Announcement
Collapse
No announcement yet.
Knee pain
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Knee pain
    Hi,
    I've had my 20" unicycle for around 2 weeks now, and for the last 7 days I've had sharp pains in both of my knees causing myself difficulty climbing stairs and nearly impossible for me to unicycle. I've never had the kind of pain before. Just wondering if any of you people have also experienced this or have any advice.
    Thank You
  • #2
    Could it be how you position your feet on the pedals? I have never had knee pain from riding, in fact it makes mine feel better.
    Dropbox is a neat app I found that I use to store files and pictures of my Uni. Works on my iPhone and computer. I no longer have to email pictures to myself.
    Comment
    • #3
      Yeah, I have a weak meniscus disc that has torn a few times (not unicycle related). Unicycling has actually helped in that it has strengthened surrounding muscles making the knee feel much better.
      Where does it hurt? I know that when I started back on the unicycle it would hurt directly above my kneecap. Two things fixed that: 1) resting and allowing the muscles in that area to get stronger with time and 2) raising the seat. The muscles above my knee will still occasionally hurt a bit if the seat was too low during the ride.
      I'm different, yeah I'm different. I'm different, yeah I'm different. Pull up to the scene and my wheel is missing. Pull up to the scene and my wheel is missing.
      Comment
      • #4
        Yes, I had similar knee pain shortly after learning to ride. Take it easy for a while and come back to it gently. Your knees probably aren't used to the kind of abuse that unicycling can dish out.
        For what it's worth, my knees are fine now and never bother me, even on long-ish rides.
        - 4umfreak
        Geagle Search Engine a unicyclist.com inspired search engine. (kh longneak vs shortbeak)
        Comment
        • #5
          When I first learned how to ride, my knees hurt really bad. I fixed this by raising the seat.
          Comment
          • #6
            Wow, my hint would be "try to lower your seat"...
            I had the same problem years ago, while riding for hours with my big backpack, and I felt better lowering the saddle a little. Then I put an elastic band, quite thight, around the knee, and it was fine.
            I'm not a knee surgeon, but I'm a thoracic surgeon...
            But the best hints are the most logical: I think that you have to rest for some days, then start slowly, after a good warmup... Go little by little! If the body says to you:"i feel bad", well, Listen to it!
            PS: now I ride a lot, with NO pain at all, even after days of massive riding!
            Good luck
            Nic
            http://picasaweb.google.com/Giocologgi
            Comment
            • #7
              I had really bad knee pain in my right knee for about 8 months before it cleared ...... 3 days after it cleared my left knee started hurting in exactly the same way!!! for now its volterol gel, Ibuprofen and a knee strap whenever I ride over 15 miles..... I think knees just need to build up their strength
              Unicycling in the Scottish Highlands
              "Unicycle into the Skye" unicycle tour Scotland June 2015
              http://www.facebook.com/?ref=home#!/Highland.Unicyclist
              Comment
              • #8
                In the beginning I panicked that my hurting knees would end my unicycling. I took it easy, took days off of riding here and there, and added a brake for downhills. Eventually the knees cleared up and (knock on wood) haven't been a problem since. My elbows actually are more of a problem. Figure that one out.
                Comment
                • #9
                  I find high speed downhill the hardest thing for my knees..... I normally ride either G29 or G36 so I shift in to low gear to cut the strain down
                  Comment
                  Working...
                  X
