Unicyclist Community
Reply
Old 2014-03-13, 06:21 PM   #1
Darth Elevator
I Love You-nicycling
Darth Elevator's Avatar
Question: 29" wheel on an original Coker 36" frame
Hi, does anyone know which 29" wheels would fit an original Coker frame? I was thinking that buying a 29" wheel and slapping it on my Coker would be a cheap way to see how much I like riding a 29er.
__________________
"The price of unicycling freedom is eternal pedaling." --Thomas Jefferson
"The only thing unicyclists have to fear is fear itself." --Franklin Roosevelt
Darth Elevator is offline   Reply With Quote
Old 2014-03-13, 07:18 PM   #2
Piece Maker
Unicyclist
Piece Maker's Avatar
I don't see why it wouldn't... What are your concerns? Unless you're hoping to fit a massive fat tyre on!
__________________
“It is well known that a vital ingredient of success is not knowing that what you're attempting can't be done. A person ignorant of the possibility of failure can be a half-brick in the path of the bicycle of history.”
Piece Maker is offline   Reply With Quote
Old 2014-03-13, 07:35 PM   #3
Jacob Young
Indecisive Municyclist
Make sure your bearing cups are the right size first!
Old square taper hubs have 40mm bearings whereas ISIS hubs use 42mm. You can shim 40mm bearings to fit ISIS frames, but not vice versa (unless you use very specialist bearings).
__________________
You know how people can do a "kick up" mount? Well I can do a "kick down" dismount. - Cloudz
Things are easy, apart from when they aren't
Jacob Young is offline   Reply With Quote
Old 2014-03-13, 08:06 PM   #4
Piece Maker
Unicyclist
Ahh, the old Cokers are Square Taper... Didn't know that I thought the question was purely towards the wheel/tyre fitting!
__________________
Old 2014-03-13, 08:32 PM   #5
unigoat
Uni CX is a thing.
Any wheel should work if the bearing holders are stamped and not machined. The 40 vs 42 mm is not a big deal with stamped bearing holders. If the holders have bolts and nuts, they're stamped.
If the frame width is a bit off, the frame can be cold set as well.
A 3" tire might be a tight fit, but anything less should be fine.
unigoat is offline   Reply With Quote
Old 2014-03-13, 08:33 PM   #6
jtrops
Unicyclist
If it is one of the original, steel, "Big One" frames you should be able to use just about any 100mm spaced hub.
Those frames have pressed bearing holders that work fine with 40mm or 42mm bearings. If you have an aluminum frame with machined bearing holders you will be limited to 127mm spaced hubs with 40mm bearings.
__________________
"A properly ridden unicycle is like an object in orbit: constantly falling but never landing." -Diogenes
jtrops is offline   Reply With Quote
Old 2014-03-13, 09:51 PM   #7
Darth Elevator
Thanks, I guess I need to measure the frame to see if it'll take a 100mm hub or 127mm.
__________________
Old 2014-03-13, 09:53 PM   #8
Darth Elevator
Quote:
Very helpful info. Thanks! And the holders do not have bolts and nuts, so I guess that means they are machined.
__________________
Old 2014-03-13, 09:55 PM   #9
Darth Elevator
Quote:
My concerns are mainly width of the space between the bearings. I tried a 20" just for fun, but the bearings weren't even close to being wide enough apart to fit the frame. I hadn't even thought about trying a 29" until today when I saw that uni for sale that comes with both a 29" and 36" wheel.
__________________
Old 2014-03-13, 09:56 PM   #10
Darth Elevator
Good point. I hadn't thought about bearing cup size; I was mainly thinking of distance between the bearings.
__________________
Reply
Tags
29", 36", coker, frame, original, question
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
26" wheel in KH 29" frame? magicollin General Unicycling Discussions 5 2012-04-11 09:45 PM
[For Sale: UK] ‘The Big One’ original Coker 36” unicycle frame Ralph Trading Post 8 2011-10-24 11:45 PM
36" build w/Coker wheel Scope General Unicycling Discussions 3 2011-09-20 10:19 PM
Anybody use a 26" tube on a 29" wheel? Carey General Unicycling Discussions 20 2010-12-16 01:16 AM
Powered by vBulletin®
Copyright © 2001-2016 Gilby
Page generated in 0.08866 seconds with 10 queries
