Announcement
Collapse
No announcement yet.
150mm isis venture 2 left crank
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • [Wanted North America] 150mm isis venture 2 left crank
    I need a set of 150 isis cranks. I happen to have a pair of venture 2's but the isis splines on the left one are bad. So the right one is taunting me. Before I go out and buy a new pair, does any one have a lonely left crank? I may also be interested in a set of cheap muni able isis cranks in the 150-137 range.
    Matt
    "A unicycle is a silly contraption."
    My wife
  • #2
    I use these (links below) - decent very strong, not too heavy 152mm Cromoly ISIS uni Cranks - $35 + shipping new. Both links are for same cranks - just different sites.
    https://www.amazon.com/Replacement-U...ct_top?ie=UTF8
    http://www.niagaracycle.com/categori...-off-road-isis
    Comment
    • #3
      Build quality on these is not quite as good as Nimbus / KH, but they work well.
      I had an issue with one loosening, but some lock-tite on the Crank bolt solved it.
      Comment
      • #4
        Keep thinking of extra details to mention - these cranks pretty straight / low - Q maybe slightly wider than Nimbus. Definitely lower Q / narrower than KH.
        Comment
        • #5
          Thanks Caseytronic. I will keep those in mind. I will probably be getting a few things from UDC UK soon so I may pick up some at that time. If someone sees this thread 5 years crom now I will probably still have a right one☺.
          My wife
          Comment
          • #6
            Matt I have a pair that you can have. They came on my 24" muni.
            Send me a PM.
            Comment
            Working...
            X
