Announcement
Collapse
No announcement yet.
Kenda Nevegal 29x2.2
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Kenda Nevegal 29x2.2
    Last week I fitted a Kenda Nevegal 29x2.2 to my uni. It had a worn big apple before this.
    Riding on roads with it pretty hard, it's good. Quite aggressive tread but runs quite smooth when inflated hard. I reckon it would wear out quick tho.
    I took it to a MTB place (Drumlanrig) and was quite surprised at how grippy it is. ++ This was my first muni on a 29" ++ There was a good 3 inches of mud over pretty much everything, but grip below. It did do a bit of sliding around sideways but that was mainly due to me being out of practise of uni-ing generally and not being used to the 29 fully.
    When I first set off, I stopped to let some air out (it was still hard for the road), and rode off down the road to find the tracks. Aha! A track off to my right, turn quickly, tyre folds, pings back, throws me off. Stopped to put some air back in and it was ok. I don't know what PSI it was at.
    There was lots of rooty sections too and I kept coming off cos I thought the tyre would slip, and was expecting it to, but it didn't slip once. Preparing for a slip was enough to throw me off.
    Last night, I went out on the road again, well... the cycle path. I hadn't put any more air back in, instantly I noticed it felt much better than other nights on cycle path. It was quite hard to turn tho, unless I was really smooth I could feel the tyre bending and wanting to ping me again. Then it threw me off into some gravel just cos I was going fast! Altho I think this was my fault really!
    I think this is a good tyre as it is really grippy, has a good fit and grip on the rim, and is wide enough for a bit of bouncing. The sidewalls could be a wee bit thicker but from what I read/hear it is much better than other offerings.
    I think for me personally, I need a wider rim and the tyre would be great.
    Uni specs:
    cheap 29" curved crown frame
    127mm steel cranks
    uni.com cro-mo hub
    Rigida 29" rim - 27mm wide (I think - it's quite narrow anyway!)
    Kenda Nevegal 29" tyre
    Kenda 29" innertube
    wellgo V8 copy pedals
    standard KH saddle - think I might upgrade to a nice flat street one soon!
    T.
    "DarkTom of Glasgow, one of the few uni riders here that you really musn't mess with" - GkMac
    "mondeos can fly" - Pebbles
    24" uni for sale
    koxx/onza trials uni for sale
  • #2
    The KH 29er rim would probably make a huge difference in your experience.
    Weep in the dojo... laugh on the battlefield.
    -- Dave Stockton
    Comment
    • #3
      I think this is the tyre I got with the BA stock with my KH29... (I thought it was meant to be a kenda ''klaw'', but hey).
      I like the tyre a lot.
      It doesn't fold for me, but I run it with a high ish PSI (a little bit of bounce) because I find this nice for road riding, and equally nice for Muni - as the freeride seat absorbs some shock from bumps and the wheel size helps roll over them.
      I prefer it to the BA (2.35(?)) because of the road crown issues - I don't get any with the kenda nevegal, I can just ride straight . What's more, I like to have a bit of resistance and tyre noise while i'm riding, or it's just boring!
      1-wheeled-grape: ''I could never do yoga... I'm too fat I was forced to do it in primary school and the results were by no means fun'' ... ''If my belly doesn't scare me though no nakedness will''
      Comment
      • #4
        I would say avoid the Nevegal.
        It's a great tire for a bike if you NEVER do skids.
        But on a Unicycle, which tends to be hopped on quite often, it's going to wear down FAST.
        EDIT: Oh and the sidewalls are like 1/1000th the thickness of paper
        Gravity is not the issue.
        Comment
        • #5
          Well i've done a couple of hundred miles on mine and it hasn't worn much...
          Comment
          • #6
            Interesting, every Nevegal I've seen that's been used for any amount of time is usually nearly bald.
            Comment
            Working...
            X
