Announcement
Collapse
No announcement yet.
Nimbus 36" Impulse - Disk Brake (350 ONO)
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • [For Sale: UK] Nimbus 36" Impulse - Disk Brake (350 ONO)
    Selling due to lack of use. Has been stored in a dry garage for 3 years and is in a great condition (see minor wear and tear in photos and below)
    Only ridden a couple of times.
    Item located in Derby but can meet in Birmingham or Gloucestershire as I travel regularly with work.
    See gumtree for photos and details: [URL="http://www.gumtree.com/p/bicycles/nimbus-36quot-impulse-unicycle-disk-brake/1312461877"]
    Saddle: Nimbus gel (black)
    Seat post: Nimbus 25.4 x 250lg Pivotal Seat Post (has been cut down due to shorter rider)
    Saddle: Nimbus Shadow handle base
    Handle A: Nimbus Shadow T-handle, bent, 400mm long (non bent handle included)
    Bar ends: Nimbus Shadow Bar ends, 130mm long (slight damage with scuffs)
    Frame: Nimbus 36" Impulse Disc version of the Nightrider
    Hub/axle: Nimbus ISIS drive LT Disc (black/green) 36H, 7075 series aluminum splindle,128mm center bearing to center bearing
    Spokes: 14G. stainless (372mm in length for 3X) brass nipples
    Rim: Nimbus stealth1 36 18mm lightening holes, 42mm wide, aluminum doublewall, reinforced eyelets, ERD-767mm
    Tire: Nimbus Nightrider 36" x 2.25" multi surface
    Crank arms: Nimbus 125/, ISIS splined, aluminum (slight damage to one crank bolt)
    Pedals: Nimbus, reinforced plastic body with steel removable pins, backing plate for added durability and CrMo axle with 9/16 threads
    Bearings: 22mm x 42mm x 12mm
    Brakes: Bengal Helix 1.1 hydraulic brake with 160mm disc
Working...
X
