Unicyclist Community
Reply
Old 2000-04-08, 04:51 PM   #1
Leo White
Newsgroup User
Posts: n/a
I've just gone from using a gear lever to a conventional brake lever on my Muni.
I overcame the awkward part i.e. positioning it where I could use it
efffectively by doing the following:
1) Slid a standard mountain bike Bar End (22.2mm) onto the standard Miyata
stem (also 22.2mm), and clamped the brake lever onto the end. This made the
brake almost usable but required an awkward 1 fingered pull, and was still
a bit far away.
2) After wandering around the garage and looking fir some inspiration (and other
usefule bits) I found an Aheadset top cap disc. I drilled a 5mm hole in the
end of the lever arm and used a longish 5mm bolt to sit the disc on top of
the lever and nearer the handle of the Miyata saddle. This makes the brake
relatively effortless to pull on with two fingers either side of the bolt.
Here's a pictogram (that might not be readable in a differently spaced font)
_________________________________
/ Saddle | {________________________________| --------------------| | __ =/
Here's a picture:
http://wkweb5.cableinet.co.uk/leo.wh...res/Lever1.jpg
Leo White, Cheltenham
P.S. I still think that using a friction gear lever is a good idea on long road
or non-technical descents, I had problems though releasing the brake when I
needed to in the middle of technical downhills, or at the end.
Reply
Tags
brakes
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.05266 seconds with 9 queries
