#1 | |
Guinness Mojo
Converting from MOV to MPEG or AVI
One of the threads in R.S.U. is getting off topic talking about video compression. I'll answer one of the questions here where it's not off topic.
The question was from Andrew's thread: Andrew's 8 minute movie... The question was: Quote:
Here's how to convert a MOV file from a digicam to an MPEG-1 file with TMPGEnc. Install TMPGEnc and the QT Reader plugin TMPGEnc http://www.tmpgenc.net/e_main.html QT Reader plugin http://www.videohelp.com/tools?tool=277#comments http://www.geocities.com/SiliconValley/4942/svcd.html Start TMPGEnc It will start up with the Project Wizard Hit Cancel, we're going to configure things manually since the presets don't do what we want to do For Video source click Browse Find the source file (the MOV file) and click Open Check the Output file name and make sure the name and path are what you want For Stream type make sure it is set at "System (Video+Audio)" Click on the Setting button Select the Video tab Stream type: MPEG-1 Video Size: 320 x 240 pixels Aspect ratio: 1:1 (VGA) Frame rate: 30 fps Rate control mode: 2-pass VBR(VBR) Click on Setting for Rate control Average bitrate: 500 kbits/sec Maximum bitrate: 2000 kbits/sec Minimum bitrate: 100 kbits/sec Click OK Motion search precision: Highest quality (very slow) Note here: Pick a frame rate that is equal to or a multiple of the frame rate that the camera produces. If the camera does 10 fps or 15 fps then 30 fps will work well. If the camera does something like 12 fps then pick 24 fps for the frame rate. Check the camera's documentation to find out its frame rate. Click on the Advanced tab Video source type: Non-interlace (progressive) Click on the Audio tab Stream type: MPEG-1 Audio Layer II Sampling frequency: 32000 Hz Channel mode: Mono Bitrate: 64 kbits/sec (could go lower if you want) Click OK We're done with the settings. Time to compress. Click the Start button. When it is done, play the output video and see how the quality is. These settings got a 3900 KB MOV file from a digicam down to about a 1000 KB MPG file. This is at an average bitrate of 500 kbits/sec. That was the point where the compression artifacts were starting to get noticeable. If you go lower than 500 kbits/sec you are going to want to keep an eye on the output quality to make sure it isn't too blocky. You can go lower if you need a smaller file size. Experiment with the average bitrate. 500 kbits/sec seemed to work OK on the sample clip I used. You can try a higher average bitrate of maybe 750 kbits/sec or even a little lower. The higher you go the better quality you are going to get, but the file size is going to get proportionally bigger. If you have problems with the sound when converting the MOV file, go to the QuickTime settings and toggle the Sound Out settings from DirectSound to waveOut (or vice versa). I don't know why that got things working for me, but it did. Control Panel >> QuickTime Select Sound Out in the QuickTime dropdown list Toggle the playback device to/from DirectSound to waveOut (or vice versa) From here you can import the MPG file to a program like VirtualDub to trim away parts of the video or do other basic editing. If your goal is to import it to an editing program you will want to use a higher bitrate (something like 2000 kbits/sec or 3000 kbits/sec or more would be good) to keep the quality up. Then once the editing is done compress the final version down to something smaller.
__________________
john_childs (att) hotmail (dott) com Team Never Wash Your Muni My Gallery :: Unicycling Bookmark List :: World Clock |
#2 |
768 - It's in your DNA
JC wrote up that conversion recipe for me and I thank him for it. I did further compression from MPEG to .wmv with another recipe he wrote for me. I found the settings in both steps to be sensitive and easily created video artifacts unless left at default values. Hopefully you will have better luck than me and, undoubtedly, you are more clever than me. This is NOT to say that the JC recipes don't work. It's just that I had to use default settings to avoid artifacts. With the defaults they worked flawlessly.
__________________
-Greg Harper JC is the only main man. There can be no other. "Natural logs are what you ride on a Mun'e'." - kevinalexandersmith |
#3 |
Guinness Mojo
Another options is to use The Rad Video Tools to convert the MOV to an AVI. The Rad Video Tools is a free utility.
Last September they made an important update to the program. It now can import DirectShow video and audio. This is important because QuickTime 6 uses DirectShow. Before this update the program didn't work very well if you had QuickTime 6 installed (you had to downgrade to QuickTime 5 to get the MOV file import to work). Here's a guide that explains how to use it: MOV to AVI guide The guide recommends using the MJPEG codec for compressing the AVI. That works well. Another compression option is Huffyuv which is a lossless codec. It will get you about 2:1 compression compared to a RAW uncompressed AVI file. Huffyuv is good if your goal is to import the AVI file to another program for further editing. Since it is lossless you won't have any video quality loss during editing. Huffyuv is also good for capturing video. I use it when capturing video from a VCR. But at only 2:1 compress it makes for some large files. The Rad Video Tools does not compress the audio in the AVI file. To compress the audio you'll need to compress the file using a tool like VirtualDub along with the LameACM MP3 codec. Best bet in VirtualDub is to compress with DivX and Lame MP3. The Rad Video Tools is a great utility for converting MOV files. With the recent update, so it works with QuickTime 6, it is actually useful again. It's free, but worth a small donation if you find it useful.
__________________
#4 |
rotartsinimdA
I use the "WinAVI Video Converter" which can turn WMV, MOV, AVI, RM, etc etc... into any of the previously listed. I also use a kodak that takes videos in a .mov form, I convert them and BAM wmv/avi's for me to use in videos! It's free, and fast, and as of yet I have no problems with it.
DOWNLOAD IT HERE!
__________________
I ride a fixie and enjoy the smell of my own farts. I have even been considering getting a Mac and Prius. -John Childs |
#5 | ||
Guinness Mojo
Quote:
Quote:
There are many shareware and commercial applications that can convert MOV files to a more useful format. But they're not free. There are only a few free tools that I've found that can convert MOV files. The best ones that I know of are the two that I mentioned. Free is a very good price.
__________________
#6 |
rotartsinimdA
I downloaded if tom Download.com and there aren't any watermarks on any of my videos. It does show a register dealy when you start it up but you just have to click past it.
So... really it works just as well.
__________________
#7 | |
Guinness Mojo
Quote:
I downloaded it from WinAVI.com. The version I got put a big watermark on every frame in the video. I'll attach a video capture of the watermark. If you have a version that doesn't do the watermark, you're going to want to keep it and never upgrade to the new and improved watermark version. I give it two thumbs down. It just plain didn't work for me.
__________________
#8 |
rotartsinimdA
Wow... it never has that tag for me.
Jus looka t all of my videos. Which all use the WinAVI converter.
__________________
#9 |
Guinness Mojo
Something must have happened when they upgraded WinAVI to a new version. They completely broke it and added the big watermark. I didn't check the version number of the version I installed. I have since uninstalled it and deleted it. Stick with your older version.
__________________
#10 |
Guinness Mojo
Here's another way to convert a MOV file to a different format. In this case WMV. Windows Media Encoder 9 can read MOV files from a digicam and convert them to a WMV file. That surprised me because it's not supposed to support MOV files. But it worked. I don't know why.
MOV files are not one of the specifically supported input file formats in Windows Media Encoder 9. That's why I'm not sure why this works. I have QuickTime 6.5.2 installed and am running Windows 2000. I may have some other codecs or magic utilities installed that somehow makes this work. If it works for you consider yourself lucky because it seems to be an undocumented feature in Windows Media Encoder. Here's how to go about it: Get the Windows Media Encoder 9 from here http://www.microsoft.com/windows/win...r/default.aspx http://tinyurl.com/7wf8 and install it. It's free. The interface for Windows Media Encoder is a bit complicated. The problem is that Windows Media Encoder does a lot more than just convert files. It also can be used to compress streaming video, capture live video, and lots of other things. It makes for a complicated interface. The good news is that WMV compresses better than MPEG-1. You should be able to get the file down to about 1/4 the size of the original MOV file size. The bad thing about WMV 9 files is that people with Unix/Linux or older Macs won't be able to play the video. Here's how to convert a MOV file to a WMV file. New Session --> Wizards -->Convert a file Select the source file Click Browse. MOV is not a file type that is supported by default Go to "Files of type" and choose "All files (*.*)" Now you'll be able to see MOV files in the file dialog Find your MOV file and click Open Select the output file Choose a name and a location for the new file Click Next Choose "File download (computer playback) Click Next For video select "VHS quality video (250 Kbps VBR) For audio select "Voice quality audio (CBR) Click Next You can supply title and author info in you want Click Next Click Finish Now we need to tweak the settings to get better output In the menu bar select View --> Properties Panel Select the Compression tab Click the Edit. button next to the Destination dropdown box Click on the tab labeled 263 Kbps or whatever number it happens to be For Audio format select "20 kbps, 22 kHz, mono" For Video size select the checkbox for "Same as video input" For frame rate enter "15" or "30". I'm pretty sure your camera is 15 fps. Anything that is a multiple of your camera frame rate will work. Now for the big one. Now we'll change the setting for the video bit rate. This will have the biggest effect on quality and file size. Some experimentation here will be necessary. A bit rate of somewhere between 500Kbps and 1250Kbps is probably a good range to try. For now we'll try 1000Kbps In the Video bit rate (average) box enter "1000K" Click OK Click Apply in the Session Properties Panel Whew! Now we're ready to encode. In the menu bar select Control --> Start Encoding or just click the Start Encoding button on the toolbar. Watch the encoding progress. Then watch the output video. See if the output video looks good. You can now try some lower bit rates to get a smaller file. Just watch for compression artifacts in the video (blocky video, washed out areas in the video, etc.). You can possibly go down to 500Kbps without too much loss in video quality. Going down to 500Kbps will cut the file size in half compared to 1000Kbps. And that's all there is to it. It is possible that Windows Movie Maker 2 in Windows XP may also be able to read a MOV file the same way and thus be able to convert a MOV file to a WMV file. I don't have Windows XP handy right now to test this out.
__________________
john_childs (att) hotmail (dott) com Team Never Wash Your Muni My Gallery :: Unicycling Bookmark List :: World Clock Last edited by john_childs; 2005-01-09 at 08:40 AM. |
#11 | |
Tim!!!!!!!!!
Quote:
I think there's a website that has older version of programs like for just a situation but I cant remember the name of it. EDIT: I desided to google it, its www.oldversion.com it seems to be down right now. I dont know if it will have it or not though you can try though.
__________________
machining the world Last edited by Tim; 2005-01-10 at 12:10 PM. |
#12 |
Guinness Mojo
Here's some info on using DivX along with VirtualDub to compress an AVI file.
First you'll need to install an MP3 codec that supports the ACM (Audio Compression Manager) interface in Windows. There are versions of LAME that include an ACM driver. There are also other MP3 codecs that include an ACM driver. I'll explain how to install the LAME ACM driver. How to install the LAME ACM driver: Download the LAME 3.96.1 stable bundle from Rarewares Extract all the files to C:\Program Files\lame Right-click on the LameACM.inf file Select "Install" from the context menu The DivX web site has some guides on how to encode using DivX. DivX How-To Guides DivX and VirtualDub Guide There is a big DivX User Guide in PDF format that explains the various compression settings in the DivX codec. The page with the DivX User Guide also has a few additional How-To Guides. The "Using DivX Pro with VirtualDub" guide covers the basics of compressing video using VirtualDub, but it neglects to cover how to compress the audio. An additional guide "Encoding Audio for DivX Certified Devices" covers the audio compression part. Combine the two guides and you've got the basics of video compression and audio compression covered. VirtualDub and many other tools do not automatically compress the audio when you create an AVI. It is not uncommon to see AVI files where the video has been compressed nicely but the audio has been left completely uncompressed. Uncompressed audio is a waste of space and in some cases can double the size of the file. Compressing the audio will make for a smaller AVI file. A handy tool when working with AVI files is AVIcodec (AVIcodec homepage). AVIcodec allows you to see what codec was used to compress the video portion of an AVI file and what codec was used to compress the audio section of an AVI file. This will let you see if the audio portion of an AVI file has been compressed. AVIcodec can also list all of the codecs that you have installed. A very handy little tool.
__________________
john_childs (att) hotmail (dott) com Team Never Wash Your Muni My Gallery :: Unicycling Bookmark List :: World Clock Last edited by john_childs; 2005-01-19 at 10:32 AM. |
#13 |
Guinness Mojo
DivX AVI vs. MPEG-1 vs. WMV9
When picking a format for a movie or video clip there a few things to keep in mind. Each format has it's own unique advantages and disadvantages. MPEG-1 is very compatible. It can be played by most any modern computer. It will play on Windows, older Macs, newer Macs with OS X, Linux, Unix, and others. MPEG-1 is the format to choose for the most trouble free playback. The downside is that MPEG-1 does not compress as well as DivX or WMV9. Files compressed with MPEG-1 can be twice as big, or larger, as the same video compressed with DivX or WMV9. WMV9 (Windows Media Video version 9) is a convenient format for Windows users. It does require that the user have Windows Media Player 9 or greater installed, or the Windows Media codec pack for WMP 7.1. There is also a version of Windows Media Player 9 for Mac OS X. So Mac users will be able to play the video too. But older Macs and other platforms like Linux are not supported. WMV9 compression is very good. It does well at low bitrates and is good for downloadable video files. Some of the Mac users here have problems playing some of the WMV videos in the gallery. I don't know what's up with that. DivX is also a popular option. It compresses well and can create small files good for downloading. WMV9 and DivX are about equal in compression ratios. The DivX codec is available for Windows, Mac OS X, and Linux. The problem with DivX is that it is not a native codec in the OS and will need to be manually installed by the user before they play the video. If the user doesn't know that the DivX codec is required and where to go get the codec, they won't be able to play the video. When encoding with DivX the best option for compressing the audio is to use MP3. Some people use WMA (Windows Media Audio) but that is a very bad choice for the Mac users and Linux users. DivX files with WMA audio will not play on Macs or Linux. Stick with MP3. To get the most compression out of DivX you need to use the DivX Pro codec when compressing the video. The DivX Pro codec has a 6 month trial period. After that it is $19.99. My preference is to use MPEG-1 unless the size of the video gets to be too big for a convenient download. When I want more compression I'll use DivX or WMV9.
__________________
#14 | |
Ðîgï†å||¥ ËñhÂÑ€èÐ
Quote:
my .MOV file 49mb -----> converted to 371mb .AVI also .. I'm having a problem with sound not sync to video... I was using 'ABCvideo Roll' which converts and edits into a number of different formats... but had same sound problem (it converts AVI much smaller) I'm dumping this program ....
__________________
My will to live was stronger than my will to die. - Iggy Pop That which does not kill me, makes me stronger. - Friedrich Nietzsche 1899 If it's popular, then what's it got to do with us? - Mens room wall My Gallery |
#15 | |
Unicyclist.com Webmaster
Quote:
It's "DivX ;-)", not the failed one time use DixX DVDs that were sold at Circuit City. Isn't DivX ;-) an Mpeg4 codec? And so is xvid? So why can't a single mpeg4 codec handle all these? Mpeg4 is standard. Or do these codecs just not adhere to the standard very well? So many options... AAC or mp3... DivX or mpeg1/2/3/4 or propriatary WMA.
__________________
Get educated about the legitimacy of government. Last edited by Gilby; 2005-01-23 at 03:28 AM. |
| Tags |
| avi, converting, mov, mpeg |
