Unicyclist Community
Reply
Thread Tools Search this Thread Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 2010-11-20, 11:28 PM   #1
gunnstein
The Univiking
gunnstein's Avatar
Dear Dr. Uni, what is wrong with me?
Hello fellow unipilots, I'm hoping you can help me with the following problem: I'm not straight.
Well, to explain: I started riding in July. During autumn I have gotten to the point where I can ride over 20 km on my 29er. Only problem is, most of the time I have to ride with my right arm in front of me and the left arm somewhat to the side. If I try to hold them symmetrically, the uni starts turning to the right. Weird!
Last week I replaced the Duro (Big Apple clone) with the Nokian Extreme studded winter tire, which is very knobbly and has lots of studs. Grip is excellent, but it made my problem worse, to the point were I find it very hard to ride in a straight line for more than 100 meters. Often I find myself leaning strongly to one side, and when I try to straighten up the Uni turns and/or I UPD. Today I even felt a bit of the same on my 20" which has been unaffected until now.
I tried:
- checking that the seat is not twisted
- checking the wheel is true (had it trued, no change)
- keeping my feet in the same position on the pedals, as accurately as possible
- holding the seat when riding (made it worse)
- checking that I am sitting straight on the seat (feels so to me)
It must sound really silly and I'm sure it looks silly too. It's frustrating since I thought I had pretty good progress but now it is regressing, and holding me back from long distance rides. Am I going crazy? Please tell me there is something obvious I have forgotten!
__________________
Experienced noob with nimbus 24" muni, nimbus 29", and nimbus impulse 36"
http://twitter.com/glye
http://www.flickr.com/photos/gunnste...tags/unicycle/
gunnstein is offline   Reply With Quote
Old 2010-11-20, 11:59 PM   #2
Klaas Bil
Sir Prince of Newsgroupia
Unfortunately, there is not simply something obvious you have forgotten to check, you've looked at the most obvious potential causes already. This is a rather common problem and it can be quite difficult to fight. Sometimes it goes away with more experience, but until now this doesn't seem to work in your case, rather the opposite is true for now.
Some additional things to check / think of:
  • If the road surface slopes to the left or right, this may push you in one direction. Many roads are slanted (it's also called road crown), to allow water to flow to the side. Sometimes it's almost to small to see, but on a uni you will still feel it. Ride in the opposite way (against traffic) to check. This is a fairly common cause for riding crooked.
  • Some tyres are more sensitive to road crown than others. The Schwalbe Big Apple 2.35" is infamous in this respect. A narrow rim doesn't help either.
  • Higher tyre pressure makes the influence of road crown less.
  • Your wheel may be true now, but is it also not dished? A dished wheel has the hub not in the centre plane but offset to the left or right. Temporarily mount your wheel backward to check if the rim is still in the middle of the frame. (Don't forget to turn back.)
  • Is your frame straight?
  • Are the two legs of your frame of equal length? Otherwise even a true and non-dished wheel would tend to one side. You can remedy this with a shim in your bearing holder.
  • Is your seat (in addition to being mounted straight) itself symmetrical? Both in shape and in elasticity?
  • Maybe your body (legs and/or something else) is asymmetrical? You might be able to compensate with an inlay in your shoe, but consult a sports medical person first.
O wait, I got it. Norway huh? Maybe you are just too close to the North Pole (which rotates as everyone knows). Immediately stop unicycling or you might slow down the planet.
Kidding aside, I hope this helps.
Klaas Bil is offline   Reply With Quote
Old 2010-11-21, 12:48 AM   #3
Pseudonym
Invisible Pink Unicycle
Pseudonym's Avatar
gunnstein, are you watching Desert bus?
Pseudonym is offline   Reply With Quote
Old 2010-11-21, 12:56 AM   #4
ally1776
UniMudder
ally1776's Avatar
Send a message via Yahoo to ally1776
Quote:
Klass Bil you are so right. I have a couple paved trails that bothered the heck out of me as to why I was fighting so badly to keep straight when I usually didn't have that problem, until I realized what was going on with the slanted surfaces.
__________________
My Facebook Page
My Twitter Page
I plan on riding unicycles till I break a hip and then I'll ride a little longer.
ally1776 is offline   Reply With Quote
Old 2010-11-21, 01:40 AM   #5
SmellyGeekBoy
"The dude that went to India"
SmellyGeekBoy's Avatar
Location: Leicestershire, UK Unicycles: 12" Bunnycycle, 24" Qu-Ax Cross
If the seat is straight (and you say it is), it's probably either the camber of the road or a natural lean / muscle imbalance which is extremely common in newbies. Either way, your body will learn to compensate and adjust given enough hours in the saddle.
Be absolutely certain that your seat is straight before you come to this conclusion, though. I find that more than a few mm either way throws my balance off a lot.
__________________
This is how I roll
SmellyGeekBoy is offline   Reply With Quote
Old 2010-11-21, 02:19 AM   #6
aarons
Eating a sandwich
aarons's Avatar
I had that problem as well. I rode with my left shoulder in front and my right shoulder behind. Since you're sure it isn't your unicycle, it must be your riding technique. Maybe this is how your muscles adapted to the tilt of the path or something, and your new tire made it worse.
If I were you, I'd change back to your other tire.
You may have to force yourself to ride straight until it becomes second nature. For me, it helped a great deal to ride with handlebars because this made me control with my feet. It took more than 2 weeks of awkward riding to get comfortable this way, but it was worth the effort.
I know you've already tried riding with your hands on the seat, but it might help if you give it more time.
aarons is offline   Reply With Quote
Old 2010-11-21, 03:08 AM   #7
unireed
Reed Breuer
unireed's Avatar
if you are on a flat road, just ride more. if you need to use your arms to balance still, you arent good enough yet. by that i mean you should practice riding more without needing arms
__________________
"I'm probably not advanced enough to have thoroughly tested it while riding, but I'm unadvanced enough to have very thoroughly tested it while falling." -uniShark
I ride for Christ-opher Walken
unireed is offline   Reply With Quote
Old 2010-11-21, 03:18 AM   #8
nordicnoel
How many wheels today?
nordicnoel's Avatar
Klaas Bil gave some good answers.
I had that problem intermittently since learning to ride late this spring. It was more of a problem on roads than muni. One day I couldn't make it out of the neighborhood without falling off my uni, but was able to ride a long way on my brother's uni. I then realized that my particular tire/rim/weight combination on a cambered road required a very narrow range of pressures. Outside of that range I lean like crazy and randomly fall off, but within the pressure range I can ride for a couple hours.
nordicnoel is offline   Reply With Quote
Old 2010-11-21, 03:30 AM   #9
AustinLee
Unipsychle Productions
AustinLee's Avatar
It is very likely that it is the slope of the road, unless it is perfectly level.
Another, yet unlikely, explanation could be that you turn more often to one side, wearing one side of the tire down more, causing the uni to pull in that direction.
Maybe try a friend's uni?
__________________
"Light a man a fire, and he will be warm for a day. Light a man on fire, and he will be warm for the rest of his life."
"'Your' and 'You're' are sworn enemies. If you misplace them, it could lead to violence."
My Youtube
AustinLee is offline   Reply With Quote
Old 2010-11-21, 07:21 AM   #10
johnfoss
North Shore ridin'
johnfoss's Avatar
Quote:
No road is perfectly level. If it's a proper road, and you ride on the right-hand side, you will tend to have to twist to the left. Even the bike path I prefer riding on has tilt. It is almost always tilted slightly to one side or the other, to allow it to drain.
If you know it's a camber problem, try turning your seat a little bit to the left; maybe 5-10 degrees. But that only works if you always ride on the camber. I've used it for track racing, and for some road riding events where I knew I'd always be on the right side. Even in Ride The Lobster, I felt fastest if I rode in the center of the road (which we weren't supposed to do).
Other factors can contribute to this. Tire is a big one, so I suggest trying a different one. Others are in your body; if your spine is a little out of alignment, legs aren't quite symmetrical, etc. Those things generally fix themselves (at least in terms of unicycling) with time. To speed the process, you can practice riding in big right-handed circles.
__________________
John Foss
www.unicycling.com
"Who is going to argue with a mom who can ride a unicycle?" -- Forums member "HiMo"
johnfoss is offline   Reply With Quote
Old 2010-11-21, 07:32 AM   #11
leo
Vandewoestijne
leo's Avatar
Quote:
It would be dangerous and highly errosive and therefor economical stupid to make a road perfectly flat. With maybe an exception for the fast-absorbation type of aphalt, but I can't recall I've ever seen that on a normal road (though I have been unicycling on it!).
__________________
unicycle.show
unicycle.blog
unicycle.builders
+1 866 UNI-CYCL
leo is offline   Reply With Quote
Old 2010-11-21, 08:04 AM   #12
Klaas Bil
Low pressure makes the sensitivity to road camber worse. You mention a requirement for a range of pressures. So are you saying that increasing the pressure above that range made the sensitivity higher? Or did the pressure range only have a maximum because of the pressure rating of the tyre?
Old 2010-11-21, 09:28 AM   #13
Sanne.Kj
56 blood donations :)
Sanne.Kj's Avatar
Hello Gunnstein
I had similar experiences with a new muni (http://www.unicyclist.com/forums/sho...46#post1403146)
- an my conclusion is: Don't have a very high pressure in the tyre. For me it was the combination of knobby tyre and high pressure that made me turn right. I think I was not heavy enough to "flatten" the tyre - so I kind of balanced on top of the knobs instead.
But well. Maybe it's different for long distance riding.
Best regards,
Sanne
PS. And I'm not straight either.
Sanne.Kj is offline   Reply With Quote
Old 2010-11-21, 09:39 AM   #14
minkuni
Meat popsicle
minkuni's Avatar
Hey gunnstein, keep working at it. I have been through exactly the same challenging period as you, so I know what you are struggling with. I can only say that experience makes it easier so just keep at it!
The one thing you should check is seeing if the saddle frame/mold is straight. The KH Freeride saddle that came with my Nimbus 36 was molded slightly skewed, making the saddle tilt to the side and backwards to a slight degree. This was VERY unnerving to ride on even though it didn´t look too far off right...
The Nokian Extreme is an excellent choice for icy Norwegian winter roads and trails. I am actually looking forward to putting it onto my Nimbus 26 and going out riding in the winter wonderland again
Studs! by minkuni, on Flickr
minkuni is offline   Reply With Quote
Old 2010-11-21, 10:46 AM   #15
gunnstein
The Univiking
gunnstein's Avatar
Wow, that's a lot of response. Thanks all. I am clearly not alone!
Klaas Bil: That's quite a checklist, great thanks for taking the time!
- Road slope is definitely a factor. Riding on the left side feels better. (without condoning British driving...)
- Tires, yes. The rim is 39 mm (outer width), so AFAIK it is wide enough for the 2.35" Duro and 2.1" Nokian.
- Tire pressure: Some say increase, some say decrease. I tried near minimum yesterday, which felt quite bad. Will try maximum next time.
- Dish: I'd trust the skill of the bike mechanic, but I could check this of course.
- Frame: Another reason to remove the wheel. Would make it easier to check fork leg length.
- Seat shape and condition: Good point, I'll have a closer look.
- Body: I'm pretty sure my legs are the same, otherwise I should have developed hip or leg problems by now. I walk and bike a lot.
- Earth rotation: Possible. How about the earths magnetic field? The uni is steel, I'll get a non magnetic aluminium frame next time
__________________
Reply
Tags
balance, dear, tire, uni, wrong
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
What should I look for, and what is fair gratefulbruce General Unicycling Discussions 10 2010-11-18 07:04 PM
Show me what you got tr4nspo Unicycling Videos 0 2010-10-16 07:21 PM
so this is what a 500+ dollar unicycle rides like :] daveykim General Unicycling Discussions 2 2010-09-28 08:06 AM
I just bought me a brand new... Thorvald General Unicycling Discussions 1 2010-09-13 11:34 AM
unicyclists with skills v. unicyclist with tricks leo General Unicycling Discussions 13 2010-09-11 07:33 PM
Powered by vBulletin®
Copyright © 2001-2019 Gilby
You Rated this Thread:
Page generated in 0.12529 seconds with 11 queries
