Unicyclist Community
Reply
Old 2002-11-03, 03:12 AM   #1
Monkey Juggler
Sal Gionfriddo
Monkey Juggler's Avatar
Send a message via AIM to Monkey Juggler
Tread Mills
Yesterday I was at my roommate's parents' house and was in the basement playing (using this term very loosely) the drums. I looked to my right and there before my eyes rested a tread mill. I jumped up from my seat ran upstairs and grabbed my unicycle. I then got on the tread mill and started that bad boy up. It was a blast especially once I let go of the bar. I got up to 10 mph on the 20". Eventually I fell of but oh well. Things to try next time; one footed, backwards, seat out in front, rolling hops.
Has anyone else tried this?
- Sal
__________________
Sal Gionfriddo
Trying to beat the Man.
Monkey Juggler is offline   Reply With Quote
Old 2002-11-03, 06:12 AM   #2
Scott Stephens
Equipment Destroyer
Scott Stephens's Avatar
Send a message via AIM to Scott Stephens
Thats sounds sweet! On first thought it looks like #33 on the Things NOT to do on a unicycle.
But that is totally cool
Too bad i dont have a treadmill
__________________
If it weren't for electricity we'd all be watching television by candlelight."
George Gobol
I have worked too hard to be a clown. I am an athlete and wish to be respected as one.- Checkernuts
Scott Stephens is offline   Reply With Quote
Old 2002-11-03, 09:03 AM   #3
Dylan Wallinger
Newsgroup User
Posts: n/a
Re: Tread Mills
Yeah, I got this idea recently while watching an old jackass episode. I think i
need to buy a treadmill.
Dylan
Old 2002-11-04, 03:18 PM   #4
hbaker1@pipeline.com
Newsgroup User
Posts: n/a
Re: Tread Mills
Sounds very cool!
Did you try the tilt mechanism, so that it was like you were
trying to go up a hill? I'd like to try that myself...
On Sat, 2 Nov 2002 21:12:26 -0600, Monkey Juggler
>rolling hops.
>- Sal
>Monkey Juggler - the ever elusive monkey juggler
>Monkey Juggler's Profile: http://www.unicyclist.com/profile/1213
>View this thread: http://www.unicyclist.com/thread/21413
Old 2002-11-04, 10:43 PM   #5
Klaas Bil
Newsgroup User
Posts: n/a
Re: Tread Mills
Clarify this please. Does the tilt mechanism rotate the axis of the
tread mill away from horizontal? Then do you ride it at an angle so
that one component of your movement rotates the drum and the other
simulates going uphill? In that case I assume there is a suitable
braking mechanism on the drum's rotation otherwise it would spin up
quite fast.
Klaas Bil
I posted only a single copy of this message.
Old 2002-11-07, 06:23 AM   #6
Newsgroup User
Posts: n/a
Re: Tread Mills
The treadmills I've seen at various exercise rooms have
a mechanism that lifts up the front of the beast so you
walk 'up an incline'. It looks like you can get upwards of
a 10-15% grade.
On Mon, 04 Nov 2002 22:39:07 GMT,
>quite fast.
>Klaas Bil
Old 2002-11-07, 02:18 PM   #7
yoopers
Registered User
yoopers's Avatar
Send a message via Yahoo to yoopers
Re: Re: Tread Mills
Quote:
Originally posted by hbaker1@pipeline.com
so you walk 'up an incline'. It looks like you can get upwards of
a 10-15% grade.
I live in Illinois. What is this "grade" you speak of?
B
yoopers is offline   Reply With Quote
Old 2002-11-07, 03:28 PM   #8
Scott Kurland
Newsgroup User
Posts: n/a
Re: Tread Mills
> > *so you walk 'up an incline'. It looks like you can get upwards of
> > a 10-15% grade.
> B
Asimov argued, correctly of course ;-), that the Earth was as smooth as a
billiard ball, to wit:
The Earth is roughly 8K miles in diameter, and the highest mountains (and,
for that matter, deepest ocean trenches, if you want to count irregularities
covered by ocean) are 5 miles high (or, you know, deep).
A billiard ball is 3" in diameter, so the equivalent to Everest and/or the
Marianas trench would be less than 50 microns high or deep.
Sorry, was that a digression? ;-)
Old 2002-11-07, 05:40 PM   #9
Sofa
you - pee - dee
Sofa's Avatar
Re: Re: Re: Tread Mills
Quote:
B
The higher the %, the steeper the hill
A grade of 0% would be flat. A grade of 100% would be straight up...or down
__________________
Happy Life Day
Sofa is offline   Reply With Quote
Old 2002-11-07, 05:42 PM   #10
Sofa
you - pee - dee
Sofa's Avatar
B
Oh crap, on closer inspection I realize I should have made the illinois - flat connection, but alas
__________________
Happy Life Day
Old 2002-11-07, 05:42 PM   #11
yoopers
Registered User
yoopers's Avatar
Re: Re: Re: Re: Tread Mills
Hill ???
I knew a U.S. president by that name once...
Old 2002-11-07, 06:49 PM   #12
harper
768 - It's in your DNA
harper's Avatar
Grade is the ratio of rise to runout, or vertical climb to horizontal distance traveled. On a 100% grade, one travels vertically as far as horizontally. This would be at a 45 degree angle. Going straight up or down is at an infinite grade.
__________________
-Greg Harper
Destroying the climate by shutting down nuclear power plants, one by one, since 1979.
JC is the only main man. There can be no other.
"A fool on a unicycle is redundant" - J.D. Miller
harper is offline   Reply With Quote
Old 2002-11-07, 07:35 PM   #13
yoopers
Registered User
yoopers's Avatar
Re: Re: Re: Re: Re: Tread Mills
Quote:
By golly, Greg, you are correct. I thought in line with Sofa about gradient but my handy dandy little black book - Thomas Glover's Pocket Ref - confirms it. I guess it's been a long time since engineering school.
I just happened to look up the word "grade" in the dictionary before I took a gander in Pocket Ref and there's another definition of grade, something about improving through breeding...
Bruce
Old 2002-11-07, 11:38 PM   #14
Klaas Bil
Newsgroup User
Posts: n/a
Re: Tread Mills
>a 10-15% grade.
Oh, OK. Even this type requires some brake mechanism though. However,
I was assuming with "treadmill" you meant a cylinder with a horizontal
axis. Either you walk IN one (like you can have in a hamster cage) or
you walk ON one. For cylinders, tilting to simulate going up a grade
is slightly less trivial.
Klaas Bil
All my posts are made with 100% recycled electrons.
Old 2002-11-08, 12:33 AM   #15
Scott Kurland
Newsgroup User
Posts: n/a
Re: Tread Mills
> >a 10-15% grade.
Imprimus: a hamster wheel is not a treadmill.
Secundus: simulating a grade on a hamster wheel is trivial: apply friction.
Granted, tilting is not the solution....
Reply
Tags
mills, tread
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.09636 seconds with 9 queries
