Announcement
Collapse
No announcement yet.
26“ KH rim 47mm wide VS 26“ Nimbus Dominator2 rim 42mm wide.
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • 26“ KH rim 47mm wide VS 26“ Nimbus Dominator2 rim 42mm wide.
  • #2
    So which is heavier?
    You could drill out the Nimbus, I would drill the outer wall before the inner one for a variety of reasons. How far you go with it is up to you.
    A wide rim will give you a more stable ride with a squarer profile to the tire, but you will be slightly more prone to suffer camber issues and sidewall damage.
    I generally think that the advantages of a wider rim trumps the disadvantages but hey, everyone rides different. Both rims are well suited to 3" rubber.
    Comment
    • #3
      Nimbus Dominator2 is heavier: 850 g, whilst KH Freeride is 700 g + rim tape. I know both are almost the same... considering your advice I think maybe the most relevant is the price
      Comment
      • #4
        When I built my 26" I chose a 32h TrialTech Race rim @ 47mm and 795g and a Nimbus 32h hub. I drilled the inner wall before I built it up and haven't had any problems but didn't loose much weight either (less than 1oz) as my drilling was pretty conservative. The TrialTech rim was less expensive than either the Nimbus or KH, was in between the two in weight, and had the width of the KH.
        Comment
        • #5
          The D2 is stronger, the KH is lighter, the D2 is less expensive, the KH has better brand recognition, the D2 is easier and possibly better for tubeless, the KH is 5-7mm wider.
          Both rims work fine.
          Don't buy the D2 with the plan to drill the rim, you will waste more $$$ of your time, possibly reduce the strength of the rim, and certainly make it less valuable for resale.
          If weight is your primary concern, consider a Salsa Gordo or Velocity P35, they are lighter and stronger than the KH, also not as expensive, but they are 35mm wide.
          I dream of hamsters and elderberries
          Comment
          • #6
            Couldn't agree more. I'm more of a Dominator2 fan as the slight increase in stability and grip you get from the KH rim isn't worth the extra drag and funny handling but each to their own.
            Hit the nail on the head. The KH rim relies on the sheer strenght of the aluminium whereas the D2 is strong due to it's high profile and round shape. The D2 is like an egg/football - strong, until punctured.
            IMHO, the D2 is a better rim. It handles better, it's stronger, less wide (I prefer narrow rims for smaller tyres and the fact that they don't 'stretch' tyres) but it is pretty heavy. If you're going to run a 3" tyre, however, I highly recomend running a lighter tube. I put a Maxxis 2.75 (I think) in my Oracle 24 and the difference in the way it tackles bumps is night and day.
            You know how people can do a "kick up" mount? Well I can do a "kick down" dismount. - Cloudz
            Things are easy, apart from when they aren't
            Comment
            • #7
              [ If you're going to run a 3" tyre, however, I highly recomend running a lighter tube. I put a Maxxis 2.75 (I think) in my Oracle 24 and the difference in the way it tackles bumps is night and day. [/QUOTE]
              Why do you run a smaller tube in a wide tire? I have heard of people doing that but I never understood how it helps. I would think that a large tube would give you more air volume which would make it easier to roll over bumps, and a small tube would make it harder.
              Comment
              • #8
                Small tubes will still stretch to fit the inside of your tire, so volume is the same. However, since there is less material than for a larger tube, it's lighter. Not to mention, it's awful hard finding high volume tubes locally. Many even run smaller diameter tubes in their wheels, ex. 29" tubes on 36" wheel.
                "I used to watch Highway Patrol whittlin' with my knife..." - NY
                Comment
                • #9
                  Yeah wider dampens out the ride for small bump compliance & drops, and less likely tire fold over, but less spingyness for hops and a bit harder to mount the tire. Some (eg Muniaddict) have gone even wider than the 47mm KH, to a 65mm Large Marge.
                  Kris considered widening all the rims to 50mm but felt the weight wasn't worth the various advantages. One of his testers of the 29er did prefer the extra width so he kept using it. To each his own.
                  IMO if u plan on riding very tech terrain, go KH. Bumpy & flowing - D2.
                  Ride everywhere and never just ride anywhere. If you can ride where you are going within a hour, do it, and if you can do a trick 50-75% of the time do it along the way.- Bob Burnquist
                  What's next?
                  Learn2Ride&doTricks
                  TrialsClasses&Building
                  Comment
                  • #10
                    I ride super tech and use a D2 because it stays true longer
                    Roses are red, violets are blue, may I procreate with you so I can ride a g32!! - Alan hogan
                    Comment
                    • #11
                      The tube I've got in now is still pretty heavy so the weight saves is negligible (especially with a duro 3") really. The difference is in the rubber compound - my 3" tube is hard and plasticy whereas my 2.75" tube is really rubbery and soft making it a joy to ride on.
                      Comment
                      • #12
                        Rubber is heavy!
                        A Maxxis 3" DH tube weighs 450gm
                        A Maxxis Freeride 2.5 - 2.7" tube weighs 300gm
                        A Maxxis Welterweight 2.2 - 2.5" tube weighs 225gm
                        A heavier duty tuby can change the ride feel and can increase the flat resistance, but consider the weight penalty.
                        You would be better off running a lighter tube or even tubeless in a better tire than going with a heavy duty tube in a lightweight tire.
                        The tube provides support, but the tire is really where the work gets done.
                        I am currently running a 29 x 1.9-2.3 standard tube in my Knard 29 x 3" tire. It works fine and it's hundreds of grams lighter than the Surly tube or a DH tube.
                        Comment
                        • #13
                          Rubber is heavy!
                          Comment
                          • #14
                            http://www.unicyclist.com/forums/sho...94#post1584594
                            Comment
                            • #15
                              Originally posted by Milodar View Post
                              Thanks to saskatchewanian, davidp, Nurse Ben, Jacob Young, Coler, Killian, skilewis74 and knoxuni for great and reasonable arguments about rims.
                              No problem I'm always happy to help a fellow unicyclist.
                              Buying KH might support Kris but Buying Nimbus supports UDC - it's your call.
                              Comment
                              Working...
                              X
