Unicyclist Community
Reply
Old 2004-08-10, 04:29 AM   #1
Scott Stephens
Equipment Destroyer
Scott Stephens's Avatar
Send a message via AIM to Scott Stephens
Remember Me?
Hey everybody, Remember me? I havent posted in a while, and ive become much more of a lurker, but the time has come to stop lurking. I stopped pretty much, and then a couple weeks ago i took my onza to work, and after doing some drops and gashing my legs open again, I realized I had forgotten just how fun unicycling can be.
On another note, the reason I am posting is because my muni,( A yuni muni with regular 175 cranks) the uni cranks keep coming loose. No matter how many times i screw them in or bang them with a hammer, within a few minutes they are loose again. I dont want to use Loctite, unless I really have to so does anyone have any ideas so I can get back on the trails ASAP?
__________________
If it weren't for electricity we'd all be watching television by candlelight."
George Gobol
I have worked too hard to be a clown. I am an athlete and wish to be respected as one.- Checkernuts
Scott Stephens is offline   Reply With Quote
Old 2004-08-10, 04:39 AM   #2
munimanpete
the unicycling kiwi
munimanpete's Avatar
Re: Remember Me?
Quote:
hmmm I don't think thats going to be doing them much good.......
munimanpete is offline   Reply With Quote
Old 2004-08-10, 04:47 AM   #3
Scott Stephens
Equipment Destroyer
sorry if that was vague, what I meant by that is get a malet and a piece of wood then put the wood over the crank and use the malet to hit it on farther so u can screw it on tighter
__________________
George Gobol
Old 2004-08-10, 07:45 AM   #4
one wheeled stallion
Guerilla Unicyclist
one wheeled stallion's Avatar
Just lube the spindle and cranks and also the thread of the nut/bolt and tightened her up!
__________________
OWS
"...I explain briefly to him that such conduct leaves him vulnerable to accusations of being an idiot. We part as enemies" - Mikefule
one wheeled stallion is offline   Reply With Quote
Old 2004-08-10, 10:54 AM   #5
onewheeldave
Semi Skilled Unicyclist
onewheeldave's Avatar
I find that lubing the spindle with vasaline and hammering on, works fine with my muni (a nimbus/yuni with 150 mm cranks)
The lube enables the crank to go further onto the spindle.
I think it's important to carry a bolt wrench on all rides for at least a few days after though, just in case they do come losose, as riding with a loose crank can wreck the uni.
__________________
"You can't outrun Death forever.
But you can make the Bastard work for it."
--MAJOR KORGO KORGAR,
"Last of The Lancers"
AFC 32
onewheeldave is offline   Reply With Quote
Old 2004-08-10, 11:14 AM   #6
Guerilla Unicyclist
That's sound advice, ride a bit, check them if necessary tighten. They should be on firmly after a couple days.
__________________
OWS
Old 2004-08-10, 12:10 PM   #7
Krashin'Kenny
Crash Tested
Krashin'Kenny's Avatar
Hey Scott,
Glad to see that riding again. I would imagine that being as your cranks won't stay tight, regardless of what you do, that the square tapers have become wallowed out. I'd try some of the suggestions listed above, but more than likely, you're going to have to replace the cranks pretty soon. I'm looking forward to riding with ya' again when you get a chance.
__________________
If you ain't crashing, you ain't going fast enough!!!!!!!!!!!
Krashin'Kenny is offline   Reply With Quote
Old 2004-08-10, 12:55 PM   #8
S_Wallis
S_Wallis's Avatar
Scott, good to see you back on the forum! I got your email this morning. Like Kenny said, you are going to have to replace the cranks because they ran loose too long. I have some bike 175's with the spider removed that I can give you if you can't buy new cranks right away. And I imagine yours are actually 170's. If you come to my shop we can put the cranks on before we go ride. Looks like we may get rained out this week though.
I am looking forward to finally riding with you again.
Scott
__________________
------------Use my Email, not PMs please--------
S_Wallis is offline   Reply With Quote
Old 2004-08-11, 06:08 AM   #9
Klaas Bil
Newsgroup User
Posts: n/a
Re: Remember Me?
Sure do. I'm an old dog on this forum by most standards.
>trails ASAP?
You probably need new cranks. And never bang hard on cranks with a
hammer, wood in between or not. That's going to cause microcracks in
the corners of the square hole which then are going to widen and
propagate when you put force on them through riding. With your new
cranks, put grease on the square tapers and on the crank nut thread.
Use a hammer only, if desired, to GENTLY tap the crank onto the taper
- usually even this is not needed. Then 'slowly' tighten the nuts -
ideally to a torque of 40 lb.ft I think (which is quite tight) but
don't take my word for it. On your first few rides, carry a wrench and
check the nuts from time to time, again ideally to 40 lb.ft. Be alert
to loose cranks during the ride and fix immediately.
Klaas Bil - Newsgroup Addict
I like the idea of not having to balance when out on a ride - joe
Reply
Tags
remember
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright © 2001-2016 Gilby
Page generated in 0.06893 seconds with 9 queries
