Announcement
Collapse
No announcement yet.
Remove vintage Schwinn cranks
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Remove vintage Schwinn cranks
    Any videos on how to remove cranks?
  • #2
    I've never seen a video about it. I'm assuming you're refering to cottered cranks since you mention "vintage". I just wanted to recommend looking for a vintage bicycle repair book. I am familiar with cottered cranks, if you have that type of crank and have questions.
    Comment
    • #3
      If they are cotterless you will need a crank extractor. The cotterless Schwinns have aluminum rims. If it has a steel rim you most likely have cottered cranks.
      If they are cottered:
      I highly recommend picking up a couple of replacement crank cotter pins before you remove the ones you have. They are made of soft steel, and deform easily. You will have much better luck using a cotter press; however, even a lot of bike shops don't have a cotter press anymore. Hammering may get them out, but I had a customer bike come in last year that he had hammered away at, and the threaded end was so deformed I had to spend far more time getting it out than I should have.
      You can buy one, or for a few dollars, and not a lot of time you can make one out of a large "top beam clamp." as in this video:
      https://www.youtube.com/watch?v=JIIjID_KdiY
      "A properly ridden unicycle is like an object in orbit: constantly falling but never landing." -Diogenes
      Comment
      Working...
      X
