Unicyclist Community
Reply
Thread Tools Search this Thread Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 2008-11-21, 12:37 PM   #1
wickedbob
Registered User
wickedbob's Avatar
Where to get ti Hardware/ kh bearing holders, seat post clamps/ seat bolts
Being a trials weight weenie, I would like to know where I could possibly get some ti hardware for my unicycle. Any bolt that can be replaced, I'm interested in, even axle haha, though I don't think they make those. Thanks for the help.
Btw, I'm not interested in ti parts like spokes and such. I'm also using Koxx seat post clamps, a kh o8 frame, and regular kh style seats.
wickedbob is offline   Reply With Quote
Old 2008-11-21, 12:46 PM   #2
kington99
Unicyclist
Send a message via MSN to kington99
you're going to be more specific about exactly which parts you want to swap, if bolts count but spokes don't it's not terribly clear. Also why Ti? It's certainly not the lightest material out there, for a fixed sized component like a bolt Al will be lighter.
__________________
Dave
- what a thoroughly post-modern subversion of the cycling genre -
kington99 is offline   Reply With Quote
Old 2008-11-21, 01:15 PM   #3
joemarshall
dumb blonde
There are 8 bolts on a unicycle - 4 on the bearing holders, 2 on the clamp, and 2 on the cranks.
If you do replace all 6 normal bolts on the unicycle with aluminium bolts, you'll save about 16g. You can also save 15g by changing the crank bolts.
Although weightweenies suggests to use titanium bolts for the scary bits - seatpost clamps etc. Which probably includes the crank bolts, but might not matter about the bearing holders. That'd reduce your weight savings to something more like 20g total.
http://weightweenies.starbike.com/articles.php?ID=16
It'd probably be much easier to cut some foam out of your seat for that amount of weight loss - KH seats have tons of padding in. Also, have you got lightweight pedals (something that takes a TI axle probably).
Or just go for a dump before you go riding / lose some weight.
Joe
joemarshall is offline   Reply With Quote
Old 2008-11-21, 01:27 PM   #4
joemarshall
dumb blonde
In terms of axle, obviously unicycle axles are not usually removable / replaceable, but you can get the titanium hub. Which would save you 200g. Probably on a money per gram saved basis that'd be more than the dodgy bolts. For example 2 crank bolts @ £10 each save you 12g that's 0.6g per £, whereas the hub is £225 saving 200g = 0.8g per £.
Joe
Old 2008-11-21, 08:33 PM   #5
wickedbob
Registered User
wickedbob's Avatar
Well, yes the bolts he said. I'm also going to get the ti hub, probably, I'm coming into some money since I should be getting a job sometime soon. So, anybody know where I can get the bolts?
Old 2008-11-21, 08:56 PM   #6
corbin
Treehouse Muni Rider
corbin's Avatar
Send a message via AIM to corbin
Actually, if you are a true trials weight weennie, just remove the seat. That'll save a ton of weight. Most trials riders hop seat out. You could replace the seat with a lightweight carbon fiber handle.
__________________
http://www.corbinstreehouse.com
maestro8 fan club
Justin LE fan club
corbin is offline   Reply With Quote
Old 2008-11-21, 09:00 PM   #7
pedrotejada
Europe Winter RoadTrip coming soon!
pedrotejada's Avatar
Send a message via ICQ to pedrotejada Send a message via AIM to pedrotejada Send a message via MSN to pedrotejada Send a message via Skype™ to pedrotejada
Quote:
easy: Ebay
__________________
Brazilian Unicycling Team
Gobble, Gobble!
pedrotejada is offline   Reply With Quote
Old 2008-11-21, 10:09 PM   #8
maestro8
is what it is
maestro8's Avatar
Quote:
This and many more tips have been posted in past threads. Check it out!
__________________
"The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt." - Bertrand Russell
maestro8 is offline   Reply With Quote
Old 2008-11-21, 10:18 PM   #9
saskatchewanian
ERIC P
saskatchewanian's Avatar
In addition to the bolts that Joe pointed out there are another 10 in the saddle.
Using a light weight tube and cutting off every second knobby can save a surprising amount of weight.
Don't forget to strip the paint off your frame
You could probably cut down or drill a bunch of holes in the rear bumper too.
saskatchewanian is offline   Reply With Quote
Old 2008-11-21, 10:40 PM   #10
Smilymarco
just call me similymarco
Smilymarco's Avatar
Send a message via ICQ to Smilymarco Send a message via MSN to Smilymarco
There is no need of a rear bumper
__________________
Riding for Triton
Supported by Municycle.com
Smilymarco is offline   Reply With Quote
Old 2008-11-21, 10:44 PM   #11
SkierAlex
Alex Grierson
SkierAlex's Avatar
Send a message via MSN to SkierAlex
Use a light weight tube. Don't waste your time doing any of the other things. Using a light tube can save 200g, all those toher things put together are unlikely to save 100g. Anyway, a few hundred grams is really insignificant, especially for trials.
SkierAlex is offline   Reply With Quote
Old 2008-11-21, 10:50 PM   #12
wickedbob
Registered User
wickedbob's Avatar
A few hundred maybe not, but 500 is a bound. It's not about taking 10g off in one place, it's the accumulative affect of it all.
Old 2008-11-22, 01:33 AM   #13
Jeremy R
onceuponatimetherewasaper son
Jeremy R's Avatar
Send a message via AIM to Jeremy R
cf base.
__________________
661
MountainUni
or make it a dinglespeed - saskatchewanian
Jeremy R is offline   Reply With Quote
Old 2008-11-22, 09:16 AM   #14
wickedbob
Registered User
wickedbob's Avatar
Already have two. Still need to drill one, I've had it for a year now.
I sure wish wallis would get making some again.
Old 2008-11-22, 07:28 PM   #15
Probailer2
Say no to drugs!
Probailer2's Avatar
Only use one CF base, will save you tons
Oh, and drill your bumper, looks cool to (I've done it)
__________________
Sponsored by www.municycle.com
Quote:
Originally Posted by JJuggle
If somebody cloned your mother would you have sex with the clone? I should think not.
Quote:
Originally Posted by Danni
I don't like having penis written all over my uni .
Quote:
Originally Posted by manon1wheel
no offense but deads look plain old gross...
Probailer2 is offline   Reply With Quote
Reply
Tags
bearing, bolts, clamps or, hardware or, holders, post, seat
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Screws for KH bearing holders => how-to? madc-ccc General Unicycling Discussions 3 2006-04-29 08:48 PM
where to get seat foam terrybigwheel General Unicycling Discussions 4 2006-01-12 05:46 PM
united seat post to kh seat lancerfan119 General Unicycling Discussions 5 2005-11-04 05:27 AM
rattling kh cranks; loose seat post bolts tennisgh22 General Unicycling Discussions 11 2004-07-03 07:54 PM
Seat Post Clamps Erin General Unicycling Discussions 7 2003-01-07 04:32 AM
Powered by vBulletin®
Copyright © 2001-2019 Gilby
You Rated this Thread:
Page generated in 0.08096 seconds with 11 queries
