Unicyclist Community
Reply
Old 2004-07-19, 05:04 AM   #1
juggle508
805elgguJ
juggle508's Avatar
Send a message via AIM to juggle508
Question Nimbus Cranks.
Ok I want to buy the Nimbus trials unicycle. I have heard that the cranks are pretty weak. I don't have much money so which ones are better? The bicycle euro's or the Nimbus X's? I don't have enough money to buy a splined set so which one out of these two? Ok say I got the KH cranks would they fit on a nimbus axle?
__________________
Kris Holm Unicycles. www.krisholm.com
juggle508 is offline   Reply With Quote
Old 2004-07-19, 06:14 AM   #2
daino149
On Vacation - till i find a job
daino149's Avatar
Send a message via AIM to daino149
I haven't used either the Nimbus or the BEs, but I heard good things about both.
I do know that KH cranks (or any other splinded cranks) will NOT work on the Nimbus axle.
Daniel
__________________
OPPORTUNITYISNOWHERE
daino149 is offline   Reply With Quote
Old 2004-07-19, 07:42 AM   #3
one wheeled stallion
Guerilla Unicyclist
one wheeled stallion's Avatar
I had the standard cranks on for a while and they held up fine until I got splined set up. The Bicycle Euros are pretty good, I had them on my muni before I got a KH set, though I did bend two sets, though they were 150s and 170s. I *think* the Nimbus X cranks are lighter, but apart from that I don't know.
__________________
OWS
"...I explain briefly to him that such conduct leaves him vulnerable to accusations of being an idiot. We part as enemies" - Mikefule
one wheeled stallion is offline   Reply With Quote
Old 2004-07-19, 11:31 AM   #4
tom_edmonds
Finally...less talking, more riding
tom_edmonds's Avatar
the BE 125's take awhile to bend but once they start going they go quickly or mine did, i went through 2 sets, theyre cheap and good value though.
for the price of the nimbus x cranks in addition to the nimbus trials uni cant you get a Qu-ax splined trials uni, well more or less anyway?
__________________
Got me another 28" uni
tom_edmonds is offline   Reply With Quote
Old 2004-07-19, 01:26 PM   #5
muniracer
Hell On Wheel
muniracer's Avatar
Send a message via AIM to muniracer
i have found that square tapered cranks are really unreliable. I have had Sun generic cranks that lasted for months, United cranks that lasted for under an hour, and BE cranks that lasted for a weekend. I have the nimbus x cranks on my muni right now and have ridden muni maybe four or five times with them. they have not bent yet, but still they have lasted longer than the United cranks and about the same as the BE cranks.
so my suggestion is for the nimbus x cranks, but if you did a poll, i think more people would suggest the BEs.
plus, try searching for threads about this, as there are quite a few. there are probably some one the first or second (or third) page of the Product Reviews section.
__________________
The Hell on Wheel Unicycle Gang owns you!!
http://www.unicyclist.com/gallery/albuq25
muniracer is offline   Reply With Quote
Old 2004-07-19, 02:08 PM   #6
digitalattrition
GET IN THE VAN!!!!
digitalattrition's Avatar
Send a message via AIM to digitalattrition
I'm more worried about the KH cranks fitting the frame. It seems that something with a 140mm length will hit the frame when they reach the top of a rotation. The reason I say this is because the Nimbus frame gets wider further up the frame. I'll have to test that out some time, unless one of you guys know what the deal is.
Back on topic: The stock Nimbus cranks on the Nimbus trials are pretty good, but they will bend if you do more than a few big drops. The Nimbus X cranks are stronger, but will bend in the same fashion as the originals. I'd say just save up around $200 and get a splined hub and crank set. I have not used the BEs, so I cannot offer an opinion.
__________________
"When life hands you a lemon, say 'Oh yeah, I like lemons. What else you got?'"
-Henry Rollins
digitalattrition is offline   Reply With Quote
Old 2004-07-20, 03:32 AM   #7
unicyclistjoe
Gapping Machine
unicyclistjoe's Avatar
Send a message via MSN to unicyclistjoe
Quote:
Daniel
thats wrong, i have KH crank and hub on my nimbus, and it goes perfect, i had 2 put in a couple of extra spacers to make the bearings fit the frame a bit better, but i have had no real dramas.
my 140s dont hit, but it is very close, maybe about 4mm clearances, but it doesnt seem to have any effect otherwise
__________________
NZUni President
94cm Highest Hop
287cm Longest Hop
205cm Static Flat Gap
unicyclistjoe is offline   Reply With Quote
Old 2004-07-25, 08:59 PM   #8
digitalattrition
GET IN THE VAN!!!!
Do you mean you have the KH splined cranks and regular nimbus hub or that you have a KH splined hub and crankset?
__________________
-Henry Rollins
Old 2004-07-26, 12:45 AM   #9
unicyclistjoe
Gapping Machine
lol whoops! im a stupid idiot, i read that wrong. i read it as if you meant that an ENTIRE splined hub and crankset wouldnt work....i have the full set. now seeing what you meant, no splined cranks wouldnt work on the axle
__________________
NZUni President
94cm Highest Hop
287cm Longest Hop
Reply
Tags
cranks, nimbus
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright © 2001-2016 Gilby
Page generated in 0.06157 seconds with 10 queries
