Unicyclist Community
Reply
Old 2017-10-11, 08:04 PM   #1
Chimeara
Chimeara
Early Morning Mounting problem
Hi all
A quick question i have been riding approx 6 months and upgraded to a 36" Nimbus about a month ago. My problem is this, when i am out and about riding i have little to no problems mounting it. However at the beginning when i first set off it can take me 5 or 6 goes before i successfully freemount and ride off.
I ride pretty much daily so it's not like i'm out of practice. plus no problems at all on rest of ride i still upd and have to get off for various reasons but i have almost 100% success mounting on these occasions. So my question is this. Is it just me? Is it normal for a relative newbie? and can i look forward to it not being a problem?
Many thanks in advance
__________________
24"Nimbus
27.5 KH
36" Nimbus Oracle
Chimeara is offline   Reply With Quote
Old 2017-10-11, 08:13 PM   #2
Mikefule
Roland Hope School of Unicycling
Mikefule's Avatar
Yes, I think as we get older, we all get an early morning mounting problem. These days, my wife and I need a coffee first,
__________________
"A unicycle is not a physics problem." (tholub)
Mikefule is offline   Reply With Quote
Old 2017-10-11, 09:00 PM   #3
lightbulbjim
Unicyclist
lightbulbjim's Avatar
Mike, I take it you donít have young kids. I vaguely remember what that was like.
Chimeara, itís not just you. When I was ~15 I used to (bi)cycle every morning at 5am. These days if I attempt to ride (my 36) much before about 9am I not only have great difficulty mounting but it feels like the ground is on a perpetual lateral lean. Most annoying.
Even riding at other times the first mount of the day on the 36 can be a bit arduous. The best advice I can offer is to make sure you switch wheel sizes every now and then. I find that if I make a point of riding my 26 at least once a week then mounting my 36 becomes much easier.
__________________
Unicycling is the fountain of youth.
lightbulbjim is offline   Reply With Quote
Old 2017-10-11, 09:13 PM   #4
Uni Klein
Hooked For Life!
Uni Klein's Avatar
When I go out to practice, I usually just start next to a car or wall, just because I'm lazy and I like to get a little 'warmed up' before I try to freemount. I know I can do it, Its just too hard to heave myself way up there first thing on a cold morning.
__________________
If your not sore, your not ridin' long enough!
Uni Klein is offline   Reply With Quote
Old 2017-10-11, 09:22 PM   #5
juggleaddict
late-night rider
juggleaddict's Avatar
Send a message via AIM to juggleaddict
what mounting style? Rolling/running mount will take a lot less energy and tends to be more consistent. Static mounting a 36 is always rough.
__________________
Steel is real! => I ride a Nimbus!
juggleaddict is offline   Reply With Quote
Old 2017-10-11, 10:05 PM   #6
Setonix
Unicyclist
I've been riding different wheel sizes lately, so the first mount will always fail (unless it is the 20"), just to feel where the balance point is. But sometimes it does take 3 or so times. As soon as I've warmed up and have to step off and mount later, it usually works the first time. It does help that the 26", 29" and 32" all have 150mm cranks, so the distance between my feet is always the same.
Setonix is offline   Reply With Quote
Old 2017-10-11, 11:49 PM   #7
Canoeheadted
Unicyclist
Be a little more "positive" on your next morning ride. Use the Force.
Instead of trying to do it on your first mount...
Just do it.
Otherwise, you might be developing a pre-pitch routine. Sniff, snort, scratch, nod, and then throw.
That's OK too, if that's what works for you.
I'm more of a just do it.
I purposely mount differently every time to keep myself in practice for anything.
My current challenge is mounting my KH29 on an uphill with enough momentum to keep the tire moving once I'm up.
Canoeheadted is offline   Reply With Quote
Old 2017-10-12, 12:36 AM   #8
JimT
Unicyclist
JimT's Avatar
I think not being able to hit a 36er free mount occasionally is more normal then abnormal.
The success rate of free mounting a 36er is more comparable to a baseball hitting average then it is to mounting a bicycle. In baseball even a 40% hitting success rate is a nearly unachievable goal. The success rate for an experienced rider mounting a 36er is much higher but never as high as mounting a bicycle. I see even the most experienced uni riderís occasional miss a free mount.
Jim
JimT is offline   Reply With Quote
Old 2017-10-12, 02:17 AM   #9
song
Unicyclist
Downsizing to 110mm cranks on my 29 forced me to give up the rollback mount and really learn the static mount. Nowadays I almost never miss, but yeah, that first mount can be a little tricky, now that you mention it. A rollback mount can be a good way to get a feel for an unfamiliar unicycle, but on a 36 or a 29 with short cranks, it sometimes isn't feasible.
I will follow juggleaddict's advice and try to get more of a running start for my static mount.
song is offline   Reply With Quote
Old 2017-10-12, 06:28 AM   #10
Mikefule
Mikefule's Avatar
I use a static mount on the 36. On the flat, I get almost 100% success - just the very rare failure on uneven ground or a narrow path, or when I'm tired. I've never really had much success with rolling or running mounts.
__________________
Old 2017-10-12, 07:42 AM   #11
pierrox
Unicyclist
pierrox's Avatar
+1 on the assisted morning mount. Getting the body warm is a bit part of the ride, I tend to brush over it too often thinking "riding will warm me up".
Quote:
I did that switch too, and was surprised that I could still do the roll-back mount! Gotta practice my static mount though, it's not a 100% there.
pierrox is offline   Reply With Quote
Old 2017-10-12, 10:13 AM   #12
Setonix
Unicyclist
And you do this even though you can static mount uphill already? Naturally it depends on how steep your uphill is. A rolling mount uphill seems problematic, though I only do static mounts these days. do you also challenge yourself by mounting with your non-dominant foot?
Old 2017-10-12, 10:18 AM   #13
Setonix
Unicyclist
Quote:
Getting tired is really annoying, also feel that with the 29" At some point after x kilometers my legs get tired and mounting hurts too much. Especially with the 36" if you can only do a static mount, it becomes a challenge to mount again. With all this talk of the 36", I wanna give it a go again. Haven't used it for in over a year, because of mounting issues. As soon as I start thinking "wow this is really high", I don't hop high enough. If only I could turn off my brain.
Old 2017-10-12, 08:38 PM   #14
mrfixit
Unicyclist
me too.
I have that problem with my purple monster. Every day. Always takes a couple tries the first time...
( I didn't name it, Nimbus did...)
mrfixit is offline   Reply With Quote
Old 2017-10-13, 03:57 AM   #15
Canoeheadted
Unicyclist
Setonix,
I'm trying to mount on uphills and it always turns into a static mount, a few steps to get momentum, then finally I get rolling.
I want to keep rolling and avoid the step climbing. (pedal, pause, pedal, pause, etc...)
I want to learn to hit that top pedal harder and start the wheel rolling before my body moves forward of centre. I think I'm putting too much pressure on my bottom pedal and taking the momentum away. So yes, a rolling mount uphill.
I have to just launch myself full tilt and keep practicing.
It's all a little harder because I do have a set of handlebars too.
And yes I do switch feet to mount every time. (Unless conditions are warranted for a certain mount of course)
I also switch hands also to try and achieve ambidexterity.
It's harder to learn but makes everything easier once it has been learned.
Try it... Keep rotating through these 4 mounts.
1- Dominant foot and dominant hand
2- Dominant foot and non-dominant hand
3- Non-dominate foot and dominant hand
4- Non-dominate foot and non-dominant hand
This is what works for me.
Reply
Tags
early, morning, mounting, problem
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
An Early Morning Ride Naomi General Unicycling Discussions 14 2009-06-10 02:41 PM
Grinding problem & 360 unispin problem Unisykolist General Unicycling Discussions 0 2008-10-25 02:40 AM
An Early Morning Ride john_childs General Unicycling Discussions 2 2004-06-02 07:48 AM
Web hosting problem and Email Problem mrwilliby Just Conversation & Introduce Yourself 5 2004-04-21 02:51 AM
X-mas came early for me! AccordNSX General Unicycling Discussions 4 2001-12-20 01:43 AM
Powered by vBulletin®
Copyright © 2001-2016 Gilby
Page generated in 0.09283 seconds with 11 queries
