Unicyclist Community
Reply
Old 2002-08-14, 11:52 PM   #1
Sofa
you - pee - dee
Sofa's Avatar
Cheapest MUni frame w/real seat post?
Well, I just bent my 3rd 22mm seat post. What's the cheapest MUni frame I can get that holds a real mountain bike seatpost?
At least they're only $15can...time to give Bedford a call!
Sofa is offline   Reply With Quote
Old 2002-08-15, 01:09 AM   #2
john_childs
Guinness Mojo
john_childs's Avatar
What about using a 7/8" BMX seatpost? A post like the Primo Rod would work. Granted the 7/8" BMX posts are chromoly and heavy, but they won't bend. It would be nice to have a strong high quality alloy 7/8" seatpost, but I haven't found any. All the 7/8" posts are steel and heavy.
I'm using a Primo Rod on my Coker. The Primo post uses steel seat guts (the pieces that clamp on the seat rails). You can upgrade the seat guts to alloy guts to save a little weight. You can also cut the seatpost shorter to save a little weight. In order to use a bike seatpost you'll also need to get a rail bracket for your seat. Dans Comp <http://www.danscomp.com/> carries both the Primo seatpost and the XS alloy seat guts.
Another option is to get a custom seatpost made. Max Dingeman's dad has made some reinforced Miyata style seatposts with beefed up steel. If his posts can survive Max's use then they must be strong. I'd also give unicycle.com a ring to see if they have any stronger Miyata style seatposts in the works. Stronger and longer Miyata posts are needed and they need to be easy to order rather than custom jobs.
john_childs
__________________
john_childs (att) hotmail (dott) com
Team Never Wash Your Muni
My Gallery :: Unicycling Bookmark List :: World Clock
john_childs is offline   Reply With Quote
Old 2002-08-15, 01:20 AM   #3
Gilby
Unicyclist.com Webmaster
Gilby's Avatar
Quote:
The Dingemans use a wooden dowel inserted into the seat post to reinforce them. You may want to try that.
Gilby is offline   Reply With Quote
Old 2002-08-15, 02:06 AM   #4
jagur
My Uzi is a Tongue
jagur's Avatar
Re:
Quote:
that would be mine, Profile fork for $50 bucks.its the last piece of my muni carcass that i have not sold.
__________________
theres enough BS in life, without mobius contributing.
Forget_Your_Life
-------MUNI MILITIA -------
One Wheeled Death Squad
twitter> @shot of jagur
jagur is offline   Reply With Quote
Old 2002-08-15, 02:22 AM   #5
Sofa
you - pee - dee
Sofa's Avatar
I break posts not hubs. A $50 frame is no good to me without a $1000 hub (I figure you need the profile hub...therefore cranks to operate this?) I'm suprised Profile doesn't make a splined pedal that only fits on profile cranks. They could let them go for $500 a piece. Spare pins would only be $100 each!
prices are mildly exagerated.
Thanks, but no thanks
Old 2002-08-15, 02:37 AM   #6
Unicyco
Snoball II
Unicyco's Avatar
Quote:
Our posts also are made from thick wall chromoly. That helps a bit.
__________________
Max "The Maniac" Dingemans
"Mmmm.....Soylent Green!"
Unicyco is offline   Reply With Quote
Old 2002-08-15, 03:46 AM   #7
jagur
My Uzi is a Tongue
jagur's Avatar
nope just the right size berings.i had planed on putting a Sem deluxe hub on it and having a cheap muni.you sound angry.sorry i interupted your angst.
__________________
Forget_Your_Life
Old 2002-08-15, 11:09 AM   #8
AccordNSX
Adam Coast Choppers
Send a message via AIM to AccordNSX
Did Sofa get teased as a kid by everyone with Profiles? There seems to be great anger towards Profile.
AccordNSX is offline   Reply With Quote
Old 2002-08-15, 11:16 AM   #9
Sofa
you - pee - dee
Sofa's Avatar
Time to step in and defend myself.
I was figuring that they took the profile hubs. As this is a pretty close community, I figured people would remember my last post on the profile hub. (too much $) This was an extension of that.
Don't get me wrong, I'm sure when I have the money and there's nothing left to buy, I'll get one. Until then, they're too overpriced.
I'm not really an angry person, just grumbly
Old 2002-08-15, 11:19 AM   #10
Sofa
you - pee - dee
Sofa's Avatar
I meant, I have one, but they'll still be too overpriced
Old 2002-08-15, 11:43 AM   #11
AccordNSX
Adam Coast Choppers
Open your own bike shop, then you can get them for $225.
Old 2002-08-15, 11:56 AM   #12
phil
Average wheels: 1.5
phil's Avatar
How do you break a seatpost? I wouldn't have thought there would be much force on them other than at the top where it joins the seat. Do you have Thighs Of Steel (TM) or something? I'm intrigued...
Phil, just me
__________________
"Cattle Prods solve most of life's little problems."
phil is offline   Reply With Quote
Old 2002-08-15, 02:00 PM   #13
Sofa
you - pee - dee
Sofa's Avatar
I bend seatposts, I didn't mean break them.
Note...this is a cheap frame post (but thanks for the alternate seatposts, i had no idea), not a Profile is a ripoff post, please respond accordingly
Old 2002-08-16, 12:33 AM   #14
Unicyco
Snoball II
Unicyco's Avatar
Quote:
Is this directly from profile? or a wholesaler? if so, which one? It's not in any of the whole salers that my shop deals with.
__________________
Old 2002-08-16, 02:42 AM   #15
AccordNSX
Adam Coast Choppers
Quote:
Profile direct.
Reply
Tags
cheapest, frame, muni, post, seat, w or real
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.08685 seconds with 9 queries
