Unicyclist Community
Reply
Old 2018-10-15, 07:04 PM   #1
Vogelfrei80
Beginner
29" frame with 26" wheel
Using a 29" Kh 2017 frame (it accept the Duro crux) how fat can it go using a 26"wheel?
Does the frame accept a 26x4? 26x5?
Vogelfrei80 is offline   Reply With Quote
Old 2018-10-15, 11:22 PM   #2
Strokin99
Unicyclist
Strokin99's Avatar
Not sure, but have you measured the inside of the frame? A simple measurement should tell you
Strokin99 is offline   Reply With Quote
Old 2018-10-16, 01:05 AM   #3
Vogelfrei80
Beginner
I'm too lazy! Tomorrow will try to measure it...
Old 2018-10-16, 05:09 AM   #4
DirtyPuddle
Unicycler
KH29 frame accepts 3.25" tires. 4" might squeeze through but probably a bad idea.
DirtyPuddle is offline   Reply With Quote
Old 2018-10-16, 10:02 AM   #5
finnspin
one wheeled cycling
finnspin's Avatar
Quote:
Well, that's assuming the numbers on the tire are actual measurements. In my experience, they aren't. A 2.5" wide tire is rarely 2.5" wide when mounted to the rim, some 2.4" marked tires are wider than some 2.6" marked tires. It's unfortunately not a simple measurement.
__________________
I do: Trials, Flat, Street, Downhill. Sometimes Freestyle.
finnspin is offline   Reply With Quote
Old 2018-10-19, 05:35 PM   #6
bodyjohn
Registered User
yep, strokin is right!
bodyjohn is offline   Reply With Quote
Reply
Tags
29 frame with 26, wheel
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Hatchet 29" vs 26" with fatty leadpan General Unicycling Discussions 2 2018-05-07 09:07 PM
Question: 29" wheel on an original Coker 36" frame Darth Elevator General Unicycling Discussions 9 2014-03-13 09:56 PM
[Wanted North America] OREGON or cage frame 26-29 w large wheel (3-4") iterk Trading Post 4 2013-03-25 11:36 AM
26" wheel in KH 29" frame? magicollin General Unicycling Discussions 5 2012-04-11 09:45 PM
Anybody use a 26" tube on a 29" wheel? Carey General Unicycling Discussions 20 2010-12-16 01:16 AM
Powered by vBulletin®
Copyright © 2001-2016 Gilby
Page generated in 0.08276 seconds with 11 queries
