Unicyclist Community
Reply
Old 2005-01-31, 08:22 PM   #1
mikepenton
Unicyclist
mikepenton's Avatar
Dynamo on a Uni for GPS/PPC power
Has anyone ever tried a dynamo on a Uni?
I've just got a PocketPC with built-in GPS. Battery life is around 2 or 3 hours which is pretty hopeless if I want a constant fix & a track. The set-up I'm thinking of is a Pedal & Power charger so I could make a cup of tea, run a mini fridge or even keep the GPS charged.
Apart from the bulk of the dynamo (2 inches or so projection from the sidewall), lack of speed, the frame-fixing issues and the water damage from landing in puddles/rivers, can anyone see any major drawbacks?
Thanks
Mike
mikepenton is offline   Reply With Quote
Old 2005-01-31, 09:01 PM   #2
markf
movie nerd
Send a message via AIM to markf
get a better gps unit. there are some that have much longer battery life. and it might not work so well for uni but i've seen touring bikers with photovoltaics on the topp of their gear to charge stuff.
markf is offline   Reply With Quote
Old 2005-01-31, 09:10 PM   #3
total uni
Newsgroup User
total uni's Avatar
Send a message via AIM to total uni
I use the Garmin E-trex, it is a little backpacking GPS but it can show agerage speed, top speed, current speed and what not, its really little too.
you can get them for about 60 bucks
total uni is offline   Reply With Quote
Old 2005-01-31, 09:57 PM   #4
mikepenton
Unicyclist
mikepenton's Avatar
A 'better' gps unit is not a sensible option. As I already have vector & rasterized mapping on the PPC there is no point wasting money on a second unit which duplicates the same tasks or offers much less. I know that I could have had a basic non-mapping GPS with a longer battery life and a seperate PPC for less money.
Hence the option of the dynamo.
Old 2005-01-31, 10:18 PM   #5
Seager
I had a thing in here one time!
Seager's Avatar
Send a message via AIM to Seager
What type of batteries are you using? Try using NiMH with a high mah rating. Those last a ton longer than alkaline and are rechargeable.
Seager is offline   Reply With Quote
Old 2005-01-31, 10:36 PM   #6
wogri
Unispinner
wogri's Avatar
Send a message via ICQ to wogri
Re: Dynamo on a Uni for GPS/PPC power
Quote:
Originally posted by mikepenton
... can anyone see any major drawbacks?
Going through the electrical engineering pain of building such a unit. You can't just inject the power of the dynamo into the ppc. You need a regulating device with capacity in between. I don't know if such a thing exists on the market.
Edit: If I had clicked on your Link I'd have known better
Wogri
__________________
http://www.wogri.com
wogri is offline   Reply With Quote
Old 2005-01-31, 10:36 PM   #7
DigitalDave
Unicyclist
DigitalDave's Avatar
hmmm ... any of you guys seen the 'charging unit' part of that kit posted available for sale ...?
Cuz, I still have a generator that I've had since I was a kid that still works.
I believe it supplies the same volts/amp as the one in the kit.
Thx in advance.
__________________
My will to live was stronger than my will to die. - Iggy Pop
That which does not kill me, makes me stronger. - Friedrich Nietzsche 1899
If it's popular, then what's it got to do with us? - Mens room wall
My Gallery
DigitalDave is offline   Reply With Quote
Old 2005-01-31, 10:37 PM   #8
john_childs
Guinness Mojo
john_childs's Avatar
I'd be concerned about how well it can charge the battery. It probably doesn't give a constant charge to the battery which could be bad for the rechargeable batteries. It might lower the useful life of the batteries. Could it end up over-charging the batteries?
Will the PPC be able to run off the external power? Will the Pedal Power thing give a consistent enough source of power so the PPC can run off the external power? Can the PPC switch from external power to battery power on the fly (for example when you stop pedaling)?
What happens if you run the Pedal Power backwards during an idle?
I'd also be concerned about the durability of the PPC. Those things aren't made to take rough or outdoor treatment.
The thing would probably be better suited for a 29er or a Coker on the roads (asphalt).
__________________
john_childs (att) hotmail (dott) com
Team Never Wash Your Muni
My Gallery :: Unicycling Bookmark List :: World Clock
john_childs is offline   Reply With Quote
Old 2005-01-31, 10:39 PM   #9
DigitalDave
Unicyclist
Quote:
It's AC current ... so doesn't matter.
I'm assuming it's got a capacitor to hold a converted DC charge.
__________________
My Gallery
Old 2005-02-01, 03:48 AM   #10
Ken Cline
Newsgroup User
Posts: n/a
"Seager" <Seager@NoEmail.Message.Poster.at.Unicyclist.com> writes:
Not so. High capacity alkaline AA cells have more charge (2850 mAh)
than high capacity NiMH AA cells (2300 mAh). Not only that, but some
equipment (especially high current equipment like my Nikon Coolpix
800) can't cope with the lower voltage (1.2V vs. 1.5V) of nickel
chemistry batteries.
Rather than dragging the wheel with a generator, I'd look into hooking
up a rechargeable (gel-cell or external NiMH pack) battery to the
computer/GPS.
Ken
Old 2005-02-01, 10:58 AM   #11
Seager
Seager's Avatar
Re: Re: Dynamo on a Uni for GPS/PPC power
Ken
My Nikon Coolpix 950 ran off low mah nimh much better than it did Alkalines (10 hour battery life vs 3 hour) and this was with the nimh technology they had 3 or 4 years ago. They're much better now.
Different experiences I guess.
Old 2005-02-02, 03:23 AM   #12
Ken Cline
Newsgroup User
Posts: n/a
I am skeptical of those numbers, but it is possible that your Nikon
draws more peak current than an alkaline battery can supply. If that
is the case, then Nikon had no business designing the camera to use AA
cells in the first place. More likely, you were using regular
alkaline cells instead of the "ultra" version, or you tried anemic
rechargeable alkalines.
But the facts remain: High energy alkalines offer 20% more charge
(mAh) than the best NiMH and higher voltage. Except for applications
where internal resistance becomes an issue (i.e. devices which drain
the battery in less than an hour or have high peak current
requirements) the alkalines win. Even so, I use NiMH rechargeables
for economy, conservation, and projects with heavy current loads.
Ken
Old 2005-02-02, 08:03 AM   #13
Klaas Bil
Newsgroup User
Posts: n/a
>(mAh) than the best NiMH.
I was skeptical (triggered by the word "facts") and did some Google
research. And found it's true. While NiMH AA size are already sold in
2500 mAh nominal capacity, the best Alkaline AA cells come out at 3100
mAh. 24% more (and then there's the higher voltage).
Klaas Bil - Newsgroup Addict
It's impossible to get old when you ride a unicycle - John (what's in a name) Childs
Old 2005-02-03, 07:38 AM   #14
Klaas Bil
Newsgroup User
Posts: n/a
I wrote that as an aside, as in "so the energy content is even
higher". But on reflection, the higher voltage of Alkaline cells might
mean that the current drawn by the equipment is that much higher too.
So unless your equipment actually needs the higher voltage, it might
be a disadvantage and the running times of NiMH and alkaline would
come out quite close.
But I'm not a battery expert. Thoughts anyone?
Old 2005-02-03, 01:12 PM   #15
mikepenton
Unicyclist
mikepenton's Avatar
It shouldn't over-charge the batteries, as an indicator light changes when it's fully charged. If it's plugged in & the car engine's off it still works on internal batteries OK.
If it gives enough power, and what happends it if runs backwards, those questions I'm not sure about. I've contacted the manufacturers about the output (without response). As Dynamos have no strict instructions on mounting, I assume that they could rotate in either direction.
True to form, a good question and one that I had not thought of! Thanks John!
Reply
Tags
dynamo, gps or ppc, power, uni
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright © 2001-2019 Gilby
Page generated in 0.14557 seconds with 10 queries
