Unicyclist Community
Go Back   Unicyclist Community > General Discussion > Rec.Sport.Unicycling
Reply
Old 2004-07-14, 08:59 AM   #1
GizmoDuck
Uni Hour Record Holder 29.993km
GizmoDuck's Avatar
Location: Wellington, New Zealand/ Middle of NSW, Australia
Anyone tried a 29er tube in a Coker?
More last minute woes,
My Stans no tubes kit arrived a couple of weeks ago- but they sent the wrong inner strip- instead of sending a 36" they sent a 26". So I had to wait and it only arrived yesterday. Now, since it is such a major upgrade and I am flying out of NZ this Saturday I have decided to leave it till after UNICON.
But just had a thought today- a 26'' tube blown up just about fits a Coker- I wonder if a 29" tube could be fitted in place of the 36'' Coker inner tube? The weight saving would be at least equal to going tubeless, once you factor in sealants and rim strip.
Has anyone tried this? This may be a safer upgrade because if it doesn't work I can always stick a 36" tube back on.
Thanks,
Ken
GizmoDuck is offline   Reply With Quote
Old 2004-07-14, 07:50 PM   #2
nathan
BIG rides: 24"/36" on/off road
nathan's Avatar
I haven't tried this but am interested in the result when you try it. I doubt it will work though. Too bad about the tubeless setup - I was hoping to check it out in Tokyo.
---Nathan
nathan is offline   Reply With Quote
Old 2004-07-14, 08:45 PM   #3
U-Turn
Small fish, small pond
U-Turn's Avatar
I've been thinking about it for a while but haven't tried it yet. I suggest using a Schrader valve tube and a valve extender because the Presta would be swimming around in the hole, and afaik there isn't a variety of Presta valve lengths available in that tube size.
__________________
Weep in the dojo... laugh on the battlefield.
-- Dave Stockton
U-Turn is offline   Reply With Quote
Old 2004-07-14, 09:44 PM   #4
jagur
My Uzi is a Tongue
jagur's Avatar
you can also get those little black rubber grommets that go in the schrader sized hole when using a presta valve. those would work on the stock rim.
i suppose if you got it all in there the tube would be pretty thin after a good amoumt of psi.
you could drill a hole in the other side of the rim and use two 29er tubes and half the utimate pressure in each.... doesnt that sound like fun?
__________________
theres enough BS in life, without mobius contributing.
Forget_Your_Life
-------MUNI MILITIA -------
One Wheeled Death Squad
jagur is offline   Reply With Quote
Old 2004-07-14, 10:06 PM   #5
U-Turn
U-Turn's Avatar
Quote:
That's true but then the Presta may not be long enough for the deep Airfoil rim. That's what I was thinking about when I mentioned the valve length. With an easy-to-find Schrader extender, this is rectified.
I'd think the 29er tube would expand ok to fit the volume of the Coker, since that's what normal tubes do in a fat trials tire.
__________________
-- Dave Stockton
Old 2004-07-14, 11:00 PM   #6
GizmoDuck
GizmoDuck's Avatar
Thanks for the replies everyone.
Jagur- I think the tube should be OK- even though it's stretched thin- the Coker tyre is 2.2kg of four ply toughness . I guess the main risk will be from pinch flats, but the sidewall is so ridid I think you'd be OK as long as the pressure is not too low.
An update: it looks like that plan will not work out either- no 29'er inner tubes in stock at my LBS today- I'm not too keen on using a narrower 700c tube.
Ken
Old 2007-01-01, 05:56 AM   #7
zfreak220
Polska Możność
zfreak220's Avatar
Send a message via AIM to zfreak220
hey ken, were you the first to use a 29er tube in a coker?
__________________
-Conrad
zfreak220 is offline   Reply With Quote
Old 2007-01-01, 06:47 AM   #8
GizmoDuck
GizmoDuck's Avatar
No, I wasn't. And I have yet to do so. But as far as I know, this is the first thread on the subject. Although I believe Dave Stockton had tossed around this idea for some time.
Tony Melton was the first person I know of to use a 29'er tube in a Coker.
I believe Tony was also the first person to suggest using a tubeless kit on a Coker. However, I believe the first tubeless conversion was done by Dirtsurfer, followed a few months later by me (gizmoduck). Tony has only recently gone tubeless.
Old 2007-01-01, 04:59 PM   #9
mornish
magic
Send a message via ICQ to mornish Send a message via AIM to mornish Send a message via MSN to mornish Send a message via Skype™ to mornish
is tubeless hard to do?
mornish is offline   Reply With Quote
Old 2007-01-02, 12:24 AM   #10
unicyclepa
i will defenestrate you
unicyclepa's Avatar
Send a message via AIM to unicyclepa
nick from swat dose it
__________________
www.unicyclepa.com
we suck
but its all good
team YAMS member in your sig or title and say
unicyclepa is offline   Reply With Quote
Reply
Tags
29er, coker, tube
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright © 2001-2005 Gilby
Page generated in 0.09155 seconds with 9 queries
