Unicyclist Community
Go Back   Unicyclist Community > Unicycling Discussion > Unicycle Product Reviews
Reply
Old 2017-02-15, 02:47 PM   #16
caseytronic
Unicyclist
caseytronic's Avatar
I used my Magura HS11 brakset and measured:
~30mm between the mounting bolt and the brake pad at max extension + 27mm Rhyno Lite rim width + ~30mm (other pad to bolt) = 87mm (maybe 90mm) max width between your Magura mounting bolts for this rim to work on your frame.
It would be easy enough to test for yourself - just mount up your maggie brakes, adjust them to max inward position/reach, and measure the gap between them.
I sold my drak frame so I couldn't measure the mount width on it, but the unis I do have (nimbus 24, 26, and older KH 24) all had almost 100mm between the mounting bolts. I know the Drak had a narrower profile than these unis, but I'm starting to wonder if maybe I didn't actually run the Rhyno with the maggies.
caseytronic is offline   Reply With Quote
Old 2017-02-15, 03:19 PM   #17
caseytronic
Unicyclist
Maggies With Rhyno Lite
It was bothering me to the point of distraction, so I mounted my Magura HS11 onto my nimbus steel 26 frame and they do fit the Rhyno Lite (plenty for grab). Whew! - I'm not crazy.
I did have to mount them as far in as they would go though.
Old 2017-02-15, 03:23 PM   #18
caseytronic
Unicyclist
Distance between Magura mounting bolts on the Nimbus steel 26 - 97mm.
Old 2017-02-15, 08:48 PM   #19
pierrox
Unicyclist
pierrox's Avatar
Thanks for taking the time to do this!
That's good news, what I would save on the brake extenders (reducers?), I would spend on the rim. Why not hey!
This rim is at a decent price, even new. Now I need to figure a way to bring it back in Europe as I don't know if it would fit my regular suitcase...
pierrox is offline   Reply With Quote
Old 2017-05-02, 06:40 AM   #20
caseytronic
Unicyclist
I discovered another wide 700c / 29 rim-brake compatible rim in a 36 hole option:
The Velocity Cliff Hanger - 35mm outer width (slightly wider than the Rhyno Lite) $65 -85
Links:
http://store.velocityusa.com/p/cliff...ffhanger?pp=12
http://www.bikemania.biz/rims/veloci....html?___SID=U
Old 2017-05-24, 08:51 AM   #21
bouin-bouin
Didier
bouin-bouin's Avatar
there is a new 29' rim in KH2017 set-up :
__________________
http://monocycle.info
http://www.leblogdumonocycle.fr/
CITY XTP 26", MUNI KH26" & KH29", ROAD Oracle 32" and KH36"
my goal : a 3 geared 29" to have only one uni for all kind of rides :-)
bouin-bouin is offline   Reply With Quote
Old 2017-05-24, 09:05 AM   #22
pierrox
Unicyclist
pierrox's Avatar
Yes but it's a non-disc brake rim, and it's even wider. So whilst it's good news for our munis, it won't help my specific setup.
Old 2017-05-24, 09:48 AM   #23
bouin-bouin
Didier
Quote:
Dear Pierre, this post is related to 29 rims, not only your concern ;-)
__________________
Old 2017-05-24, 11:28 AM   #24
UniDreamerFR
Unicyclist
UniDreamerFR's Avatar
To be fair, Pierrox is the OP of this thread and it's clearly about finding a narrower rim than KH rims for his G29 project, rather than talking about 29 rims in général.
Maybe the title of the thread is not specific enough.
Quote:
29" Rim
I'm looking for a rim to move my Schlumpf hub into my 29" uni. I'd rather build a new wheel and go narrower than the KH rim as it'll be for road/town use.
It would have to be compatible with Magura brakes and have 36 holes to match the hub.
New KH rims will be even wider than what we have now, clearly not matching his project.
__________________
- Geared kh36 + Nightrider Lite + Kh Tbar + HS33
- Qu-ax 36" + nightrider +Q-handle+ cable rim brake
- kh 29" + knard 29x3+ kh Tbar + HS33
- Qu-ax trial 19"
-24"&26" wheels and forks and spare stuffs.
UniDreamerFR is offline   Reply With Quote
Old 2017-05-25, 07:13 AM   #25
Siddhartha Valmont
Unicyclist
Siddhartha Valmont's Avatar
What about the rims spec'ed on QX unis?
Or even the Alexrims DX32 that is found on the regular Qu-ax muni?
It is a rim strong enough and in the 32mm ballpark. And they have several different drilling including 36H.
__________________
=> Triton 29: KH XC, Nimbus CrMo hub, Spirit 110/137 & Schwalbe Big One
=> Flansberrium 26: Nextie rim, JumboJim 4.0, Spirit 127/150mm, M4O ISIS
=> MiniFat 24: M4O green, KH/S hub, Spirit 117/137mm, HollyRoller 2.4/Mission 4.0
Siddhartha Valmont is offline   Reply With Quote
Old 2017-05-25, 04:15 PM   #26
Eric aus Chemnitz
Landesvertreter Sachsen im EVD
Eric aus Chemnitz's Avatar
Quote:
They're 40mm. (The Plus size ones are wider)
__________________
Einradfahren in Sachsen:
einradsachsen.com
f/EinradSachsen
02.06.2019: Europamarathon
Eric aus Chemnitz is offline   Reply With Quote
Old 2018-05-17, 09:19 PM   #27
pierrox
Unicyclist
pierrox's Avatar
Just for future reference... here is what I did with the brakes as the pads couldn't reach the rim I settled for (a Rigida Sputnik)!
http://www.unicyclist.com/forums/sho...d.php?t=120857
Old 2018-06-01, 12:45 AM   #28
GizmoDuck
Adventure Unicyclist
GizmoDuck's Avatar
Now it's a 19C with a total width of 25mm. Mavic says tire shouldn't be wider than 50mm but the one I have and wanted to use is a Schwalbe Big One, 2.35" wide (i.e. about 60mm).
Is that really too big for this rim? I read a lot about rims lately and with the wave of fatter tires on MTB, it seems acceptable to go that wide on such a rim. But real life - and unicycling - has different rules.
Do you think this rim would work? What would be another choice?
I ran a Schwalbe Big One 2.35" on a H Plus Son Archetype rim at Unicon 19. It was good enough to come third so I guess it works just fine.
The rim is pretty strong, didn't notice any flex, and has a braking surface. It is slightly narrower than your Mavic at 23mm. The deeper profile silver finish looks really good though.
GizmoDuck is offline   Reply With Quote
Old 2018-06-01, 08:18 AM   #29
pierrox
Unicyclist
pierrox's Avatar
Thanks for the feedback!
I kept my Big One until recently. I loved the look of it, the light weight, how I could fall into a turn with it. But I hated that it got 4 punctures in just a few months - the only uni I ever got a flat on. And I didn't like how it reacted to road camber, and even to tarmac patches (when they fix a part of the road and you ride across, almost parallel, to the joint between the old and new tarmac).
I'm clearly nowhere near you as a rider, but those were too much to cope with for me and I wen't to a narrower Marathon.
Reply
Tags
rim
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
[For Sale] KH 29 with Magura rim brake dkoeblitz Trading Post 5 2016-09-20 11:49 PM
[For Sale: North America] KH Schlumpf (24" with a 29" rim available) Killian Trading Post 22 2015-11-13 05:34 AM
[For Sale: Europe] 29" wheel (KH rim + nimbus hub) Yngvar Trading Post 6 2015-07-16 07:28 PM
Rim strip size for a KH Freeride 24" rim unimogmatt General Unicycling Discussions 5 2014-12-17 03:33 PM
[For Sale: North America] Complete Wheel: KH 29" Freeride Rim 47mm + Nimbus ISIS hub Nurse Ben Trading Post 4 2012-06-03 02:34 AM
Powered by vBulletin®
Copyright © 2001-2016 Gilby
Page generated in 0.44032 seconds with 10 queries
