Unicyclist Community
Go Back   Unicyclist Community > General Discussion > Rec.Sport.Unicycling
Reply
Old 2004-01-24, 12:17 AM   #1
onewheeldave
Semi Skilled Unicyclist
onewheeldave's Avatar
Adjustable crank idea
I wrote this post some weeks ago in a bout of enthusiasm at a unicycle idea I had. Since then I've been wondering if I've actually got the correct idea of what splines are because some recent posts seem to be saying that splined cranks aren't particularly easy to take on and off.
However, here's the post in its original form, it's about an idea for adjustable cranks, all comments welcome.
The most obvious way to make adjustable cranks is to simply have extra holes for the pedal to screw into, this has the benefit of simplicity but also several drawbacks: -
1. when in 'long mode' the inner hole is a weak area for the crank
2. changing length necessitates unscrewing the pedal and rescrewing it into a different hole i.e. inconvenient if changing a lot and also, I suspect that there is a limit to how often they can be changed before the threads start taking damage
The other method, and one used in commercial models, is a sleeve arangement; it works and seems to be intended for tandems, but involves compromises between strength, ease of adjustability etc.
The few tests of available adjustable cranks by unicyclists seem to have not been successful, with the cranks breaking; though we should differentiate between cranks used for commuting/transport and those used for muni/trials (with big drops etc).
So here's my idea, in theory it looks like it should work well, but, lacking the tools/knowledge necessary to make a prototype, I'm not able to make and test it out. (see attached image)
The idea is, rather than adjusting the actual length of the crank, the distance betweeen the crank and pedal is altered by a mechanism that effectivly creates a bend in the crank.
So, if it is set to '125 mode', the pedal axis is 125mm from the wheel axle, creating the same leverage effect as if a 125mm crank is used.
The benefits of this system is: -
1. Use of present unicycling technology; splined axle/cranks are becoming commonplace and the same tools could be used to create the elements of the adjustable crank.
2. Strength. I'm no engineer, but, given that splined axles/cranks are used in top of the range muni/trials unis, and, as far as I can see there is no reason why the stress on pedal/crank splines should be greater than the present axle/crank splines; then this setup should be strong enough for all uses of uni.
3. Ease of changing length. As all the stress of riding should be mainly in the direction of the circumference of the spline hole, rather than at right angles, it shouldn't require a hefty mechanism to hold the pedal in the crank hole. This means that something as simple as a hole drilled through the protruding spline part with a retaining pin should sufice, enabling quick and easy changes.
Like I said, I'm no engineer so maybe there's some flaws I've missed and it'd be great if someone with experience in making uni parts/engineering gave some feedback.
It'd be nice if it did work because one of the things I love about unicycles is their mechanical simplicity. As someone whose experienced the pros and cons of different crank lengths for a given wheel size, i know that a workable variable crank would be a great boon to unicycling.
Of course, it looks like geared unicycles will soon be on the market, but my feeling is that they will have issues of cost and lack simplicity.
While gears may have the edge in terms of a large range, I would be quite happy with a crank that adjusted from 150-125mm, and I see no reason why a range of 100-175mm should not be feasible with a splined angle crank mechanism.
__________________
"You can't outrun Death forever.
But you can make the Bastard work for it."
--MAJOR KORGO KORGAR,
"Last of The Lancers"
AFC 32
onewheeldave is offline   Reply With Quote
Old 2004-01-24, 12:19 AM   #2
onewheeldave
This is the set up for 125mm mode: -
__________________
AFC 32
Old 2004-01-24, 12:20 AM   #3
onewheeldave
And 150mm mode: -
__________________
AFC 32
Old 2004-01-24, 01:08 AM   #4
U-Turn
Small fish, small pond
U-Turn's Avatar
That is a really, really cool idea, and one that sounds as though it would work well. Why not take a couple of sets of cranks down to a local machine shop, show them your drawings, and see what they say?
__________________
Weep in the dojo... laugh on the battlefield.
-- Dave Stockton
U-Turn is offline   Reply With Quote
Old 2004-01-24, 01:22 AM   #5
daino149
On Vacation - till i find a job
daino149's Avatar
Send a message via AIM to daino149
That's a great idea! I have never thought about doing it that way. One part i can't understand or figure out is how the two parts of the cranks connect. I would assume that the pedal side would be on the outside of the axle side. right? Also, would there be something like a splined axel on the crank part that goes into a splined hole on the hub part?
Over all I think the idea is worth seriously looking into.
Just imagine how many crank lengths you could get out of a 48 spline setup.
Keep the ideas coming.
__________________
OPPORTUNITYISNOWHERE
daino149 is offline   Reply With Quote
Old 2004-01-24, 01:54 AM   #6
onewheeldave
Quote:
Initially I was thinking that the short arm (with the pedal attached) would connect on the outside of the long arm (the one that connects with the axle).
This would mean that the pedal would be slightly further outwards from the axle than on a normal uni.
However, the short arm could connect on the inside of the long one, this would leave the pedal no further out from the axle than normal; it would slightly restrict the shortest effective crank length a little as, in the short mode the pedal axle would rest on top of the long arm.
Then again, as some people prefer the pedal further out, as it stops their heel accidently catching the axle, the first method may be ok after all.
[/B]
That would be optional, but, as splining would be used on the long arm/short arm connection, it would probably be used to connect the whole crank to the axle as well.
__________________
AFC 32
Old 2004-01-24, 03:22 AM   #7
harper
768 - It's in your DNA
harper's Avatar
That's a really cool idea. The limitations are minor. One could be surprised by the piece of crank coming up and bumping into the bottom of their shoe when in short mode. If that piece were significantly long it could sneak into a pant leg also. It probably wouldn't be able to take big drops but a device like this would most likely be used for distance riding anyway.
Make it. Good luck.
__________________
-Greg Harper
JC is the only main man. There can be no other.
"Natural logs are what you ride on a Mun'e'." - kevinalexandersmith
harper is offline   Reply With Quote
Old 2004-01-24, 03:27 AM   #8
chirokid
The Russian Bear!!!
Send a message via AIM to chirokid
I am impressed with the idea. Now, who's going to make the first prototype? --chirokid--
__________________
"Other than that, the best maintenance is to keep riding it as this helps to keep the eccentric nut on the saddle in optimal condition." quote by Mikefule
chirokid is offline   Reply With Quote
Old 2004-01-24, 03:41 AM   #9
daino149
daino149's Avatar
Quote:
Sounds like a job for Steve!
__________________
Old 2004-01-24, 04:30 AM   #10
gerblefranklin
Registered User
Great idea! I might try making one for a machine shop project, but probably not for a while.
I'm also not an engineer, but I can say that one limit would be the range you could build with this. With a range of 125-150mm, the part attached to the pedal could be very short (pedal axis would be 12.5mm from the center of the spline axis), which would be a plus, because that would put less stress on the hinge. But, as you make the range larger, say 100-175mm, you encounter some serious issues with the strength of the splined hinge. To have a thin splined area 75mm from the pedal would be extremely weak. The strength of splined setups partially comes from the length (thereby contact area) of the splined area (actually, now that I think about it, the whole point of a splined steup is to maximize the contact area between the crank and axle with a minimal increase in axle diameter. That's why profile is so strong. Massive contact area between crank and axle. Square taper cranks suck because they have a very spmall contact area). Onza and Profile cranks have 1" contact areas, I think. For contrast, square taper joints use about 1/2-3/4'' of contact, which isn't as good. So, the point is that in order to put one of these splined attachments on the middle of a crank would mean it'd need to be rather thin, which would weaken it. Also, it would be 97.5-175mm range. YOu could work a way around this, though. You could have a strengthening pin in it, so when you want to do extreme stuff, you just set the crank in it's shortes setting, and put a clamp on each piece so the joint is reinforced closer to the pedal.
With that in mind, I think a modification of this design would be to include a crossbar that would be sleeve type of bar, which would only get direct straight forces. You have the hinge be a freemoving hinge (instead of splined), and have the adjustment be the length of the bar. You could use a bolt type of tightening system where you tighten the bolt on the outside of the bar, which would clamp down on the inside one. It'd work like a unicycle seatpost or a router collet. That might be a bit thinner and stronger.
My $0.02
Bevan
gerblefranklin is offline   Reply With Quote
Old 2004-01-24, 05:30 AM   #11
unisk8r
One Wheel Wander
If you want more material between the various pedal holes in the crank, just CURVE the crank arm forward, i.e. down from horizontal starting at the axle...the pedal holes will still be the desired length from the axle, but with the curve, the partial circumference of the curve will result in a longer path to the next outward pedal hole than a straight line. With this design, the crank can stay 1 piece and thin.
unisk8r is offline   Reply With Quote
Old 2004-01-24, 09:14 AM   #12
john_childs
Guinness Mojo
john_childs's Avatar
What about something like this. The big disk could be made out of steel for durability (the tapered hole will last longer) and the crank could be made from aluminum to save weight.
__________________
john_childs (att) hotmail (dott) com
Team Never Wash Your Muni
My Gallery :: Unicycling Bookmark List :: World Clock
john_childs is offline   Reply With Quote
Old 2004-01-24, 09:31 AM   #13
GILD
Waffle-Tosser, Time-bider and JCTK
GILD's Avatar
Location: the bustling metropolis of Nelspruitia, south africa
Re: Adjustable crank idea
Quote:
from one non-engineer to another...
could this particular problem be overcome by using clip-on pedal type technology? ?
allowing to un- and reclip the pedal in different positions in a matter of seconds?
and if your onefooting is good enough...
GILD is offline   Reply With Quote
Old 2004-01-24, 09:59 AM   #14
U-Turn
U-Turn's Avatar
The cool thing about John Child's modification is that you could use the same wrench that you use for the bearing holders. Another advantage: it is cleaner for your feet.
__________________
-- Dave Stockton
Old 2004-01-24, 01:19 PM   #15
cyberbellum
Level 1.0 rider!
Cool idea. Seems workable.
RE: Stresses - Since the pedal sticks out from the crank it creates some pretty severe torques at right angles to the spline axis. These are resisted by the splines taking an up force on the outside of the crank and a down force on the inside of the crank. These stresses are far greater than the actual propulsive stress.
For example, assume a 160 lb rider is just standing on a regular pedal with the crank pointing straight down. The force is exerted about 3 inches out from the crank. This gives a torque of 480 inch-lbs (40 foot-lbs) that acts about the axis that is at right angles to both the crank and the pedal spindle.
On a regular threaded pedal the threads are about a half inch long. For simplicity, assume that the forces between the pedal and crank act at only two points - one at the inside face of the crank, at the end of the pedal threads, and the other at the outside faces of the crank where the pedal shoulder contacts the crank. (This assumption makes the forces act with the longest length which gives the smallest possible forces, which is unrealistic, however it's good enough to make my point.)
Engineering statics say that these two forces must 1) carry the weight of the rider, and 2) resist the torqe of the offset pedal. If we call the upward reaction force on pedal thread at the outside crank face (pedal side) "Ro" and the downward reaction force on the pedal threads at the inside crank face (wheel side) "Ri" then the statics analysis can be described mathematically by the following two equations:
1) Vertical forces must sum to zero:
(upward force on the pedal) + (upward force at the outside face + (upward force at the inside face) = 0
(-160 lbs) + (Ro) + (- Ri) = 0, or simply
Ro = 160 lbs + Ri
2) Torques must sum to zero, so (think teeter-totter):
(3 inches*160 lb) = (.5 inch*Ri), or simply
Ri = 960 lbs
Plugging this into the vertical forces equation means that
Ro = 1120 lbs
This was for an average rider just standing on the pedal. A heavy rider doing dynamic things would create reaction forces of up to a couple of tons. The contact area of these forces is going to be about the size of a pencil eraser, so we're talking serious metal stresses. With forces like these it doesn't take long for a little bit of slop to turn into a seriously worn fitting. Add a little road grit and the life expectancy and "feel" with the clevis pin setup won't be very satisfactory even if it is perfectly machined at the beginning.
You're going to have to consider some way to make the two parts really connect with a massive stress preload to keep them from moving against each other. Either a split outer spline with a quick-release pinch mechanism (borrowing from curent splined crank design), or tapered splines with a mechanism that creates a strong axial pull (borrowing from the square tapered spindle design) would do.
Best of luck. It's a seriously good idea.
__________________
I was standing in the park wondering why frisbees get bigger as they get closer. Then it hit me.
cyberbellum is offline   Reply With Quote
Reply
Tags
adjustable, crank, idea
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright © 2001-2005 Gilby
Page generated in 1.08002 seconds with 10 queries
