Announcement
Collapse
No announcement yet.
ISIS Crank Reviews
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • ISIS Crank Reviews
    I was installing some QuAx chromoly cranks, and since I had a bunch of cranks just lying around, I pulled out the scale and had a weigh-in:
    KH Moment 137mm = 602gm
    Nimbus Venture II 150mm = 431gm
    QuAx Chromoly 145gm = 474gm
    KH Moment 150mm = 571gm
    Koxx K1 160mm = 630gm
    KH Moment 165/137 = 680gm
    Nimbus Venture II 165mm = 462gm
    QuAx Chromoly 170gm = 523gm
    QuAx Aluminum 170gm = 556gm
    I had expected that the Venture II's would be the lightest cranks as they are fairly slim compared to the Moments and they lack a pedal insert. What suprised me was the QuAx Chromly cranks which are not only lighter than every crank other than the Venture II's, but they are probably the strongest and most durable.
    My 29er lost 125gms tonight
    Steel is real!
    Anyone have weights for the shorter lengths: Moments 125, 125/150, K1 140...
    I dream of hamsters and elderberries
  • #2
    Not sure if you made a typo or if its to do with the accuracy of your scales but how can the 137mm moments be heavier than the 150s?
    Find out about my latest Enduro XC rides and races at my blog.
    http://www.markandhisunicycle.wordpress.com
    Comment
    • #3
      Nope, that is the correct weight, I thought the same thing, so I triple checked them. The 150's are newer and have some additional machining on the backside (2011), the 137 are from 2008-2009.
      Mark, did you machine your cranks or where you thinking about it?
      They QuAx chromoly cranks are pretty svelte
      Comment
      • #4
        Would you like me to throw up some Koxx 140s?
        Roses are red, violets are blue, may I procreate with you so I can ride a g32!! - Alan hogan
        Comment
        • #5
          Throw up as in puke? No, don't got none, buy some. Hey, this is not a discussion page! Weights, reviews, no chatter!!
          Comment
          • #6
            K1 140 reinforced
            Ok will weigh them when i can find a scale. I am 220 pounds and do regular 5ft plus drops with no bending
            Comment
            • #7
              The Ventures and Venture2s have absolutely no Q factor btw.
              Unicycling is really dangerous. I almost crashed... while driving to work while looking for good places to ride.
              Comment
              • #8
                Q factor, good point, maybe I can figure a way to measure than on my crank collection, then we could have a database of weight, lengths, and Q.
                Now that there are three different hub widths, Q factor is more of an issue, esp with the super wide 125mm bearing spacing on the Oregon and Impulse.
                I use the Ventures on the Oregon, tried to use them on the Nimbus ISIS 100mm spaced hib and it made my knees hurt, seems like there is an ideal width depending on rider size/width.
                Comment
                • #9
                  The Ventures are ~+5mm Q, the Venture2s are listed as "almost no" Q, the KH Moments are listed as +10mm Q, the QuAx have very low +Q.
                  Comment
                  • #10
                    Well, I thought the Q factor would vary more from crank to crank, but for the most part the cranks are either 10mm Q factor (Moments and QuAx Chromoly and Aluminum) and zero Q factor (Koxx, Ventures).
                    I measured the Q as an offest from the outside of the crank bolt hole to the outside of the pedal hole. I suppose the offset could be slighty different depending on how the crank goes on the spindle. On my Guni, the Moments go on really far, nearly touching the frame.
                    Comment
                    • #11
                      Its easy to measure Q-factor. Count how many cuts and bruises are on your ankles at the end of the day from riding.
                      Lots of Q-factor = no cuts and bruises
                      Little to no Q-factor = Cuts and bruises
                      TEAM FUN
                      Comment
                      • #12
                        Hello, first post here.
                        In my world, Q factor usually means the installed outside to outside measurement of the cranks. So if you're making a database, I guess hub and crank should both be listed.
                        I'm going to be learning to ride once our weather warms a little, have a 29er being built up for me. I borrowed a friend's 20" department store uni with a frozen post (too short) a few years back and over the course of a couple of weeks made it as far as 2 or 3 blocks. I could turn left but not right. I'm getting safety gear this time around.
                        Comment
                        • #13
                          Yes, you have a point, and this is an issue with unicycles because the cranks don't always go onto the hub in a "Standard" manner.
                          I measured my Oregon with 150 Ventures and the pedals inserts were ~8" apart, I measures my KH 29 with 145 Qu AX Chromoly and the dimension was ~8", then I measured my KHGuni with 150/125 Moments and the dimension was ~7.5"
                          Comment
                          • #14
                            To keep things simple I think only the offset of the crank in question is needed. Specs like these are usually used by people looking to buy new equipment. If the offset is listed they can easily measure their current hub/crank setup and come up with a pretty good estimate of where the new cranks will put them in terms of total Q.
                            Comment
                            • #15
                              True enough, I'm coming from a cycling background where cranks are often purchased with BB, throwing more possibilities of confusion into the mix.
                              Thanks!
                              Comment
                              Working...
                              X
