Announcement
Collapse
No announcement yet.
Post Your MUni here!
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Post Your MUni here!
    So I've been wanting to see peoples MUni's and specifications of them.
    Heres mine:
    Specks:
    KH Fusion Freeride Seat 09
    KH Adjustable Seatpost
    Nimbus 24'' ISIS Wheel with KH Moments, 150's and Trailmix Pedals
    KH 08? Frame
    Magura HS 22 Rim brake
    Sam
  • #2
    Ok! here's mine! But I'm waiting for a brake, I should get it soon. Anyway here it is.
    Specs:
    Torker DX wheelset
    NimbusII orange frame
    Custom trimmed Coker seat
    Gazz 2.6 tire
    Axiom Double jump pedals
    Magura HS-22 raceline brake (Coming soon!)
    Jakob F.
    Comment
    • #3
      Here's my geared 26":
      stripped KH29 frame 07
      KH/Schlumpf hub
      KH09 fusion freeride seat + T-bar
      KH seat post unadjustable
      KH single bolt clamp
      KH moment 225/150 cranks
      Odyssey twisted PCs
      TryAll 26" x 47mm drilled rim
      Nokian Gazzaloddi 26x3
      I'll post it's little brother KH24 soon.
      -knee
      Comment
      • #4
        KH/Schlumpf hub
        Odyssey twisted PCs
        I really like your Guni. I hope I could get a schlumpf hub one day too
        I hope your cranks are not really 225mm and 150mm long
        Jakob F.
        Comment
        • #5
          So here is Wickie:
          KH24 2008
          Magura HS33
          137 moments
          www.bikepark-info.com
          Comment
          • #6
            Here's mine...
            Frame: Lightweight CroMo Nimbus II style.
            Hub: 20mm diameter 36-splined hub with a dual keyway.
            Bearings: 20 x 42mm Sealed bearings.
            Cranks: 165mm super strong CroMo splined cranks, chromed.
            Rim: Alex double-walled deep section rim.
            Saddle: New Onza Kris Holm saddle.
            Weight 6.5kg
            If I'm going to keep it, (which I think I am) because I want a Coker Big One before upgrading my Muni, than I want to powdercoat it pink and see if I can put Moments on it, not sure if I can. No brake because so far I don't need one, because I'm still a newbie, eventually I might and it is set up for a brake, so whenever.
            My Facebook Page
            My Twitter Page
            I plan on riding unicycles till I break a hip and then I'll ride a little longer.
            Comment
            • #7
              Thanks! And the cranks are of course 125/150s. I am having a lot of fun with it, but I am really looking forward to get some brakes installed once I get a frame that is compatible with the hub, tire and the maguras...
              -knee
              Comment
              • #8
                Originally posted by ally1776 View Post
                Here's mine...
                Weight 6.5kg
                I think you can put moment cranks on that hub. The moments are ISIS and this hub is splined ao it wont fit. The only way to put moments is to change your hub.
                That would be awsome with a brake, It would be the perfect Muni/XC machine!
                Jakob F.
                Comment
                • #9
                  Thanks, that is sort of what I was afraid of. I don't think I know enough about all that to try it. I can deal with what it has as they are fine, but I have Moments on my 20" and really like them so it was just a thought, especially if I have to take it all apart to paint it eventually anyway.
                  I appreciate the input, saves me having to ask later. Did you go for your Coker ride today? I went to three parks and rode till I was exhausted and had to dismount, even remembered to dismount with uni in front (practicing for my Coker, haha) awesome fun!
                  My Facebook Page
                  My Twitter Page
                  Comment
                  • #10
                    you have seen that the surly frame is now availible on municycle.com?
                    http://www.einradladen.net/shop/show...roducts_id/799
                    its in the 26 wheelsize and schlumpf compatible? plus it has the magura brake
                    Comment
                    • #11
                      Yes, and it's 300 and weighs a lot. But I would get it if it were cheaper. I just asked them if the Koxx frame could work by any chance but didn't get an answer yet. That would only cost 50 but I'm afraid it isn't compatible with the hub...
                      -knee
                      Comment
                      • #12
                        Just take off you cranks from both unis and you'll see, the splined hub is smaller than the ISIS and I dont know if they both have the same numbers of spline.
                        And yeah I did a really small Coker ride, it was rainy so I havn't been really long outside today. It was only like 15km.
                        The Koxx-one frames aren't compatible with schlumpf hub, because they have "un-machined" bearing holders. I dont think it will work with a Surly frame too. Just wait until the KH26 frame is gonna be compatible with 3" tires. KHs are much better IMO.
                        Jakob F.
                        Comment
                        • #13
                          I will a pic tonight.
                          Specs:
                          KH Freeride 08 seat
                          Kh adjusterble seat post
                          Echo TR Hydraulic brake
                          Nimbus Balck double bolt seat clamp
                          Nimbus Orange Frame
                          JC trailmix pedals
                          137/165mm Moment cranks
                          Duro wildlife 24x3 tyre
                          08 24" kh rim'
                          08 KH hub
                          You know your not succeding when you know your not achiving anything
                          Comment
                          • #14
                            Specs:
                            KH Freeride 08 seat
                            Echo Hydrolic brake
                            Nimbus Orange Frame
                            JC trailmix pedals
                            08 24" kh rim'
                            08 KH hub
                            I always wanted to know if they would fit on Magura brake mounts. I've seen a couple and they look awsome
                            Jakob F.
                            Comment
                            • #15
                              yes they fit like a charm. Its also an echo TR lol
                              Comment
                              Working...
                              X
