Unicyclist Community
Reply
Old 1995-08-04, 12:51 AM   #1
Ken Fuchs
Newsgroup User
Posts: n/a
Doug Borngasser <db@ucsd.edu> wrote:
[color=blue]>Anyone have an opinion as to the dangers or difficulties if both cranks are[/color]
[color=blue]>left handed?[/color]
If tightened sufficiently, two left threaded pedals and cranks should pose no
problem whatsoever. By sufficiently, I mean as tight as possible with a 12 inch
pedal wrench without stripping the threads. (When the pedal absolutely refuses
to be tightened further, it is tight enough [to stay on forever].)
The risk of stripping threads by tightening too much with even a 12 inch is many
times less than ruining the threads by not tightening enough. However, body
builders may need to use some restraint while tightening pedals with a 12 inch
pedal wrench.
Stay on Top, with two left pedals,
Ken Fuchs <kfuchs@winternet.com
Old 1995-08-04, 02:14 AM   #2
Eric Busboom
Newsgroup User
Posts: n/a
Re: Two left pedals [Re: Threads of unicycle pedals]
On Thu, 3 Aug 1995, Ken Fuchs wrote:
[color=blue]> If tightened sufficiently, two left threaded pedals and cranks should pose no[/color]
[color=blue]> problem whatsoever. By sufficiently, I mean as tight as[/color]
[color=blue]> The risk of stripping threads by tightening too much with even a 12[/color]
I rode -- very happily -- with a pair of 165mm left cranks on a Schwinn, but not
without problems. These were aluminum cranks, so striping did end up being a
problem, and their ultimate demise. They stripped because I tore out the threads
hopping down stairs while they were loose; they were loose despite my best
effort with a 30cm wrench.
Based on experience with these cranks and others on my mountain bike, it seems
that they vary in hardness -- with a soft aluminum alloy you may have problems.
Another problem -- the extra length puts more torque on the spindle (axel) when
jumping, such that I sheared a spindle jumping stairs.
eric.
Reply
Tags
left, pedals, threads, unicycle
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.06447 seconds with 9 queries
