Unicyclist Community
Reply
Old 2012-05-18, 08:58 PM   #1
Zagira
Jeff Hanson
Zagira's Avatar
Handle Bar Suggestions?
I currently have a Coker Handlebar with some areobars attached. I like the vertical adjustment and the areobars added significant length, but it needs to be longer.(can post pics later)
My problem is I cant figure out what to buy to make it longer and keep it adjustable.
The KH seems it would work great(with a longer post), but then I couldn't get a more comfortable seat ever.
The Nimbus seems non adjustable, complicated and expensive. It also removes the possibility of rail type seat?
So I am looking for a way to get my bars further out with parts I can buy or scrounge off some bikes etc.(i.e. no welding or vframe stuff). Please let me know if I've misjudged anything.
Zagira is offline   Reply With Quote
Old 2012-05-19, 04:51 AM   #2
Vee
The Unsung Uni-Hero
Vee's Avatar
This is from Terry Peterson. It sounds like what you are looking for.
Vee is offline   Reply With Quote
Old 2012-05-19, 09:53 AM   #3
Zagira
Jeff Hanson
Zagira's Avatar
Hey thanks that will definitely give me something to work with for a bit.
Old 2012-05-19, 11:25 AM   #4
Zagira
Jeff Hanson
Zagira's Avatar
Ok so I am looking at something like this:
http://www.controltechbikes.com/test....asp?pro_id=51
It is adjustable, only need to buy one thing, and I can find it on amazon.de.
My only concern is the clamp widths, the one I found says
Seatpost - 29.8 mine is 25.4
Bar - 25.4 mine is 22.5..
Is there any chance of these tightening down to my width?
What about some spacers?
I really cant find anything this shape with a 25.4 seatpost clamp. :/
Old 2012-05-19, 01:42 PM   #5
jtrops
Unicyclist
You would need shims to get the different pieces to fit together.
When I had my PI Bar I considered making an extension for it using a Torker Brake Mount. I never got around to trying it, but it still seems like a good way to go, and similar to Terry's in adjustability. It's also under $6 on Amazon. The shim could cost you a few dollars more, but still not that much. It has a 25.4 clamp for the seatpost. To make it work with the PI bar you will also need a 22.2-25.4 shim. It would be adjustable by moving the Coker stem along the boom of the extension. Here's a photo of the Torker mount:
__________________
"A properly ridden unicycle is like an object in orbit: constantly falling but never landing." -Diogenes
jtrops is offline   Reply With Quote
Old 2012-05-19, 04:28 PM   #6
Zagira
Jeff Hanson
Zagira's Avatar
Hey that looks great, especially the price! But, I don't know how you would clamp an extender into it, and I can't tell how much length it adds itself. But also, I don't know where to find torker parts outside of the US, and I am currently in Germany..
Old 2012-05-19, 05:11 PM   #7
Zagira
Jeff Hanson
Zagira's Avatar
Right so those are only 125mm, and I would want to be able to make it longer.
I did notice that Terry's also doesn't need a clamp for the extender.. I'm not totally sure how those work, but do they just keep themselves tight in there when you twist them? If so,then I will try to find something like that.
Old 2012-05-19, 05:24 PM   #8
jtrops
Unicyclist
The idea with the Torker piece is that you clamp it to your seatpost, and then use the stem on the PI Bar attached directly to it. So in effect you could move your handlebar 100+ mm's further from your seatpost than it is currently.
The ControlTech stoker stem replaces your coker stem. it includes both the boom part and the part that clamps to the PI Bar.
If you could find an old frame made to fit a 25.4 (1") seatpost you could scavenge the toptube/seat cluster from it, and make your own boom. The advantage here being that you could make it as long as you wanted, and that a lot of old road bikes have a 25.4 top tube that the Coker stem will clamp onto without a shim. If you did it this way you could have it done with no cash out of pocket, but some time with a hacksaw.
__________________
Old 2012-05-19, 06:08 PM   #9
Zagira
Jeff Hanson
Zagira's Avatar
I got the idea with the torker, just that 100ish mm isn't so worth it.
And with extending, I was wondering about these things:
Which terry had in his video, but I'm not sure how they attach. If they are meant to be clampless, then that would be the way to go.
Old 2012-05-19, 10:22 PM   #10
MuniAddict
UniGeezer - Not "2" Tired
MuniAddict's Avatar
This is my current mod, which I like much better. It's also a lot lighter than then my previous mod with the stoker stem.
__________________
Happy Birthday Terry! Every year you get cooler, younger and unicyclier!
Be our muniprohpet for many years more.
-Dani Buron
Website
Videos
Facebook
MuniAddict is offline   Reply With Quote
Old 2012-05-20, 09:01 PM   #11
rogeratunicycledotcom
Mostly OKish Unicyclist
I know slightly off topic... but I thought you may like to see the latest UDC handle bar.
__________________
Roger Davies
Unicycle.com in the UK
The UK's Unicycle Source
www.unicycle.co.uk
rogeratunicycledotcom is offline   Reply With Quote
Old 2012-05-23, 08:45 PM   #12
Zagira
Jeff Hanson
Zagira's Avatar
Hey terry that does look nice. My only issue would be having to get rid of it if I wanted a new seat.
I was still hoping someone could explain to me how the stem raiser quills stay in tight.. I didn't see it tightened in the video exactly, for time purposes I guess.
Roger: Yes I do! Slightly off topic is fine here..
Looks sweet. Also can you get it goin without the back wheel?
Old 2012-05-23, 08:57 PM   #13
Thank you.
Not on purpose. You get more control down hill when you are closer to unicycle balance and several times I had the wheel just off the ground... but it is scary!
__________________
Roger Davies
www.unicycle.co.uk
Old 2012-05-23, 09:18 PM   #14
Milosboy
Live every week like its shark week
Milosboy's Avatar
Quote:
Originally Posted by rogeratunicycledotcom View Post
Thank you.
I'd imagine. That wheel has to be close to 60".
__________________
Happy cows come from California. Then at one point, PETA got into the mix and claimed that California cows were not happy. Of course, being the animal experts PETA aren't, they were unable to quantify any method of detecting cow happiness. - JF
Milosboy is offline   Reply With Quote
Old 2012-05-23, 09:22 PM   #15
no, it is a 51". It is the biggest I can ride.
We have produced 3 of them, 2 at 51" and 1 at 54".
We were racing at the Pennies in the Park event. We came 2, 3rd and 6th. Not bad for first outing.
Roger
__________________
Roger Davies
www.unicycle.co.uk
Reply
Tags
bar, handle, suggestions
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
The KH T-bar Touring Handle chazpantz General Unicycling Discussions 11 2015-05-07 03:49 PM
[For Sale: Europe] Nimbus shadow handle bar with 27.2 mm and 25.4 mm seat post. rvs Trading Post 2 2011-12-26 05:27 PM
[For Sale: Europe] Triton 36 inch+handle bar also sold in parts (Netherlands close to the german border) rvs Trading Post 0 2011-10-19 05:36 PM
[For Sale: Europe] Tritron 36 inch+Nimbus shadow handle bar (the netherlands close to the german border) rvs Trading Post 2 2011-08-30 05:41 PM
handle bar for nimbus 29 daveykim General Unicycling Discussions 11 2011-01-19 08:24 AM
Powered by vBulletin®
Copyright © 2001-2019 Gilby
You Rated this Thread:
Page generated in 0.29712 seconds with 13 queries
