Unicyclist Community
Reply
Old 2007-01-03, 06:08 AM   #1
president_luke
Unicyclist
Is the Kh moment hub powder-coated?
I sure hope its not. Damn blue-ness.
president_luke is offline   Reply With Quote
Old 2007-01-03, 07:29 AM   #2
ntappin
Ask me about the Ottawa unicyclists
ntappin's Avatar
Send a message via MSN to ntappin
It's anodised.
ntappin is offline   Reply With Quote
Old 2007-01-03, 07:30 AM   #3
president_luke
Unicyclist
even worse.
Old 2007-01-03, 07:38 AM   #4
ntappin
ntappin's Avatar
Quote:
Originally Posted by president_luke
even worse.
Not really, its easier to paint over.
Old 2007-01-03, 07:53 AM   #5
president_luke
Unicyclist
oh cool. I was gonna strip the paint first but i wont anymore.
I don't want to start a new thread, but are the flange dimensions on the new hub close enough to the kh/onza hub to use the same length spokes?
Old 2007-01-03, 11:57 AM   #6
kington99
Unicyclist
Send a message via MSN to kington99
Anodising is a coating proces that only applies to aluminium, due to the way it forms an oxide layer due to its high reactivity. The hub is not aluminium, it's 4130 CrMo, and therefore it isn't anodised (but incidently the frame is). I would guess, but Im not sure, that it is powder coated, but it certainly isn't anodisied.
Use the UDC spoke calculator to find the spoke length for the two setups you're considering, and see how close the spoke lengths are. Within a couple of mm you can use the same spokes, otherwise you'll have to get new ones.
__________________
Dave
- what a thoroughly post-modern subversion of the cycling genre -
kington99 is offline   Reply With Quote
Old 2007-01-03, 12:17 PM   #7
president_luke
Unicyclist
Quote:
The moment hub's not on there.
Old 2007-01-03, 12:31 PM   #8
kington99
Unicyclist
damn!
__________________
Dave
Old 2007-01-03, 12:54 PM   #9
joemarshall
dumb blonde
http://www.unicycle.uk.com/hubcomparatorisis.html lists it as 75mm wide, 56mm diameter, and the 2005 one as 68mm, 56mm. If that's true, it'll only make a tiny difference to the spoke length and you should be able to reuse the spokes.
Joe
joemarshall is offline   Reply With Quote
Old 2007-01-03, 01:11 PM   #10
president_luke
Unicyclist
Quote:
Joe
Thanks.
Old 2007-01-03, 01:22 PM   #11
rogeratunicycledotcom
Mostly OKish Unicyclist
It is powder-coated.
You can actually anodise other materials, Titanium being the other popular one. Although anodising steels don't work very well it can be done (the processing I don't think is then called anodising). From what I understand it is not for the colour properties but for other reasons... surface hardening? sorry this is the extent of my knowledge and memory to remember more than that. I am sure someone will give us a full explanation. :-)
Roger
__________________
Roger Davies
Unicycle.com in the UK
The UK's Unicycle Source
www.unicycle.co.uk
rogeratunicycledotcom is offline   Reply With Quote
Old 2007-01-03, 02:53 PM   #12
swarbrim
blank
swarbrim's Avatar
Send a message via ICQ to swarbrim Send a message via MSN to swarbrim
Joe
When I was upgrading (the exact same parts) I was told by Roger that I could reuse the spokes, but it would be stronger to just buy new ones. If you have black spokes I say you should change them to silver. Silver spokes kick black spokes arse's.
Mike
[EDIT] Maybe Roger was just trying to get me to buy more stuff...
__________________
Add me at: mike41ishere <att> hotmail <dott> com
'i like things big' - Amanda
'Crankflips are like woman, hard to understand' Peter/Probailer2
swarbrim is offline   Reply With Quote
Old 2007-01-03, 03:04 PM   #13
may be. :-P
There are a couple of reasons for new spokes, they are stronger as they are not already stressed and they also make the wheel building easier.
Note we now have 13g KH spokes in stock! these are great.
Roger
__________________
Roger Davies
www.unicycle.co.uk
Old 2007-01-03, 07:21 PM   #14
ntappin
ntappin's Avatar
My bad Luke when I looked at it, it looked kind of metalic and such a thin layer I didn't think it could be powdercoated but I guess I'm wrong.
I guess you learn something new every day.
Old 2007-01-06, 08:33 AM   #15
byza_dog
I SEE SETS
byza_dog's Avatar
the kh moment hub is alloy.....
the spindle is cro-mo....
why would they make a hub that is chromoly? you dont need the strength of chromoly in a hub and chromoly is heavier so it would be wasted weight, thats why the hub is alloy and seeing it is alloy then why powdercoat it when anadizing looks better and lasts longer?
put simply, hub is alloy and is most likeley anodized.
dont give me any $#!T about 'oh but udc says it is chromoly" because udc is talkin about the spindle as that is what is of most concern and most unicyclists refer to the hub as the hub plus spindle whereas bikers for instance dont refer to the two parts as one but as seperate parts which they are.
bye bye
__________________
improving each day revs r cool, i say rev it up!
CRANKFLIP CHAMPION!! 1st place
)---'O, Crankflip
link to crankflip vid > http://www.youtube.com/watch?v=8TmQnEIXc4Y
Street Dog (my vid) http://www.youtube.com/watch?v=ijM6vbhc5xs
byza_dog is offline   Reply With Quote
Reply
Tags
hub, moment, powdercoated
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Profile hub/cranks vs KH moment hub/cranks Uni_Every_Second General Unicycling Discussions 11 2006-12-29 11:32 PM
04 KH hub with 127 qu-ax cranks. president_luke General Unicycling Discussions 9 2006-12-21 05:09 PM
Powder Coated 2005KH24 Ed Hansen General Unicycling Discussions 9 2005-01-29 10:25 PM
Bedford Hot Pink and Metallic Purple powder coated frames Darren General Unicycling Discussions 12 2004-01-12 11:10 PM
Amazing Powder coated frames, rims and hubs! Erin General Unicycling Discussions 5 2003-05-04 05:03 AM
Powered by vBulletin®
Copyright © 2001-2019 Gilby
Page generated in 0.10766 seconds with 11 queries
