Unicyclist Community
Reply
Thread Tools Search this Thread Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 2013-08-02, 03:31 PM   #1
waaalrus
Unicyclist
3.8:1 geared direct drive wonderhub
Due to my continued interest in freewheel unicycling I read a lot about drift trikes and I came across this interesting photo:
https://www.facebook.com/photo.php?f...&type=1&ref=nf
Quote:
JR Drift Trikes
We've got both our prototype trikes running the 3.8:1 geared direct drive wonderhub, aka the game changer! Both have got our custom JR rotors on them, the white one now has a post mount holding the brake calliper
Notice the Nimbus Venture cranks! This doesn't work for freewheel unicycling because it's direct drive but I'm curious if anyone's seen anything like this. Is it maybe a regular bike hub and they mounted the cranks in a special way? It looks like there may be more developments soon and maybe they'll give out more information.
waaalrus is offline   Reply With Quote
Old 2013-08-02, 03:46 PM   #2
tholub
Totally Doable
tholub's Avatar
Interesting. With internal planetary gearing the best you can do, theoretically, is 2:1, and in practice the best you can do is a lot less than that. (The Schlumpf is 1.54:1). Maybe there's a hidden jackshaft in there somewhere?
The big questions are the amount of backlash, and the behavior when pedaling backwards; the NuVinci hub, for example, doesn't really have backwards ability, although Justin managed to modify it to make it possible to use on a uni. (At a weight penalty of 12 pounds).
tholub is offline   Reply With Quote
Old 2013-08-02, 04:04 PM   #3
jtrops
Unicyclist
I wonder how heavy this hub is. A lot of the backlash in typical IG hubs is due to the need for shifting. Since this hub is a single gear it seems logical that it would have much less backlash (although not completely without).
So, with a 20" wheel this would equate to a 76" gear? That is a huge wheel. I don't know if I could push that with cranks short enough to clear the ground on a small wheel.
__________________
"A properly ridden unicycle is like an object in orbit: constantly falling but never landing." -Diogenes
jtrops is offline   Reply With Quote
Old 2013-08-02, 04:10 PM   #4
tholub
Totally Doable
tholub's Avatar
Whether or not a planetary hub is shiftable, it will have backlash; it's a function of the gear teeth moving from one side of the groove to the other. Harper's hub had more backlash than the Schlumpf does, mostly because Harper's not Swiss (the tolerances weren't as tight).
A 76" gear would not be a problem to ride once you got it up to speed. Getting it up to speed would be a challenge.
Old 2013-08-02, 04:43 PM   #5
MuniOrBust
show me the muni!
MuniOrBust's Avatar
Why is everyone quoting the post directly above theirs? Isn't that a given?
Sorry... just something I noticed.
MuniOrBust is offline   Reply With Quote
Old 2013-08-02, 04:50 PM   #6
jtrops
Unicyclist
I know there will be backlash, but much of the regular backlash is designed into the hub to allow the key to move in the keyway. Without having to release the key, and slide it into a new position you would be allowed to tighten up the tolerance quite a bit.
__________________
Old 2013-08-02, 06:30 PM   #7
harper
768 - It's in your DNA
harper's Avatar
Compound gears can be put into a planetary hub. It's only simple gearing that imposes the theoretical 2:1 limit.
__________________
-Greg Harper
Destroying the climate by shutting down nuclear power plants, one by one, since 1979.
Change is good. Bills are better.
harper is offline   Reply With Quote
Old 2013-08-02, 06:49 PM   #8
tholub
Totally Doable
tholub's Avatar
Quote:
Fair enough, but wouldn't that require three sets of planets?
Old 2013-08-02, 08:56 PM   #9
harper
harper's Avatar
I've never looked at space constraints for compound geared fixed hubs. In the case of a compound planet gear, the sun can be big, the part of the compound planet contacting the sun can be small, and the part of the compound planet contacting the ring can be big. the hub starts getting big as the ring gear necessarily expands. There is also a limit to how big the the larger of the compound planet gears can get because they start crashing into the axle.
__________________
-Greg Harper
Old 2013-08-23, 08:33 PM   #10
waaalrus
Unicyclist
I guess I don't understand the term "direct drive" very well. It sometimes seems to be used in conjunction (as opposed to contrast) with freewheel. Looking at the video it looks like this hub does freewheel which means I may need try one on a unicycle.
Old 2013-09-17, 04:08 PM   #11
waaalrus
Unicyclist
I checked with the makers and the bad news is that these are custom dropouts so if you want to make a unicycle out of it without a lot of modification you'll need to use their forks which limits the size of the wheel to 20". The good news is that they will be selling these front ends separately so I think the only thing you would need to do is notch the steering tube and put in a unicycle seat post and seat post bolt. Pricing is still forthcoming but I'm excited about the possibility of a 20" wheel geared up to feel like 76".
Old 2013-09-17, 07:20 PM   #12
aracer
Registered Unicyclist
You might be the only one. Well I suppose to be fair I am quite excited about the idea of seeing somebody attempt to ride one
__________________
Unicycling: great for your thighs.
aracer is offline   Reply With Quote
Old 2013-09-17, 08:59 PM   #13
Shmolagin
Uniquecyclist
Shmolagin's Avatar
Quote:
My thoughts exactly.
__________________
You shouldn't believe everything you read on the internet. -Honest Abe Lincoln
Shmolagin is offline   Reply With Quote
Old 2013-09-17, 09:38 PM   #14
jaco_flans
Trials & Muni!
jaco_flans's Avatar
Send a message via MSN to jaco_flans
I'd ride it to school! I need a faster uni without killing my Muni tire on pavement. The 20" wheel would even fit in my locker!
__________________
Jakob F.
jaco_flans is offline   Reply With Quote
Old 2013-09-19, 06:03 PM   #15
johnfoss
North Shore ridin'
johnfoss's Avatar
I guess I don't understand the term "direct drive" very well. It sometimes seems to be used in conjunction (as opposed to contrast) with freewheel. Looking at the video it looks like this hub does freewheel...
If I understand correctly, Direct Drive means you are directly driving the wheel, like a unicycle or a tricycle. I do not know if this allows for a gearing system in between.
Fixed Gear (or Fixie) means there is no freewheel. Whatever the gear is, that's all you get, forward or backward. So those trikes may be direct drive, but they are not fixies.
...I'm excited about the possibility of a 20" wheel geared up to feel like 76".
It'll be rideable, but very sluggish. Don't listen to the naysayers.
__________________
John Foss
www.unicycling.com
"The miracle is this: the more we share, the more we have." -- Leonard Nimoy
johnfoss is offline   Reply With Quote
Reply
Tags
direct, drive, geared, wonderhub
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
DAKOROMAN DRIVE SYSTEM - geared unicycles/ hpv's dakoroman General Unicycling Discussions 28 2015-09-28 07:46 AM
Unicycling Skyline Drive on the geared 36er siafirede General Unicycling Discussions 0 2009-04-07 04:44 AM
Direct drive bicycle cyberpunk General Unicycling Discussions 7 2005-07-26 06:21 PM
Powered by vBulletin®
Copyright © 2001-2016 Gilby
You Rated this Thread:
Page generated in 1.14630 seconds with 12 queries
