Unicyclist Community
Reply
Old 2012-09-24, 04:17 PM   #1
Feisty
Unicyclist
Feisty's Avatar
Location: Worthing, England Unicycle 1: KH20 LN Sold Unicycle 2: KH24 (HS33) Sold Unicycle 3: 24 Impact Gravity Unicycle 4: KH26 (Disc) rebuilt Unicycle 5: KH29 (Disc) Unicycle 6: Triton 36 (Disc)
Kris holm 2012 Bearing caps
Thought this might be useful to post as I hadn't seen any pictures posted already.
As most of you know the 2012 bearing holders and caps are machined down to allow enough room for the disc bolts when using the Spirit cranks, I was surprised by how much.
Another interesting point is that the inside bearing face has been machined clean of powder coat which makes sense as my other 3 KH frames were very tight on the caps and need a big tug to get the wheel out. This maybe of interest to Schlumpf owners due to slipping of the knurled end of the hub as the powder coat gave a tighter fit? There is no internal lip on these ones which is for schlumpf hubs I believe?
Hope this is of interest/use
Feisty is offline   Reply With Quote
Old 2012-09-24, 04:34 PM   #2
dmacuni
The other unicycling geologist.
dmacuni's Avatar
Quote:
Hey feisty,
Kris explained it all here... http://www.unicyclist.com/forums/sho...09#post1523309
Cheers,
Dmac
__________________
Ken Looi - Nostradamus of the unicycle world???
dmacuni is offline   Reply With Quote
Old 2012-09-24, 04:38 PM   #3
Feisty
Unicyclist
Feisty's Avatar
Cheers I thought he lack of lip was meant for that but though a comparison picture would be useful especially for people retro fitting spirit cranks to old frames as it gives an idea of how much material needs removing
Old 2012-09-24, 05:10 PM   #4
uniShark
muni commuter
uniShark's Avatar
Yeah, the amount of grinding on the frame to retrofit with Spirits/disc was enough to start making me nervous. But seems OK so far.
__________________
My 29er is my little wheel. Roll it, baby!
pLs forgve anu typist imak win positing forum my fone.
uniShark is offline   Reply With Quote
Old 2012-09-24, 05:52 PM   #5
Feisty
Unicyclist
Feisty's Avatar
Quote:
And here is me with a 2012 frame when I wanted a non disc tab one as I ran an Oracle hub
I might try whacking the caliper on upside down to see how it aligns and if it would be feasible (with a caliper that uses a banjo bolt so as to be able to rotate the hose angle) to tun the hub and brake on the right to use the tab mount instead of the D Brake.
worth a play
Old 2012-09-24, 10:47 PM   #6
uniShark
muni commuter
uniShark's Avatar
worth a play
If your plan doesn't work out, we could swap frames.
__________________
Old 2012-09-25, 05:21 AM   #7
Feisty
Unicyclist
Feisty's Avatar
That would a long distance trade
I hae a D-brake mount anyway so I am not that fussed and I may get a Schlumpf at stome point so it gives me the option to run a crank mounted rotor if I go down that route way down the line (be more for road use and 1:1 off road as it is bloomin hilly around here).
Old 2012-09-25, 02:55 PM   #8
uniShark
muni commuter
uniShark's Avatar
True, but if you want to trade your new 2012 frame for my well-used 2008 frame that I've taken a grinder to, I might pay for the shipping.
__________________
Old 2012-09-25, 03:01 PM   #9
Feisty
Unicyclist
Feisty's Avatar
Man you make a tempting pitch!
Reply
Tags
2012, bearing, bearing cap, caps, frame, holm, kris, kris holm, schlumpf
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Loose bearing caps La Rueda Perdida General Unicycling Discussions 2 2012-07-04 02:24 AM
[Wanted North America] Kris Holm Isis Hub bearing timekeeper Trading Post 1 2010-09-24 04:18 PM
Bearing Clamps for Kris Holm bungalistic Trading Post 6 2007-01-20 06:35 PM
WANTED: Torker LX/DX bearing caps Spudman Trading Post 2 2006-04-25 04:37 AM
Yuni bearing maincap caps? abbabibble General Unicycling Discussions 2 2005-10-29 03:33 PM
Powered by vBulletin®
Copyright © 2001-2016 Gilby
Page generated in 0.08366 seconds with 11 queries
