Unicyclist Community
Reply
Old 2007-12-18, 02:58 PM   #1
Brian MacKenzie
If I hear that tune one more time..
Brian MacKenzie's Avatar
Send a message via MSN to Brian MacKenzie
usine v-brakes with magura brake mounts?
is there a way?
Brian MacKenzie is offline   Reply With Quote
Old 2007-12-18, 03:03 PM   #2
iridemymuni
i just dribbled
iridemymuni's Avatar
Send a message via MSN to iridemymuni
yes
__________________
maker of the happy birthday threads
_________
Just put the new uni together in the driveway stopped to move the car and ran over the uni.
Felt like putting my head under the tire.
- JustOneWheel
iridemymuni is offline   Reply With Quote
Old 2007-12-18, 03:05 PM   #3
Brian MacKenzie
thank you sir <tips hat>
Old 2007-12-18, 03:36 PM   #4
john_childs
Guinness Mojo
john_childs's Avatar
There is also ZHI at Trialsin
ZHI Magura to V-brake adaptor
And similar adapters from other trials bike companies. Email some of the online trials bike shops and see what they suggest.
It doesn't look like the one at UDC UK will position the post in the correct spot? I think the post needs to be below the lower Magura bolt mount and the adapter at UDC looks like it positions the post right at the same height as the lower Magura bolt mount. Could be just the angle of the photo.
__________________
john_childs (att) hotmail (dott) com
Team Never Wash Your Muni
My Gallery :: Unicycling Bookmark List :: World Clock
john_childs is offline   Reply With Quote
Old 2007-12-18, 03:47 PM   #5
Brian MacKenzie
thank YOU sir <re-tips hat>
Old 2007-12-18, 04:08 PM   #6
thejim
Unicyclist
thejim's Avatar
I have the UDC ones on my KH 29 and they work fine. Not that I ever use the brake....
They bolt into the bottom hole from memory.
The only thing I would say is that they don't work on Nimbus 36ers as the brake link cable fouls the frame spars.
__________________
Can't afford a proper bike......
thejim is offline   Reply With Quote
Old 2007-12-18, 05:52 PM   #7
john_childs
Guinness Mojo
I was thinking of the custom adapter someone made to put a 26x3 wheel in a KH 29er frame. In that case the brake adapter needed to be moved down.
The ones that convert a Magura trials mount to a V-brake mount don't need to lower the brake position like that. The V-brake post will end up positioned over the lower bolt hole.
__________________
Old 2007-12-19, 09:12 AM   #8
Unicorn
Unicyclist
Unicorn's Avatar
V-Brake Adaptor
I was the one who originally posted the Mission 4 bolt adaptors. I am happy to see that UDC uk started supplying them. I bought them way before UDC uk was selling them. After using them for about a year and a half now I have the folowing to say about them.
They are big and clumsy and torke is increased. I would not use them on a MUni. I have kept them on my KH29 where I do gentle feathering of the breaks on downhill sections of road. They are perfect here. Also I very rarely fall on the KH29 when doing cross country and road riding.
In MUni they get hit a lot and I have had the post break in the holes. It is then a bitch trying to get it out! I would use Maguras for hard MUni. There is also a 2 bolt adaptor made by Woodman that sells for $50 that would probably be better. However if yuo are going to spend so much money you might as well just get the Magura!
Unicorn
__________________
Keep your eyes on the stars and your feet on the pedals, and you will accomplish great feats!
The Unicycling Commune
Unicorn is offline   Reply With Quote
Reply
Tags
brake, magura, mounts, usine, vbrakes
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Welding Magura Mounts on an Aluminum Frame Danni General Unicycling Discussions 8 2006-11-14 05:06 PM
Magura brakes from UDC? forrestunifreak General Unicycling Discussions 5 2005-11-03 01:14 AM
Magura brakes oxfordrider General Unicycling Discussions 11 2004-09-07 05:39 AM
Magura Brakes? Dylan Wallinger General Unicycling Discussions 7 2002-06-27 08:38 AM
Magura Brakes dingeman General Unicycling Discussions 8 2001-07-26 08:04 PM
Powered by vBulletin®
Copyright © 2001-2016 Gilby
Page generated in 0.30531 seconds with 10 queries
