#1 |
Rubberduck
QU-AX Q-Axle 29 Disc white
Hi there
This is my new 29er. I love it ![]() The dealer told me that this is the first of its kind in Switzerland ![]()
__________________
Rubberduck Wer Rechtschreibfehler findet kann sie behalten ![]() Who finds spelling errors may keep them ![]() |
#2 |
This space available
Very nice, Rubberduck!
There was a discussion on the forum about this new model a couple weeks ago. Can you tell us how long the cranks are, and if there was a choice of lengths when you bought it? What type of riding do you mostly do with it?
__________________
"I'm a unicyclist. I make my own reality." |
#3 |
Rubberduck
Hi LanceB
First, I am riding unicycle for about 12 weeks now. So I do have a lot to learn ![]() So for now I am riding mostly on tarmac roads and easy / smooth paths, with little uphill and down hill. Nothing complicated. The cranks have a length of about 150mm, and there was no choice...
__________________
#4 |
It will make a great muni when you get a little more riding experience!
Cheers!
__________________
#5 |
29" Muni/Downhill! (and 36" Muni)
Sweet!! As I commented in the other thread, curious as to the options offered concerning crank length, but otherwise it looks great!! I've been thinking about adding a 29 to my 24 and 36... so curious what you think.
If you ever make it over to Munich/Bavaria/Tirol then drop me a line! |
#6 |
Rubberduck
Somehow the hub got destroyed. It seems that the red part moved somehow. Now the frame, cranks and of course the hubs are damaged. The hole thing moved to one side. During riding. I had some cracking noise, then at one moment this happened...
I am a unicycle beginner. I have to unicycles, 24" and 29". Both of them had problems. And both from QU-AX. Hope the guys will help me. It is quite new, and I am riding not that hard to destroy a unicycle. I am riding since 4 Month now... Here some pics. My heard is bleeding, this 29" was a gift from my wife...
__________________
#7 |
Unicyclist
Measure from the edge of the red hub to the end of the axle on each side to see if the bearings have just moved, or if the axle has slipped in the red hub and is no longer centered.
I would guess if the axle has moved through the hub it would be a warranty issue. ?? Not sure how the hub is constructed.... Last edited by fugsworth; 2014-12-24 at 02:36 PM. |
#8 |
Unicyclist
Sounds like a bearing may have moved because of a missing spacer. The bearing to bearing measurement will rule this out (or not).
If they forgot a spacer, I am sure the shop you ordered from will send you some. From the pics, it seems like the damage is limited to the frame because of the crank rub. And if the hub IS damaged, it will be covered by the warranty. It is never nice to experience, but the future isn't that bleak... ![]()
__________________
=> Triton 29: KH XC, Nimbus CrMo hub, Spirit 110/137 & Schwalbe Big One => Flansberrium 26: Nextie rim, JumboJim 4.0, Spirit 127/150mm, M4O ISIS => MiniFat 24: M4O green, KH/S hub, Spirit 117/137mm, HollyRoller 2.4/Mission 4.0 |
#9 |
Backwards at Grant's Tomb
Does not look unusable. I too would be very upset and want some help, but in the worst case I think it can be made to be 100% useable again.
Good luck |
#10 |
Unicyclist
Damn, I hope everyone above is right and this isn't a big issue!
__________________
“It is well known that a vital ingredient of success is not knowing that what you're attempting can't be done. A person ignorant of the possibility of failure can be a half-brick in the path of the bicycle of history.” |
#11 |
Rubberduck
First, I like the QU-AX products very much, they have nice looking ones and also with this new hub not mainstrem design.
last time I had an similar problem they changed the whole wheel. So great service, no question. so I hope the same kind of help for this issue. I measured a bit. The bearings sit on a 24mm diameter, fitted to a 27mm shoulder, no space between, so the bearings seem to be on the right place. But the axle where the bearings sit has moved through the whole red part. that can seen by eyes, no measurement needed. With spacers between cranks and bearings AND bearings and red part this would not happend. But I think spacers where not intended to be used. But I might be wrong. I observed also a cracking noise during riding, only on the right side, and if I apply enough force by hand I can hear and feel the crack on the right side. But there ise no obvious play. I would like to point out that I posted this here to give feedback to you guys. Not to harm or bad talk about QU-AX. They made with this new design a real sexy looking product. And it is brand new, so such things can happen, not cool, but as I am as well from this mechanic industry I totaly understand that this can happen... I will come back to you with news...
__________________
#12 |
The scraping of the bearing housing by the crank arm is purely cosmetic, so I wouldn't worry about that. Spacers on the outside of the frame would have prevented this. You may want to consider adding them. The bearings are press-fit onto the axle, and aren't supposed to move, but sometimes they do, as you see.
Good luck!
__________________
#13 |
Unicyclist
It may not be relevant, but did you apply the brake just before this happened? Perhaps it set something in motion that was supposed to be fixed…
hope you solve it, it looks like a real nice unicycle |
#14 | |
Unicyclist
Quote:
![]() ![]() I think the issue is that this is a brand new hub design. Yours was probably one of the first off the shelf, so I wouldn't expect it to be 100% perfect in every way. That being said, I would've hoped they would've tested it a bit better before selling them! Hopefully at the very least they'll take the feedback and improve the next batch.
__________________
#15 |
XC Muni
There should be spacers on both the inside and outside of the bearings, this maintains spacing for the frame. The crank should fit snug against the outside spacer. Based on the look of your frame, there was no outside spacer, so the beairng shifted on the spindle.
__________________
I dream of hamsters and elderberries Last edited by Nurse Ben; 2014-12-26 at 10:50 PM. |
Tags |
disc, qaxle, quax, white |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | Search this Thread |
Display Modes | Rate This Thread |
Thread | Thread Starter | Forum | Replies | Last Post |
New Qu-Ax Q-axle Disk 36" - any info? | mindbalance | General Unicycling Discussions | 15 | 2015-01-16 06:53 PM |
Qu-Ax Muni 29" | Eric aus Chemnitz | Deutsches Einradforum | 6 | 2014-09-17 11:38 AM |
Qu-Ax Cross 29"--good unicycle? | Dydaying | General Unicycling Discussions | 8 | 2013-12-02 05:58 PM |
[SPRZEDAM] QU-AX QX Series 29 cali | paweloyama | Polskie Forum Monocyklowe | 26 | 2013-10-14 06:49 AM |
QU-AX 29 Cross. | biged | Unicycle Product Reviews | 6 | 2011-11-22 11:56 AM |
