Unicyclist Community
Go Back   Unicyclist Community > General Discussion > Rec.Sport.Unicycling
Reply
Old 2005-02-02, 01:57 AM   #1
themeatballking7
Registered User
crank falls off
ya ive been riding my torker lately and originally i put up a post about my pedal popping all the time when i ride but i discovered the other day that it was actually my crank arm and it kept unscrewing itself and thats what the popping was, any ideas on how to fix it????
themeatballking7 is offline   Reply With Quote
Old 2005-02-02, 01:59 AM   #2
General Dibbles
Registered User
Send a message via AIM to General Dibbles
buy a crank wrench and tighten the cranks, and make sure they are always tight
__________________
REVENGE INDUSTRIES
www.torkerusa.com
General Dibbles is offline   Reply With Quote
Old 2005-02-02, 02:03 AM   #3
daino149
On Vacation - till i find a job
daino149's Avatar
Send a message via AIM to daino149
Also, be sure to never ride with a loose/popping. It will cause the square taper to get rounded. Once that happens, you're in a world of hurt. For more info, check unicycle.2ya.com
Edit: Don't forget to grease the taper first.
__________________
OPPORTUNITYISNOWHERE
daino149 is offline   Reply With Quote
Old 2005-02-02, 03:07 AM   #4
Unitik908
The Lone Clothespin....
Unitik908's Avatar
Send a message via AIM to Unitik908
Re: crank falls off
Quote:
That is exactly what is happening to me i keep tightening the bolt but in about 2 days it ge really loose and falls off. it is really starting to bug me.....
POW
__________________
All hail the exhaulted Sigpoose, for he is forever king...
R.I.P Unibiker
R.I.P Gazzaloddi
R.I.P Paul Hester
R.I.P James Doohan
R.I.P Mitch Hedberg
R.I.P Peter Jennings
R.I.P Pope John Paul II
R.I.P James_Potters_Cat
YAMS
Unitik908 is offline   Reply With Quote
Old 2005-02-02, 06:13 AM   #5
john_childs
Guinness Mojo
john_childs's Avatar
The best way to make sure the crank is properly tight is to use a torque wrench. The crank nut should be tightened to 40 foot-pounds. If it is properly tightened it should stay tight for normal riding and you shouldn't have to mess with it till it's time to remove the crank. Things like muni and trials are rougher and can cause the cranks to come loose on their own. If you're doing muni or trials you'll have to keep an eye on the crank tightness and retighten things as needed.
Here's the short run down on how to get the cranks tight:
1) Clean the hub taper and crank taper of any grease or dirt
2) Put a little bit of grease on the taper of the hub and/or crank
3) Slide the crank on
4) Put a couple drops of red high strength Loctite threadlocker on the crank nut threads
5) Tighten the crank nut to hand tight
6) Use a torque wrench to get the crank nut to 40 foot-pounds
It is difficult to estimate what 40 foot-pounds is without a torque wrench. If you don't get the crank tight enough it will come loose on its own. If you get it too tight you can strip the threads. A torque wrench is the only reliable way to know if you got it tight enough.
If you don't have a torque wrench then take it to a bike shop and have them tighten it.
You can do it without a torque wrench and you can learn to estimate what 40 foot-pounds feels like. But you'll never know if it really is tight enough and you'll have more loose crank episodes than if you use a torque wrench.
Since I started using a torque wrench I've not had any loose crank episodes on my Coker or my freestyle uni (my two unicycles I ride regularly with square taper cranks).
__________________
john_childs (att) hotmail (dott) com
Team Never Wash Your Muni
My Gallery :: Unicycling Bookmark List :: World Clock
john_childs is offline   Reply With Quote
Old 2005-02-02, 06:59 AM   #6
tomblackwood
Tailgate at your own risk...
tomblackwood's Avatar
Quote:
Originally posted by john_childs
The best way to make sure the crank is properly tight is to use a torque wrench. A torque wrench is the only reliable way to know if you got it tight enough.
JC speaks gospel. I got one on his recommend for switching cranks on my 36-er, and it works great. And you don't need to spend up for the ultra cool digital model. Sears makes a very good basic Craftsman torque wrench that will probably last a lifetime. I think I paid between $20 and $30 for it.
edit: just searched on it. It's this one.
__________________
Tom Blackwood is like a shadowy figure behind a 36" tree...
tomblackwood is offline   Reply With Quote
Reply
Tags
crank, falls
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright © 2001-2005 Gilby
Page generated in 0.20372 seconds with 9 queries
