Unicyclist Community
Reply
Old 2017-09-05, 07:48 AM   #1
kahunacohen
Unicyclist
kahunacohen's Avatar
Tubeless 27.5
What would it take to go tubeless on a stock 2016 kh 27.5?
__________________
KH20 Street, 110/127 Moments with rollos
Stock KH27.5 with Black Street Saddle
Oracle 36/Oregon Hub, 127/150 spirit
kahunacohen is offline   Reply With Quote
Old 2017-09-05, 02:13 PM   #2
kahunacohen
Unicyclist
According to this the rim is tubeless compatible: http://www.unicycle.com/kris-holm-27...55mm-rim-2017/. That's 2017 though. Mine is a 2016. Havok seems tubeless compatible too: http://bicycle.kendatire.com/media/2...spec_sheet.pdf.
The problem here in Israel is lots of nasty thorns. I rarely have had flats before. Now without sealant I have one every few weeks. On inspection they are not pinch flats but very small pin pricks. And sometimes I actually see the thorn in the tire. The other advantage of tubeless would be that the correct innertubes are hard to come by here. I found a good shop and they only want about $25 to convert it. Seems worth it to me.
__________________
Old 2017-09-06, 01:04 AM   #3
jaco_flans
Trials & Muni!
jaco_flans's Avatar
Send a message via MSN to jaco_flans
The 2016 drilled rim isn't tubeless ready. There are ways to make non-tubeless rims work but it's more work, and you usualy have to ride it with higher pressure than you would on a true tubeless rim.
What makes it tubeless vs non-tubeless is the rim profile on the inside. A tubeless rim will hold the tire on the sides of it, even without pressure. A non-tubeless rim is made like an arc on the inside, only pressure holds it on the sides of the rim.
Look up on youtube, there are several ways to make non-tubeless rims work as tubeless. I personnaly dont bother when it's not meant for it, it's either an excuse for another wheel or just pure lazyness hahaha.
__________________
Jakob F.
jaco_flans is offline   Reply With Quote
Old 2017-09-06, 07:43 AM   #4
kahunacohen
Unicyclist
Thanks for the info. So I guess the 2017 rim is tubeless ready? Actually after researching it a bit I think it's probably more trouble than it's worth. I'm kind of into simplicity and don't love the idea of having more complications when trying to change the tire. I'll stick with the tube for now and try taking out the valve core and putting in some sealant. Hopefully that will help with thorns.
__________________
Old 2017-09-06, 08:22 AM   #5
kunstrasen
Unicyclist
You could use a system like Schwalbe Procore. Due to its construction the tire is securely fixed to the rim. As a result you can run as low pressure as you like even on a standard rim. Even with an unridable low pressure you wont have any burping.
kunstrasen is offline   Reply With Quote
Old 2017-09-06, 07:00 PM   #6
Alice Arctan
rhymes with dark tan
Alice Arctan's Avatar
Procore still requires a tubeless rim.
Alice Arctan is offline   Reply With Quote
Old 2017-09-07, 05:52 AM   #7
kunstrasen
Unicyclist
No, it does not have to be a tubeless rim. Of course you have to seal the rim if it is a standard rim (e.g. with a tubeless rim tape). My point is that Procore overcomes the disadvantages of standard rim design as mentioned by Jakob. It will securely connect the tire to the rim so that you can run any desired pressure.
Reply
Tags
275, tubeless
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Tubeless knoxuni General Unicycling Discussions 23 2011-03-30 07:03 PM
Tubeless 36 ??? Tucson Uni General Unicycling Discussions 6 2010-12-04 02:23 AM
Tubeless TA, anyone? joshben General Unicycling Discussions 16 2009-03-30 10:17 PM
Tubeless, anyone? JesseG General Unicycling Discussions 15 2008-10-21 12:05 PM
tubeless? snuffiluffigus General Unicycling Discussions 3 2006-03-28 09:48 PM
Powered by vBulletin®
Copyright © 2001-2016 Gilby
Page generated in 0.05838 seconds with 11 queries
