Unicyclist Community
Reply
Old 2007-06-06, 06:35 PM   #1
delcypher
Dan Liew (UUU webmaster)
delcypher's Avatar
Send a message via MSN to delcypher
Question a bit of advice of 4 issues please...
1. I have a mate who has the KH/ Onza splined hub
But there's play in it. The removal splined axle rotates inside the hub slighly before engaging. The axle has two bits of metal which are removable which is what fixes the axle to the hub body but they don't 'seem' to be worn.
I've noted that the spacers between the bearings and cranks are missing, but I wouldn't of thought it would be causing the play.
any ideas people?
2. I'm thinking of building a new wheel and I want to know what crank arm length is suggested for unicycle trials (19" wheel). My current uni has 125mm cranks, but I think some people have 140mm! Comments please.
3. Could anyone suggest between KH/Onza Hub (http://www.unicycle.uk.com/shop/shop...?catalogid=671) +cranks and the Kris Holm momentum 2007 hub + cranks (http://www.unicycle.uk.com/shop/shop...atalogid=902)?
4. What's the difference crank length aside between...
and
http://www.unicycle.uk.com/shop/shop...?catalogid=521
Thanks guys & gals.
delcypher is offline   Reply With Quote
Old 2007-06-06, 06:41 PM   #2
brendan
Unicycling = trials
brendan's Avatar
i have koxx reinforced 140's and i love them. Most people like smaller cranks especially for street. but i think 140s are nice for trials.
brendan is offline   Reply With Quote
Old 2007-06-06, 06:43 PM   #3
thejdw
elcycinu
thejdw's Avatar
Kh moment hub is better
__________________
I didn't spell it wrong, you just read it wrong!
thejdw is offline   Reply With Quote
Old 2007-06-06, 06:50 PM   #4
kington99
Unicyclist
Send a message via MSN to kington99
1. the hub pictured isn't a KH/Onza, it's an onza, there's a difference. The keyway slop you described is a well known problem with the onza hub. You can remove the axle and put enough glue in place to keep the keyway in place properly. Many people have done this and it proves to be a good and longlasting solution. Use the search feature to find descriptions of how to do this to your hub.
2. I understand most trials riders use 135 -140mm cranks, some people prefer slightly shorter cranks for more spped for rolling hops, but they are the exception.
3. and 4. the onza came first, then the Kh/Onza, then the KH moment. Each one was better than the last, so the KH moment is the hub/crankset of choice, it's stronger, stiffer, lighter and cheaper than the older models.
__________________
Dave
- what a thoroughly post-modern subversion of the cycling genre -
kington99 is offline   Reply With Quote
Old 2007-06-06, 07:06 PM   #5
thejdw
elcycinu
thejdw's Avatar
I've heared of people bending kh/ onza cranks, is the original onza like this?
__________________
Old 2007-06-06, 07:25 PM   #6
kington99
Unicyclist
Quote:
The cranks are similar, infact you can swap them with each other, I should imagine some have been broken, infact my good friend loosemoose snapped one on his onza trials, and had the problem with the loose keyway on his onza muni. I can't remember any others, but you must consider that in the hey-day of the onza cranks street riding hadn't really been invented, people just didn't break stuff like they did now. Also there was that issue with the 1.4mm thick versus 1.6mm KH/Onza cranks.
__________________
Dave
Old 2007-06-06, 08:27 PM   #7
delcypher
delcypher's Avatar
thanks for the replies.
Old 2007-06-06, 09:04 PM   #8
uni_jim
i shot a clown and stole his bike.
uni_jim's Avatar
I have this hub with matching cranks, and the same problem. Anyone know a cure?
__________________
evolve trials
Quote:
Originally Posted by pedrotejada
flatlanders are street riders with fear of height and ladders...
uni_jim is offline   Reply With Quote
Old 2007-06-06, 09:15 PM   #9
kington99
Unicyclist
Quote:
Voila
__________________
Dave
Old 2007-06-06, 09:59 PM   #10
chicagounicycle
chicagounicycle@gmail.com
chicagounicycle's Avatar
Send a message via AIM to chicagounicycle
I am one of them... had to sink another $125 for new crank arms
__________________
Join the Chicago Unicycle Community:
http://www.myspace.com/chicagounicycle
chicagounicycle is offline   Reply With Quote
Reply
Tags
advice, bit, issues
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Bit of a long shot.... spanner General Unicycling Discussions 4 2007-04-26 07:42 PM
Coupla DX Issues: Advice Welcome tjanvier General Unicycling Discussions 5 2007-01-02 03:10 PM
Bit of help with hard drives, please s7ev0 Just Conversation & Introduce Yourself 14 2006-12-18 07:16 PM
Powered by vBulletin®
Copyright © 2001-2016 Gilby
You Rated this Thread:
Page generated in 0.07434 seconds with 11 queries
