Unicyclist Community
Reply
Old 2002-10-20, 08:02 PM   #1
JJuggle
Last of the Dogmato-Revisionists
JJuggle's Avatar
Send a message via AIM to JJuggle
Riding backwards
This is something of a "duh!" post, but still might be useful to some of the other slow learners, like myself, out there.
I have been struggling with riding backwards, making steady, but very slow progress over the past couple of years.
Today for some reason I sat firmly in the seat, i.e. as with riding forwards I keep my weight on the seat not the pedals, and wow, what a difference. I pretty much doubled my furthest backwards distance and the improvement in control is significant.
I think in struggling with the additional issues of not being able to see very well where I'm going and the fact that it is different from riding forwards, I simply forgot to apply the basics to riding backwards.
Raphael Lasar
Matawan, NJ
__________________
Raphael Lasar
To Plotz is Human
To Shvitz Divine
JJuggle is offline   Reply With Quote
Old 2002-10-20, 08:51 PM   #2
Mikefule
Bridge of Otherwhere: on Kindle
Mikefule's Avatar
Progress made slowly is all the more rewarding, or something like that...
My tip for learning to ride backwards is to develop it from idling in a step by step process:
Normal idling = less than half a revolution of the wheel each way.
Next step, I've heard called 'super idling' with more than half but less than a whole turn of the wheel. This means left foot starts at the bottom, comes over the top and the right foot hits the bottom (or vice versa) then back again.
Next step I've heard called 'mega idling'. More than a whole turn, so one foot starts at the bottom, goes over the top and stops at the bottom, then back.
Then you get to idling with two or three pedal strokes in each direction - riding backwards and forwards over a few feet of ground. The critical balance points are when you stop travelling in one direction and start in the other. At first you may need to idle for a couple of strokes at each 'end' of the forward and backwards run.
Eventually, you get up to the stage where you can comfortably ride 5 - 10 pedal strokes back and forth. By now you have good control and are able to *regain* your balance when reversing.
Then it's just a matter of practice practice, practice.
I find reversing a few strokes a useful skill. I've never found a *need* to cover great distances, which means I usually lose it after about 50 pedal strokes in reverse unless I stop and idle for a stroke or two.
__________________
My first novel, Bridge of Otherwhere, Michael Wilkinson, on Kindle. A tale of subtle magic, mystery, friendship and love. Tinyurl.com/Bridge-of-Otherwhere For US$ page: TinyURL.com/OtherwhereBridge
Mikefule is offline   Reply With Quote
Old 2002-10-20, 10:32 PM   #3
yoopers
Unicyclist
yoopers's Avatar
Send a message via Yahoo to yoopers
Raphael,
For what it's worth, the key for my sort-of-success in riding backwards was to hold my arms out straight to the sides, as in good body form for Standard Skills competition.
Really made a difference for me.
Bruce
yoopers is offline   Reply With Quote
Old 2002-10-20, 11:27 PM   #4
rhysling
Simmian Envoy from Fenetic Climate
rhysling's Avatar
Send a message via AIM to rhysling
Quote:
Next step, I've heard called 'super idling' *snip*
Next step I've heard called 'mega idling' *snip*
I believe these are all roll-backs; true iddling is done with the roll of the foot in a peculiar pumping motion, and is destinctively different technique from a roll-back. I found it much easyer to roll-back than to iddle, and, as Mike did, used it as a gateway to backward riding. Attempting to use roll-back technique to truely iddle is frusterating and required much more top foot controll for this beginer than a true iddle would. Still, roll-backs are great, and are sometimes more practicle (such as on uneven terrain).
On the weight-on-sadle issue, backward riding is much easyer for me with the sadle high- it is quite a bit more difficult at hopping hight; I made big leaps in progress once the sadle was raised.
-Christopher
__________________
"Jeeeezus! I can be misunderstood enough all by myself" -Uni57
"Jesus would love you if he were real."
-Catboy
"Could someone please pass the brain soap?"
-Jethro
rhysling is offline   Reply With Quote
Old 2002-10-21, 12:07 AM   #5
carjug
Unicyclist
I agree with Mike Fule, I learned to go backwards this way; however I did not really progress until after I had done some distance riding with hills. My advise is to mix Mike's technique with some distance or trail riding, 'specially with winter coming up and all...
carjug
carjug is offline   Reply With Quote
Old 2002-10-22, 02:16 AM   #6
jerryg
JerryG
I learned to ride backwards before I learned to idle. When I'd mount, I'd try to continue the 1/2 backwards pedal. It was difficult to start, but after a few pedals it levels out. -It's exactly like learning to go forward, only different. At the time, I didn't know idling was possible.
jerryg is offline   Reply With Quote
Old 2002-10-22, 06:39 AM   #7
andrew_carter
Back into muni!
andrew_carter's Avatar
I know that in some places such as here in Australia, this isn't as easy (I was lucky) but try to practice with a friend. I learnt to ride backwards with another unicyclist. He'd pedal forwards and I'd pedal backwards and then after a while and after I'd gathered a bit of momentum, I'd let go and pedal a bit on my own. Maybe if you don't have a unicycling friend you could hold onto the handlebars of a bike. Another similar way is if you can go to a supermarket carpark and find a spare shopping trolley to use while you're there. Then you can hold onto that and you can use it instead of another person on a unicycle. This method also gives a stronger thing to hold onto when you've just starting out. I also used this method to learn and found it quite useful.
Good luck,
Andrew Carter
p.s. I may not be the best person to take advice from because I'm not the greatest backwards rider. I sort of stopped learning after I could ride about 50 metres because I got sick of having to ride with my head turned around...it gets quite uncomfortable.
andrew_carter is offline   Reply With Quote
Old 2002-10-22, 12:27 PM   #8
rhysling
rhysling's Avatar
Quote:
Originally posted by andrew_carter
I know that in some places such as here in Australia, this isn't as easy...
You must be very sensitive- most cyclists aren't bothered by the Coriolis effect...
-Christopher
__________________
-Catboy
-Jethro
Old 2002-10-23, 12:09 PM   #9
andrew_carter
Back into muni!
Sorry if I'm beign an idiot here but what's "the Coriolis effect... "?
Old 2002-10-23, 12:30 PM   #10
phil
Average wheels: 1.5
phil's Avatar
The same thing that makes water spiral down a plughole in one direction above the equator, and the other direction below it...
(I hope)
Phil, just me
__________________
"Cattle Prods solve most of life's little problems."
phil is offline   Reply With Quote
Old 2002-10-23, 01:29 PM   #11
jdkimble
Working on Level 2
The Coriolis force is caused by the rotation of the Earth. The further from the equator you get, the stronger the force. In the Northern hemisphere, this force causes wind patterns to turn to the right. Opposite is true for the Southern Hemisphere. This force is not strong enough to cause water to drain in a particular direction, though. That is just a science myth.
More info
__________________
Josh
jdkimble is offline   Reply With Quote
Old 2002-10-23, 01:36 PM   #12
phil
Average wheels: 1.5
phil's Avatar
Quote:
I suspected not; I had a very vague feeling that it was just a myth, but I couldn't remember. It's the myth most people remember, anyway...
<puts on Dunce hat>
Phil, just me
__________________
Reply
Tags
backwards, riding
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright © 2001-2016 Gilby
Page generated in 0.55929 seconds with 10 queries
