Announcement
Collapse
No announcement yet.
Qu-Ax 36 Disc
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Qu-Ax 36 Disc
    A quick review of my 36". Frame The finish is good welded on brake mount and no flex so far . Wheel The hub is nicely made but the bright red is a bit bright for me the cranks are good 125 150 holes they look very similar to shimano bike cranks , not sure how strong they are but this is a road only uni the rim and spokes look up to the job the king George tire is silent and tracks good , it is a dished wheel and is about 2mm closer to the disk side but does not effect the uni. Saddle is a qu-ax 11 which has a KH base it is very similar to a KH street but has a slightly softer top layer so it suits me very much. Bars qu-ax loopy bar is good very stiff and light but the foam on the front is vanerble to upd damage I have seen the weight advertised between 7.1-7.7 kgs so pretty standard for a 36 the specs said it has a foss tube but I don't know how to tell if it is , so far all is good but I have only done about 100ks.
    This is the most stupid thing you have ever purchased. "WIFE"
  • #2
    For the FOSS tube, you can tell by the valve poking out of the rim. If it is a blue shradder valve it is a FOSS tube (should be marked also on the valve I think ).
    => CrMo 29: KH XC rim, Nimbus CrMo hub, Spirit 110/137 & Schwalbe Big One
    => Flansberrium 26: Nextie rim, JumboJim 4.0, Spirit 127/150mm, M4O ISIS
    Comment
    • #3
      Thanks for the spammer who unearthed this thread!
      It's a cool uni. I have its older brother - Isis cranks instead of their own system - and it's a great machine! Just got the new lightweight tire for it, can't wait to shake the flu off to try it!
      Comment
      Working...
      X
