Unicyclist Community
Reply
Old 2000-09-08, 09:40 PM   #1
uni mtl
Newsgroup User
Posts: n/a
I have a semcycle and for weeks the crank kept coming loose during rides. Turns
out the nut used to hold it on has a set of ridges on the back that "wear out"
and when I replaced it, no more loose crank, so if any one else has the same
problem, the solution is easy and cheap!
uni montreal
Reply
Tags
crank, loose, problem, solved, uni
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.05027 seconds with 9 queries
