Announcement
Collapse
No announcement yet.
Help With Rolling Wraps
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Help With Rolling Wraps
    i need some tims on rolling wraps.
    i can do the roll and stepover with a seat pass but cant seem to get the uni to roll when im on the other crank. ive watched many tutorials but maybe you guys have some tips. im also not stop rolling when i step over
    If you need a vid of me just ask
    Matt Manson
    FlatStreet
  • #2
    Try doing them down a slight hill, this will give you some extra momentum. You also should be able to gain some momentum from pulling the seat forward after the seat pass. A video of your attempts might be helpful.
    My Website: www.Unitips.ca for trick tips and gear advice!
    Visit Municycle.ca Canada's online unicycle source!
    Check out the Municycle.ca Blog for news, tutorials and more!
    Comment
    • #3
      Thanks for the tip. ill see if i can take a vid tomorrow cuz im busy today.
      Matt Manson
      FlatStreet
      Comment
      • #4
        Any tips on foot position on the cranks?
        Does a stiffer sole help?
        The best advice I've heard so far is to keep your weight over the hub.
        A good video tutorial would be awesome!
        - Kenny
        Comment
        • #5
          You just want the middle of your foot in the middle of the cranks really, make sure they are straight so your feet won't get caught in the cranks or slip off. For the second part of the roll, it definetely helped me to pump up the tire a lot so it would roll more easily. If you keep falling off a certain way, try countering the weight, see if it helps.
          Unihopper did a good tutuorial: [ame="http://www.youtube.com/watch?v=PNn-bmNzjnI"]YouTube - ‪Rolling wrap tutorial‬‏[/ame]
          Hope this helps
          Comment
          • #6
            Finally i landed it! i got ike a bunch of em . Thanks for the tips
            Matt Manson
            FlatStreet
            Comment
            • #7
              Congratulations!
              Comment
              • #8
                i watched your tutorial a few more times and then used your tips. They worked great thanks!
                Matt Manson
                FlatStreet
                Comment
                • #9
                  I've found it a lot easier to use flat, stiff soled shoes. My 5 10's are the stiffest shoes that I have and I can rolling wrap a lot more consistently with them that my old, softer DC's.
                  My latest video
                  Comment
                  • #10
                    i have found that any flatland is easier with stiff sole shoes
                    Matt Manson
                    FlatStreet
                    Comment
                    Working...
                    X
