Announcement
Collapse
No announcement yet.
Nimbus Oregon
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • [For Sale] Nimbus Oregon
    I have a Nimbus Oregon unicycle from the first "edition." It has not been ridden very much since I have had it. I just never felt very lovable towards the ride. I can send pictures if interested. I'm in the SF Bay Area (San Jose). Prefer pickup, but will ship at your expense. Asking $485.00. You can text or call (text is easier) 408 205-9 one one 6.
  • #2
    What size wheel?
    Comment
    • #3
      This is the 26" wheel. It's like riding a 29" because of the fatness of the tire. This picture is mine from when it was new. It has a fatter tire now, also the white is a bit dirty from drops in the dirt.
      Comment
      • #4
        Hub size
        I was asked if the hub is 100mm or 125mm. I admit that I don't know. Can any of you that know post the hub size here for the original Oregon?
        Comment
        • #5
          All the Oregon have the same 125mm hub spacing. You need width to get this baby in and out of the frame.
          => CrMo 29: KH XC rim, Nimbus CrMo hub, Spirit 110/137 & Schwalbe Big One
          => Flansberrium 26: Nextie rim, JumboJim 4.0, Spirit 127/150mm, M4O ISIS
          Comment
          • #6
            Thanks. It is definitely wide.
            Comment
            • #7
              Not really. Wide makes for a strong wheel, but the Surly Conundrum, and the new Mad4One frames use a 100mm hub. You just have to let enough air out of the tire... Usually it's squishy enough to just slip out anyway.
              Steel is real! => I ride a Nimbus!
              Comment
              • #8
                You are right JuggleAddict, it is okay with a 65mm rim and 3.8 tire (that is the stock configuration of the Oregon).
                However, if you start using all this frame space to the full (with a 4.8 or bigger tire and/or with a 80mm rim or more), you start being thankful for the wide frame at the base.
                (back to the initial topic)
                Don't worry too much about the self-steer, the Oregon pictured here has a Surly Larry tire that is prone to self-steer. If you go with a more recent tire, you should not get that much self-steer (but with a 4.0 tire, you have to show the uni who's the boss anyway ).
                Comment
                • #9
                  [T]he Surly Conundrum and the new Mad4One frames use a 100mm hub.
                  I don't know about M41, but the 2009 Surly catalog says
                  Bearing compatibility: 42mm OD x 12mm wide
                  Hub bearing spacing: 102104.5mm, measured outside to outside
                  so 90-92.5mm center to center.
                  Comment
                  • #10
                    They were build on 100mm Profile Racing hubs originaly. Crmo can be streched a bit. The frames probably squeezed to 90mm when they took them off the jigs. All my frames need some streching right after welding. I jig them 2mm wider to strech less when I'm done.
                    Jakob F.
                    Comment
                    Working...
                    X
