#1 |
What is that thing anyway?
Unibiker breaks one hour!
Dan,
Here’s another time for the TT records. During today’s 25k ride, the 15-mile point went by at 59:48. 25k time was 1:02:02. This was from a standing start. Of course, I have to admit to cheating. At about the 5-mile point, I tossed the helmet when a wasp flew in and started buzzing around. You may have to penalize my time due to the advantage of less wind resistance.
__________________
Jeff Baker jeff@unibiker.com MAKE IT A GREAT DAY!!! > > > > Unibiker's Photo Gallery |
#2 |
Newsgroup User
Posts: n/a
Re: Unibiker breaks one hour!
Outstanding!
Could you give us more details? What size rim & tires? What length cranks? On Sat, 12 Oct 2002 20:47:10 -0500, unibiker <unibiker.cfvdy@timelimit.unicyclist.com> wrote: >Here’s another time for the TT records. During today’s 25k ride, the >15-mile point went by at 59:48. 25k time was 1:02:02. This was from a >standing start. Of course, I have to admit to cheating. At about the >5-mile point, I tossed the helmet when a wasp flew in and started >buzzing around. You may have to penalize my time due to the advantage of >less wind resistance. ![]() > >Jeff Baker >unibiker@unicyclist.com |
#3 | |
Guinness Mojo
Re: Re: Unibiker breaks one hour!
Quote:
Congratulations on the ride.
__________________
john_childs (att) hotmail (dott) com Team Never Wash Your Muni My Gallery :: Unicycling Bookmark List :: World Clock |
#4 | ||
Re: Re: Re: Unibiker breaks one hour!
Quote:
Quote:
__________________
#5 |
Newsgroup User
Posts: n/a
Very cool! Are the gears/freewheel stock, or have you done something
to kill the freewheel? Or do you use the brakes to help balance ? I've seen freestyle BMX types ride like this, but I think that they were using a fixed gear with no freewheel (but I could be wrong about this detail). On Sat, 12 Oct 2002 23:35:28 -0500, unibiker <unibiker.cg39b@timelimit.unicyclist.com> wrote: >This was done on my 27 speed contraption (which I failed to specify >because Dan is familiar with what I'm riding. He's placing my times in >the Open Category to prevent confusion with the Cokers), so this info >may not be helpful unless you’re riding a geared uni. I’m using a 26” >wheel, 26 x 2.0 road tire, 170mm cranks, and usually run a gear ratio of >about 2.2:1 (I’m still experimenting) after I spend about 30 seconds >shifting up to the necessary gear. Dan just got me interested in this >process a couple of months ago, and my legs are still improving, which >continues to change the optimum gearing. Here is a link to some pictures >of this thing – http://www.unicyclist.com/gallery/albun01 |
#6 |
The hub is freewheeling; gears are changed to give me one-tooth increments. I don’t think anyone has figured out how to make a locked hub shift-able (but they’re trying). I think Michael Grant built a freewheeling/shift-able giraffe, but I don’t think he had much luck riding it, until he locked the hub. I’m using the brakes to tip forward when necessary. A search for ‘unibike*’ will produce some past threads on this project. Also, check this link for discussions on gearing - http://www.unicyclist.com/forums/sho...ght=unibike%2A
What a weekend! Calm enough for unibiking yesterday, windy enough for windsurfing today, and a holiday for MUni-ing tomorrow! Yahoo! I'd better find my crutches to get me through the work week! Have fun
__________________
#7 |
Newsgroup User
Posts: n/a
Thanks very much for the info. At some point, I'll have to convert
my bike to see if I can ride it the same way. I guess I should start with a track bike first, though, before attempting the freewheel. On Sun, 13 Oct 2002 13:36:09 -0500, unibiker <unibiker.ch65b@timelimit.unicyclist.com> wrote: >The hub is freewheeling; gears are changed to give me one-tooth >increments. I don’t think anyone has figured out how to make a locked >hub shift-able (but they’re trying). I think Michael Grant built a >freewheeling/shift-able giraffe, but I don’t think he had much luck >riding it, until he locked the hub. I’m using the brakes to tip forward >when necessary. A search for ‘unibike*’ will produce some past threads >on this project. Also, check this link for discussions on gearing - >http://tinyurl.com/1ygj |
#8 |
Snoball II
It seems to that you start by getting good at ding wheelies on a normal bike, and work your way up to harder things...
__________________
Max "The Maniac" Dingemans "Mmmm.....Soylent Green!" |
#9 | ||
Quote:
Quote:
In fact, I would recommend NEVER removing the front wheel. Falling forward will have to be painful, since the bars will prevent you from stepping off as with a unicycle UPD. Face plants are not good!
__________________
#10 |
Newsgroup User
Posts: n/a
Yes, a track bike has a single speed & a locked up. Sort of
like a giraffe with an extra wheel that doesn't touch the ground :-). There are also trick bikes which are set up the same way, and have extra footrests at various places around the bike. I saw a performer in Paris riding such a bike normally, then flip the bike over and hold onto the front wheel and ride it upside down, and then sit on the front of the bike and ride it like a unicycle. He was very good. He also had a giraffe and did lots of juggling, though I can't recall whether he juggled and uni'ed at the same time or not. On Sun, 13 Oct 2002 23:33:50 -0500, unibiker <unibiker.chxxb@timelimit.unicyclist.com> wrote: >hbaker1@pipeline.com wrote: >> *Thanks very much for the info. At some point, I'll have to convert >> my bike to see if I can ride it the same way. I guess I should >> start >> with a track bike first, though, before attempting the freewheel. > >Does a track bike have a locked hub? This is probably a better way to >start, with the front wheel in place for safety! |
#11 |
Newsgroup User
Posts: n/a
By the way, I don't understand why
a unicycle with the proper _fixed_ gear ratio couldn't beat or equal your unibike in an allout time trial race. Perhaps your setup is more aerodynamic? |
#12 |
Equipment Destroyer
Track bike? I dont think i understand. Do you have any links?
__________________
If it weren't for electricity we'd all be watching television by candlelight." George Gobol I have worked too hard to be a clown. I am an athlete and wish to be respected as one.- Checkernuts |
#13 |
ONE for the...Off Road
Location: West San Fernando Valley, Southern California
I posted her bymistake, never mind couldn't delete.
__________________
Rod Wylie |
#14 | |
Quote:
I think a properly geared uni will be faster. The problem is the major design change every time your legs get strong enough to handle a slightly higher gear. I haven't seen any times posted, but I expect the geared unis to have better times in the long run. And they are probably safer. The only advantage I have is being able to change gears easily. In a time trial race, the start would be interesting. I don't know which would have the advantage; starting in a low gear and shifting up or starting in a high fixed gear which would have very little power at the start. Maybe a Coker rider can give us a clue? It takes me about 30 seconds to reach 15mph from a standing start. Mounting is more difficult than a uni, and at this point I have much more success starting in a low gear. Are you involved in this 25k stuff? We need more participants to keep it interesting. I'm challenged by the possibility of a 1-hour 25k, but if I ever reach it, I'll need some competition to keep me interested.
__________________
#15 |
Newsgroup User
Posts: n/a
30 seconds out of a 1 hour race is < 1% of the total, and the start is
not subject to wind resistance. I would think that the start is not going to be much of an issue. I would be interested in TTuni (or is it uniTT?), but my first problem is getting out of the 10% hills around my house. I've almost conquered all of them, and would then be ready to move to the flats. I also don't have a Coker, which appears to be the best way to go after a good TT time (with the proper selection of crank lengths). From what I understand from this newsgroup, the Japanese use very small cranks and very high cadences for their races (150 rpm's?), which is probably a good way to go after a TT. But over the longer term, the big problem for unis will be aerodynamics -- a good TT time may will require some sort of a fairing to make up for the inability lean over for an hour w/o handlebars. Or perhaps a TT uni will require some kind of handlebars to be able to hold an aerodynamic position. On Mon, 14 Oct 2002 01:04:29 -0500, unibiker <unibiker.ci23d@timelimit.unicyclist.com> wrote: >In a time trial race, the start would be interesting. I don't know which >would have the advantage; starting in a low gear and shifting up or >starting in a high fixed gear which would have very little power at the >start. Maybe a Coker rider can give us a clue? It takes me about 30 >seconds to reach 15mph from a standing start. Mounting is more difficult >than a uni, and at this point I have much more success starting in a low >gear. > >Are you involved in this 25k stuff? We need more participants to keep it >interesting. I'm challenged by the possibility of a 1-hour 25k, but if I >ever reach it, I'll need some competition to keep me interested. |
| Tags |
| breaks, hour, unibiker |
