Announcement
Collapse
No announcement yet.
cap for double hole cranks
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • cap for double hole cranks
    Hi I have a pair of kh moments 125/150 I was wondering if anyone knows where to buy or how to make a cap that willl keep dirt out of the hole that's not being used.
    More ideas than talent
  • #2
    I've heard of people using duct tape and wrapping around the crank to protect the holes. Personally, I haven't covered them with anything and haven't had any problems other than the normal insert movement associated with moments. However, I'm far from experienced.
    "I used to watch Highway Patrol whittlin' with my knife..." - NY
    Comment
    • #3
      I sometimes use insulating tape...... but its not really a big problem
      Unicycling in the Scottish Highlands
      "Unicycle into the Skye" unicycle tour Scotland June 2015
      http://www.facebook.com/?ref=home#!/Highland.Unicyclist
      Comment
      • #4
        I made a thread about it quite a while back: http://unicyclist.com/forums/showthr...ight=dual+hole
        Happy Birthday Terry! Every year you get cooler, younger and unicyclier!
        Be our muniprohpet for many years more.
        -Dani Buron
        Website
        Videos
        Facebook
        Comment
        • #5
          Could use a bar end cap.
          Roses are red, violets are blue, may I procreate with you so I can ride a g32!! - Alan hogan
          Comment
          • #6
            I use expandable foam ear plugs.
            But they are bit difficult to get back in my ears afterwards!
            Comment
            • #7
              I didn't give this much thought until I read this thread this morning. I took a look at my cranks and found that the threads had grease on them from the factory and they had collected quite a lot of sand and grit. I cleaned out the holes and then wondered what I had that I could use to seal them. My solution was foam insulation that I bought for a dog door that I installed. Pictures will show the install details. Very quick and easy.
              "Imagination is everything. It is the preview of life's coming attractions."
              -- Albert Einstein
              Comment
              • #8
                How about a set of spare pedals? You never know when you might break a pedal on the trail.
                - 4umfreak
                Geagle Search Engine a unicyclist.com inspired search engine. (kh longneak vs shortbeak)
                Comment
                • #9
                  I carry an old toothbrush on rides where I plan on changing cranks.
                  A couple of spins and the threads are clean.
                  Comment
                  • #10
                    I carry a spare seatpost when i ride trials but not when i ride muni
                    Comment
                    • #11
                      I like that idea but have a couple questions
                      1.Is it easy to remove/ can you reuse
                      2.Do you twist it in or did you push it in the hole
                      3.What is the black stuff on the end
                      4.How do you remove it
                      Thanks
                      Jack
                      Comment
                      • #12
                        sorry that was to SalManilla
                        Comment
                        • #13
                          it is easy to remove and yes you can reuse
                          I pushed mine in
                          i am not sure what he black stuff is
                          I just pulled mine out.
                          Thanks
                          Jack
                          here ya go!
                          Comment
                          • #14
                            Originally posted by knoxuni View Post
                            here ya go!
                            thanks!
                            Comment
                            • #15
                              Yes. Just pushes right out and back in.
                              See above
                              It's 'Phil Wood' bearing grease. Did that to help keep moisture out.
                              Just pushes out with pinky.
                              Thanks
                              Jack
                              Here ya go again.
                              -- Albert Einstein
                              Comment
                              Working...
                              X
