crank length and come up with ratio and lots of other interesting stuff.
Chuck
Chuck Webb is offline   Reply With Quote
Old 2003-09-28, 01:15 AM   #10
duaner
Send a message via ICQ to duaner Send a message via AIM to duaner
Quote:
Yep, the gaz 24x3 is about 26" (radius 13"), however, it's typically run at such a low pressure, that I wonder if the effective radius (distance from center of hub to point of nearest contact) isn't closer to 12.5" or even 12" - implying an effective 25" or 24" diameter.
Just something to think about.
.duaner.
duaner is offline   Reply With Quote
Old 2003-09-28, 03:00 AM   #11
ubersquish
Unicyclist
Send a message via AIM to ubersquish
actually, all that stuff is wrong. the center of rotation for rolling objects (wheels) is not the hub. it's where the wheel touches the ground. so to you use the wheel radius plus the crank length instead of just the crank length. and no, i didn't think of this on my own or make it up
ubersquish is offline   Reply With Quote
Old 2003-09-28, 11:00 AM   #12
rogeratunicycledotcom
Mostly OKish Unicyclist
Quote:
Try www.unicycle.uk.com/Cranklength.xls I think
rogeratunicycledotcom is offline   Reply With Quote
Old 2003-09-28, 02:40 PM   #13
ubersquish
Unicyclist
um, whoops. that shouldn't be wheel radius + crank length. that should be distance of the pedal from the wheel's contact point, which is wheel radius + crank length only when the crank is pointing up
Old 2003-09-28, 09:21 PM   #14
joemarshall
dumb blonde
Quote:
I didn't believe that, but thinking about it I think it's true and it's obvious that this is a different number and doesn't average out to the same thing.
Why:-
When the pedals are at 9 o'clock, 12 o'clock and 3 o'clock, the distance between the point where force is being applied and the contact patch is greater than the wheel radius. It's only in a small section of the pedal circle that the pedals are less than the wheel radius away from the ground and that doesn't come near to balancing out the time spent in the other parts of the pedal circle.
Being currently a programmer and having forgotten my maths, I wrote a little program to work it out, for a 18 inch radius wheel (coker sized) with 18 inch cranks the effective radius is 22.9 inches, going down to 18.5 inches for 6 inch cranks and tending towards 18 inches as crank length goes to zero.
It doesn't matter really though as it doesn't make much difference to the calculations anyway, even in the most extreme practical cases (eg. 6 inch cranks on 20 inch wheel = effective radius of about 22 inches).
I'm not sure what happens on a bike, although the small size of rear sprockets might mean it's only a very tiny amount of constant difference in gearing due to the drive being from slightly behind the axle.
Joe
joemarshall is offline   Reply With Quote
Old 2003-09-29, 09:46 PM   #15
Klaas Bil
Newsgroup User
Posts: n/a
On Sat, 27 Sep 2003 22:00:43 -0500, ubersquish
>[if the pedal is at 12 o'clock]
That only holds in a reference frame fixed to the road. So it only
applies to someone standing (or walking) on the road. Indeed, if you
stand beside a unicycle and want to propel it forward, pushing against
the top pedal gives you most leverage, equal to wheel radius plus
crank length.
However, if you think about a unicyclist riding a unicycle, then you
have to consider rotation in a reference frame fixed to the unicycle.
Then the centre of rotation is at the hub, and the usual notions about
leverage apply.
Klaas Bil - Newsgroup Addict
If the crank is moving then it really sounds as if it's loose. - onewheeldave trying to pinpoint the cause of a clicking crank
Reply
Tags
calculating, crank, diameter, ratio
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright © 2001-2016 Gilby
You Rated this Thread:
Page generated in 0.09710 seconds with 8 queries
